Honda Accord Cabin Air Filter
can someone tell me how to change the cabin air filter in my SE V-6,or provide a link on how to do it? Belive it or not the manual doesn't even mention it.
Your cabin air filter is behind the glove box.Pop the glove box down and you will see the access cover for the cabin air filter
This is pretty narrow so you may want to look in the Maint. & Repair tread... which is probably where this should be posted anyway.
Here is a link to changing the cabin air filter. I have an SE 4 cyl. so item one does not apply to me, or honda changed this item on the 2007 model year. After you drop the glove box. look for the words "air flow" and arrows pointing downward. This is the filter frame. There is a tab at each end of the frame, press both tabs and pull the assemby out. The filter fits inside of the frame and turning the whole frame upside down will remove the filter.
Total repair time: 5 minutes. Tools needed: none
http://www.micronair.us/assets/pdfs/85.pdf
The 2007 owners manual only has 284 pages plus an index. There is reference to the dust and pollen filter on page 225. It says in part: Have your dealer replace the filter when this service is indicated by a maintenance message on the info display. Good message, much better than the instructions I found. I'm starting to get this feeling that the dealership wants to do minor repairs.
Yahoo!!!!! Thanks so much for the picture links as they are the same for my 07'accord. Note though that the plastic glove box stop PUSHES toward the engine compartment,not away as in one photo, to drop the glove box door. At any rate, i was able to find and, R&R the filter in about 5 minutes! I really appreciate you taking to the time to help me.
grampy1
It's all good, grampy
That's fine with me, if you're not exceeding the owner's manual recommendations. Since my 03 V6 is driven mostly short trips (less than 5 miles/ severe conditions) I change my oil every 3,000 miles (which is only 750 miles less than the recommendation in the owner's manual). The oil seems to get dirty quickly in this engine, so the oil is a dark brown already at 3,000 miles. Since I change the oil myself, it doesn't cost me that much.
However accessing that cabin air filter is not easy. It is at least an hour long job for most folks. It entails removing the the whole glove box area of dashboard apart.
Not only are removing the glove box itself but also the crash pad and trim pieces under nearth the glove box too Along with several metal reinforcement bars in the dash. All told one removes about 15-20 screws to get to it.
:sick:
