Toyota 4Runner Electrical Problems
I have a 97 4runner Limited that I'm having trouble with. The rear wiper , rear defrost, and window for the hatch are all inop. These all happened at pretty much the same time. The wiper was working very slowly but now not at all. Also the license plate light will sometimes stay on all the time after I shut off vehicle. The only way to get it to go out is turn the ignition switch on and then back off, then light will go out. This seems to happen more frequent when I use the key fob to lock doors and set factory alarm. Ihave checked all fuses and they are ok. I also checked the wires where they come through the roof to the rear hatch for rubbing. No problem found there either. It seems like all the problems could be related to maybe a relay? I dont know, anyone have any thoughts or know where I might find the relays related to these items? thanks.
I just encountered a problem I hope someone can help me with. My 97 runner doesn't seem to want to start. I have enough power to turn on my head lights, interior light and move the power seat. However, the dash warning lights do not come on when I turn the key, nor does the radio, and the power windows will not close either. The ignition lock turns but there is absolutley no sound from any of the accesories. All the fuses look good is there a "secret fuse block somewhere I am neglecting?
i am from downunder
the car was well looked after ( i examined it before the dealer had time to have it detailed for the lot)
i went for the "defence pack" after market protection.
ie,paint,upholstry,and electronic RUST PROTECTION.
I had some accessories fitted before delivery.
towbar,rear step and a heavy duty roof rack.
I had an operation that month and the vehicle was rarely driven over the next six months.
I had a stainless steel nudge bar and spotties fitted before a 6 week trip to europe.
on return i noticed extreme rust on the spotlights and
the 2 stainless steel ratchet tie downs on the roof rack.
the suppliers had never seen such corrosion on either of these products.they replaced them under warranty.
i then had stainless steel side steps fitted.
within 2 weeks,all the offending items as well as some painted screws on the sidesteps are rusting out.
took the vehicle back to the roof rack supplier and was told he had heard sometimes these electronic systems actually seek out accessories somewhat like a sacrificial anode.he offered to replace the ratchet device again.
took the hilux back to the inspection centre for the rust prevention system.got the run around.
he eventually just took the fuse out to disconnect it from
the vehicle.
has anyone out there had any similar experiences.
no kidding,the rust that forms looks more like what you would expect after 2 years,not 2 weeks!
:mad:
Any ideas?
THANK YOU. gary.schaut@gmail.com
And, by the way, we advise against posting your email address in public postings.
SUVs and Smart Shopper
-Josh
I'd like to thank you for taking the time read this email! I have a 1990 4-Runner V-6 4wheel drive 3.0 Liter engine. The stock 60 AMP alternator just went out and I had heard that you could upgrade to a higher alternator with an out put of 130 AMP. The 3.4 liter Toyota years 95 1/2 to 2004 but, that it must be the alternator that supports the tow-package? I had also heard that you may have to shim it to make it fit ? I have offroad lights that I plan on installing onto the 4-runner. Do you think that the switch from 60 AMP to 130 AMP will damage the electrical system in the 4-Runner?I can't find anyone that will give me any real information on the subject and I hope that you might have some answers to my questions? I really look forward to your reply and hope that life is treating you and your family GOOD
I have spent two days following circuits on the thing and have the following: Constant voltage line to the radio tests at 8v. and drops to 2v. when any cabin lights or door switch goes on(lights don't come on)
I have checked all light switches and circuits for shorts.
Relays for running lights and brights ok.
Light control switch (low,flash,brights) ok.
A couple of weeks ago, I drove across town and stopped at a local business. In the middle of the drive, I heard a noise that sounded like a rock hitting one of the wheel-wells along with a "twang," sort of like a guitar string breaking. When I stopped at the business, I turned the key off and noticed that the power antenna didn't retract. I didn't think much of it at the time, just figuring that it was an antenna motor or connection problem. I went inside the building and came out about 30 minutes later. When I got in, the battery charge was very low- not enough to turn the engine over or operate the power locks. However, I could hear a motor-noise that seemed to be coming from the power antenna. I jumped the vehicle and drove it home without a problem. I was sick over the next couple of days and didn't start it. When I tried later in the week, it was totally dead again.
Thinking that a connection might be bad in the antenna motor, I disconnected it, jump started it again and drove it for a while to build up a charge. The next day, it was completely dead again.
After this, I decided to take the battery to a shop to have it tested. The shop had a computerized tester, which indicated that the battery was okay. I asked them to charge it and when the charging process was finished, the cold cranking amp level showed just below the original factory rating, which I think was 530 (I believe the CCA level indicated by the charger was about 480 or so). However, the charger also said, "REPLACE BATTERY," which I chose not to do. I brought the battery back home and reinstalled it. Over the following week or so, I didn't have any problems, driving the vehicle (I think) about 5 out of the 7 days of the week.
Today (the beginning of the following week), I drove the vehicle about 15 miles or so and shut off the engine. I had not experienced any further problems since having the battery charged, but when I tried to start it again, it started and ran for about 7 seconds and then the motor shut off (I didn't shut it off, it just cut out on its own). I tried to start it again and it was completely dead... AGAIN! I jumped it and drove it home without any problems. After I arrived at home, I shut it off and then immediately started it again. It did start without a problem.
However, I'm not sure what's causing this to happen. Since the battery charger/tester at the local shop said to replace the battery, I'm thinking that might cure the problem, but it doesn't make sense to me that the current battery would be the source of the problem because it seems to work fine, then completely die, then work fine, then completely die, etc., etc. Also, since the vehicle has been running fine a couple of times and cut off on its own, unable to restart, that seems like it might be something other than a battery problem. I don't know, though, whether or not a battery can cause that.
Could anyone tell me whether this seems normal for a battery problem? If not, does anyone have any suggestions at to what MIGHT be causing it?
Any help/suggestions would be REALLY appreciated!!
- Alan W.
PS- I'm not sure, but I think the battery is about 3 years old.
I have a 2005 4Runner Limited with the V-8 and air ride. When I step on the brake, the GPS and 12volt charger go out but come right back on. This happened only when I stepped on the brake until today. Then the problem happened at idle in park. Also yesterday the engine seemed to be searching for an idle. Lastly as I was driving down the highway today with the cruise control on the car did the same thing but took the car out of cruise control, then the cruise control indicator started to flash. It only stopped after I turned the cruise off and back on. I have 165k on the truck and use it to tow our camper. What a great tow vehicle and I am just not ready to get rid of it yet, still have another 200k to go. Any helpful suggestions are appreciated.
