Honda CR-V Security System Alarm
I just purchased a 2007 CRV EX L. I added two options (remote keyless startup and an alarm). The EX L already comes with an alarm. However, my salesperson insists that it's a basic system. basic. In fact, it only works if someone tries to enter through the doors. The alarm they are adding for an additional $500 will go off if someone breaks the windows or attempts to tow the car.
Is it worth it for me to pay the additonal $500 when my car already comes with a basic alarm?
1
But I believe (more knowledgeable people may correct me) that newer cars are becoming more difficult to steal. That difficulty now deters at least the casual car thief of old. Nothing will deter a professional.
The CR-V has had the accident shut off since (at least) Gen 2.
Are you sure about that? Maybe it is dealer installed system?
AFAIK, CR-Vs come with keyless entry, but not Security system in the US.
You are right, that is probably what they mean by the security system. It is not an alarm for sure... Thank god. Can't imagine all of CR-Vs have the alarm and all of them going off each time a diesel truck passes by.
Also, I could not find information about what exactly 'security system' in EX model provides and what is different compared to LX.
Haris
P.S
I just registered and I apologize if this question appears twice
Haris
The CR-V already comes with immobilizer (disables the engine) from the factory. There is no need to add alarm to get this function.
In the past, OEM alarm added the horn activation when it was triggered. It takes about 30 minutes to install, as it is a complete "plug and play." It may take novice an hour max to install following Honda instructions.
Are the keys on the same keyring?
If so, Read The Fine Manual. The answer is there.
Twomotor
I bought a used HONDA CRV 2006 and installed an AFTERMARKET ROCKLEDGE SECURITIES ALARM SYSTEM.
My previous issue that I spent days figuring out, was that I forgot to turn off the headlights on my car, and when the battery ran out, we COULDN'T RECHARGE the car because the ALARM SYSTEM WOULD SOUND, and the car was unchargeable. Eventually I had to REMOVE THE HORN FUSE, and FINALLY PUT IT BACK in the fuse box in the hood of the car. And press a button on the inside of the car by the driver's side to get the alarm system to stop sounding.
I have since resolved that problem.
My current problem that is driving me crazy is that I pulled my car into my driveway one day and all of a sudden the CRAZY ROCKLEDGE ALARM SYSTEM WONT STOP GOING OFF AS SOON AS I TURN OFF THE ENGINE. THE ONLY THING THAT FINALLY STOPPED THE NOISE WAS GOING INTO THE FUSE BOX IN THE HOOD OF THE CAR AND REMOVING THE HORN FUSE.
HERE'S THE PROBLEM THOUGH -- W/OUT the HORN FUSE, there is no noise and the alarm doesn't go off. HOWEVER, W/OUT THE HORN FUSE, the car WON"T START. Then WHEN I TRIED PUTTING the HORN FUSE BACK into the MAIN FUSE BOX so the car will work, the CRAZY ALARM GOES OFF AGAIN.
My Car currently is W/OUT THE FUSE so the crazy alarm doesn't sound. But the Car won't start w/out the fuse either. Can't drive it. School starts Tuesday. I worked on it for days today.
If you have HONDA CRV or ROCKLEDGE SECURITIES EXPERIENCE, PLEASE PLEASE PLEASE HELP!!
Mary
Since the factory does not recommend any additional security system, so now I make door lock cylinder “blinded” with a thin sheet of stainless steel. Simply I do not want anyone to get into my car. Remember, once they interrupt the ignition, the car will be immobilized, and left a much bigger problem. Hope this post is useful for this discussion..
