Jaguar XJ-Series Starting/Stalling Issues
This problem is weird. When I turn the key to
start the car, everything shuts down. I mean
everything. No power anywhere in the car.
Sometimes when I take out the key, the instrument
cluster clicks and flashes and power comes back. Other times, I have to open the trunk, manually
with the key because therer is no power. I shake
the wires near the battery and power comes back
on. This does not happen all the time. Jaguar
said the battery terminals were dirty. I don't
think so. Something is causing the entire
electrical system to disconnect. The computer
then resets, the radio loses it's stations, etc.
The main concern I have is WHY is there no power
to anything in car. Is there a main disconnect
somewhere in the car that will do this? Please
help because Jaguar doesn't have a clue!
Ric
Ric
How corroded are they at both ends?
How old is the battery?
Sometimes when you disconnect the Negative or Ground cable to the battery, for 30 or more minutes, circuts reset themselves.
Any Ideas?
Doug
My daughter kicked the floor board and it cured the problem. It was a loose wiring harness- under the dash. U can reach it (them) with your hand. The red light is an indication that the security feature is activated.
