Towing with a Forester
-mike
a. You should have trailer brakes since it's over 1000 lbs
b. If towing beyond short distances, a transmission cooler would be extremely helpful.
c. When towing something almost as heavy as your Forester, be aware that the emergency handling will be severely compromised.
-Frank
Be constantly aware on this point.
c. When towing something almost as heavy as your Forester, be aware that the emergency handling will be severely compromised."
The purpose of the trailer brakes is not only to help the car's brakes, but also to help emergency handling. For instance, without trailer brakes, applying the car's brakes causes the trailer to push on the ball, if the car is not going in a straight line, this push will force the rear end to the outside and begin a jacknife.
I noticed this only once and it scared me so I never let it happen again. One rainy day I was pulling our 2,000 boat with our Mazda pickup, and braked gently to round a tight turn on a little 2-lane road. Suddenly the braking made the trailer begin pushing the back of the truck around to the outside of the turn. To stop this I had to release the brakes and coast, so the trailer would follow the truck instead of pushing it to the side. That meant taking the turn a lot faster than was safe, out of control.
If the trailer had had brakes, the trailer brakes would have made the trailer pull on the hitch, instead of push on it. So the trailer would not have tried to keep going straight and push the back of the truck around.
What does extremely helpful mean?
The Forester is rated at 2400 lbs and the manual does not say a transmission cooler is part of that rating, like it says about trailer brakes.
With electric brakes you can control the amount of braking needed with an interior-mounted electronic brake control, not so with surge brakes. Surge brakes are really not very good.
Bob
And they do indeed "help" but you still have to be aware that you're towing a trailer and modify your driving accordingly.
He has a previous generation Forester that is only rated to tow 2000 lbs so if he's gonig to be towing a significant distance then I think a transmission cooler would be a good idea.
-Frank
On surge brakes, it depends on the application. I tow a 10,500lb triple axle boat trailer with my Armada and it has surge brakes w/discs on it and it does pretty well with the surge brakes. There are 2 reasons to get surge brakes on a trailer, mostly if it's a boat trailer you would have surge brakes due to the electric brake components getting wrecked in the water, the other reason would be if you lend your trailer out to various friends who probably don't have controllers.
I would say though Electric over Hydrolic > Electric > Surge > No Brakes.
-mike
Only in terms of traction. Maybe not so important with an RV trailer. With our 2000 lb boat on a compact pickup truck, there were several ramps that I declined to use for lack of traction.
If the ramp was steep, and the water's edge was covered with mud or algae, then the tires would spin on pull out. If the boat was pulled partly out of the water, and the tires were spinning with no hold, the boat would try to return to the water, pulling the truck back with it. By the time the boat was buoyant again and stopped pulling, the rear of the truck could be pretty deep in the water. This spinning and loss of forward motion began to happen a couple of times, and so I just avoided such ramps.
With 4WD or the Forester's AWD in 50/50 mode, this would not happen.
The new forester is out will be arriving here in Feb IIRC. Larger but powerplants will likely stay similar.
-mike
A few years? It will debut in Japan on Christmas, and here at the Detroit Auto Show next month. It should be in dealers this spring, or so the rumor goes.
But this should tickle your interest:
http://blogs.edmunds.com/Straightline/3888
Bob
Ditto. I've also got a MT XT but towing is the one exception where I think an AT makes more sense. I about burned out the clutch trying to back a loaded Uhaul trailer up a narrow driveway
-Frank
Bob
We will find out next summer.
Fred
Seems almost abusive and a terrible price to pay in terms of wear and fuel cost. The XT is not a Cummins. The XT's turbo must be designed for bursts of acceleration rather than steady towing.
That was one of the reasons I chose the NA automatic LL Bean for towing.
The automatics are not normally very fuel efficient in my experience. We have several friends with AT non-turbo Foresters and we get better mileage under normal circumstances. The tow-load rating is lower for the automatics as well.
I can't afford nor do I want a Cummins or any other diesel truck. The engines alone cost several thousands extra on top of the vehicles which tend to be in the $35-45,000 range. They are, of course, much more durable but the maintenance is rather high on them when it is done properly. We drove a diesel car in Europe and it would be just fine for us but the few manufacturers that offer passenger car diesels in the U.S. are not on my shopping list. That may change.
Subaru offers diesels overseas, but not here. If they start offering them here, I might consider buying one. They certainly are good for towing.
Thank you for your concern,
Fred
Where do you find this? The 2008 brochure says 2400 lbs for any and all, regardless of engine or transmission.
Sorry for the delay. We just got back in town. The owner's manual, I believe, has different figures for the two transmissions. I will check it again when I get some sleep to make sure.
Fred
Not exactly. See page 8-19.
The figures are the same for the two transmissions.
Except, for the AT, the 2400 lbs is reduced to 1000 lbs when towing a trailer on a long uphill grade continuously for over 5 miles with an outside temperature of 104F or above.
-Frank
Bob
See if you can lighten it up as much as possible, perhaps by loading the gear inside the cargo area of the car instead of under the seat of the jet skis.
I towed with my 98 (also over that 1000 lb limit) and noticed braking distances were a lot greater. Still, I managed OK, taking is easy. No harm to the Forester, which was reliable for the 9 years I had it, until I sold it.
The car will be fine. You will only be as fine as your driving care. I towed a 2000-lb boat for many years, without trailer brakes, never feeling the need for them, or knowing what they were for.
Until one rainy day I entered an unexpectedly sharp turn on a rural road at 45 mph, felt it was too fast, and applied the brakes as I entered. The trailer being at an angle to the car in the turn, it began to push the rear and of the car around. I had to get off the brakes and roll around the turn without slowing. After that I was very aware of what side-force on my hitch could do.
You will be fine, as long as you don't brake too hard in the middle of a turn or have to do a panic stop. In a panic stop, you expect to not stop as fast as a bare car, but what you don't expect is that with the slightest deviation from a straight line stop, the trailer can push the rear end of the car to the side and then jack knife it, instantly.
This will be our first really long trip and it's a shakedown for an even longer trip to upstate New York in July. I may be able to get the new suspension, battery and its isolator in by then.
Good luck on the trailer brakes. Fortunately, our little T@B trailer at least has inertia brakes and they have worked well so far.
I'm going out to pick up our trailer from its storage on the 19th and we're leaving on the 23rd. Wish us luck, please.
Fred
Check out the Odessey PC680 and tray kit from PPI:
http://www.paradigmperformance.net/products/forester/batt.html
Specs on the Odessey:
http://www.odysseybatteries.com/battery/pc680.htm
Did you look at the coil overs for the Forester?
Fred
-mike
Waaaay upstate in New York. We will be at Clark Point, NY which is on the northeast shore of Lake Ontario. It's north and west of Syracuse about 50 miles. My wife is from Watertown which is another 25-30 miles north. We'll be there from 7/17 to around 7/21 or so then back down to I-80 and on back to Colorado.
Where are you?
Fred
Has anyone had this problem? I hate to take it to the dealer because it's one of those things that's practically impossible to demonstrate around here.
Fred
Forget that, where do you live? I'm moving there!
I think the cruise control ceases to work over about 85 mph, by design.
As far as the speed control ceasing to work above 85, that isn't true. I've used it at over 90MPH for just a couple of miles and it always worked fine until recently. The true problem was that, eventually, the maintainable speed would drop to the point where I couldn't keep up the speed limit. It did that on one trip back from Arizona. It got as low as 65-70 before it improved.
On one of the other Forester forums they seem to have isolated the cause as a bad neutral safety switch on the manual transmission models. I will be looking into that as it is supposedly easy to diagnose. You just push the gear lever a bit tighter against its limit stop and the cutting out problem goes away if it is the switch. Isn't the internet great? Some of those forum contributors have found that their speed control will work to up around 95MPH. I hadn't gotten to that extreme, personally.
Fred
On the cruise it will cutout on subies at 92mph. Same on my nissans.
-mike
92MPH = 150KPH Makes a nice round number so that makes sense. I just want it to maintain at a mere 80MPH. We have lots of 75MPH speed limits out here in the west and the pickup trucks tend to run at 85MPH. However, when we tow the trailer, we run right around 70MPH as the MPG drops fast above that speed.
Fred
-mike
Unfortunately the switch has to be replaced from under the car. I may try to replace it down there as we will have some down time once we arrive.
We're having another one of our blizzards of 2008 again so we are soooo looking forward to getting down there in the warmth.
Fred
-Frank
Fred
-mike
Fred
You may have lost a teeny-tiny bit in terms of departure angle, but no ground clearance at all.
I likely will not tow more than a couple times a year, but I also wanted the hitch to replace the hokey screw-in eye hook for vehicle recovery. I don't know that I would trust the integrity of a class II hitch receiver when using it to pull vehicles out of ditches....
There was no damage at all in the end.
