Chevy Tahoe/GMC Yukon Hybrid Electrical and Lighting Questions
I own a 2003 Tahoe with a factory towing kit. I recently hooked up my travel trailer and noticed the trailer brake lights did not work. The Turn Signals work, the backup lights work, also the running lights work. I replaced the bulbs and it did not help. I decided to try my little landscape trailer and I have the same problem. I then measured with a voltmeter and found that I was not getting 12 volts on the right and left signal pins at the connector on the Tahoe (7 pin). I saw the voltage rise when using the turn indicators, but nothing when the brakes were engaged. The brakelights on the Tahoe work fine, as do all of the lights and signals. I am perplexed. Does anyone have any advice? Thanks
Tommy D
I checked the fuses for these items and they are not blown. Does anyone have any suggestions on what I can look for?
Mike
