Buick Enclave Transmission Questions
I test drove an Enclave yesterday. When utilizing the +/- button to shift manually, there was an annoying delay between when the button was pushed, when the dash indicated the switched gear, and worse, when the tranny responded. This is a deal killer for me, because I was hoping to use it to build torque for passing, etc.
How has it worked for others? Is it something one can get used to, or is it chronically irritating to power-lovers like me?
Audi Q7
MDX
CX-9
Enclave
We are now down to:
Enclave, CX-9
I have driven an Enclave three times now and I really like the manumatic mode. I have had no issues with it and find it quire able to negotiate quick down shifts when you want to execute a lane change and go around a car quicly. I have used it to downshift 1,2 or 3 gears all at once with varying amounts of "let's get going" gas pedal pressure.
I actually like the Enclave's manumatic mode better than the CX-9 although the CX-9's handling is very crisp. The Enclave is Verrrrry quiet and comfortable. The CX-9 is sportier. These are trade-offs my wife will have to decide between as it is her car.
Thx!!
Thx, Steve
i went to another dealer on friday and tested another enclave and gues what, it didn't do that.
i'm just wondering if anyone else has the same problem, or had the same problem. i had the transmission reprogrammed about 2 months ago.
I can live with the transmission in town, but driving uphill on the interstate and keeping your speed up is a problem because car will not down shift on its own.
Can anyone point me to the Service Bulletin # about Re-Programming the Transmission. My dealer has never heard about the problem (small dealer)
and has no idea as to what I am talking about.
The constant shifting is driving me crazy.
Document ID: 2177083
#08-07-30-022A: Hesitation or Flat Spot Between 56-80 km/h (35-50 mph) (Reprogram Transmission Control Module) - (Aug 1, 2008)
the constant upshifts and downshifts. Milage seen to be down about .5
but it is will worth it.
BTW: Take the Document ID # to the dealer. My dealer/Service Guys had never heard of the problem.
I am concerned about the re programming I am reading about, that it would reduce the gas mileage, but it is even more troubling that my dealer essentially says I am the first to have this problem.
This has happened about 8 times when driving it last week and this week. I pull over and let the engine idle and after a few minutes the engine trouble light goes out and the message disappears. The outside temperature is about 105 degrees F and I am not able to use the air conditioning otherwise the temperature continues to rise. Now periodically when the transmission shifts, after accelerating there is a very strong jerking of the car. My vehicle is suppose to have a tailoring package. Why and what is causing the over heating and the jerking action? :sick:
I apologize for the problems you are experiencing with your vehicle. Were you planning on having the vehicle diagnosed at a GM dealership? Please keep me posted.
Thank you,
Caron, GM Customer Service
My major concern now is why has it been overheating? I first experienced the overheating in the late summer of 2009 when pulling my trailer. If I continued to use the A/C the needle on the temperature gauge would slowly creep up to two lines above "normal" position (middle of gauge). Did not experience overheating last summer because I did not pull the trailer as much as I did in 2008 and 2009.
Any suggestions as to the cause of the overheating? Any solutions? :confuse:
deerhunter2405
Unfortunately, I am unable to diagnose the vehicle as to why it may be overheating. Have you heard anything more from the dealership? Have you been in contact with GM Customer Assistance via telephone? Please keep me posted.
Thank you,
I apologize for the problems you are experiencing with your vehicle. Glad to hear the vehicle is at the dealership. Please keep us posted on any information from the dealership.
Thank you,
i apologize for the problems you are experiencing with your vehicle. Please keep us updated on any information from the dealership.
Thank you,
On a surprisingly similar note - they indicated that the transmission in the windshield wiper motor for variable speed wipers has failed (no longer works) and will cost $300 to replace. Around 60k miles seems to be a turning point for this vehicle.
We also were having a dvd/map error, frequently preventing the navigation system from functioning. The dealer found the same error when they drove the car and apparently replaced the navigation system.
We just got the car back today. I have not driven the car yet. I am hoping the transmission computer was flashed with better software to make the transmission run more smoothly and get better than 17 mpg highway.
This vehicle only has 14,900 miles on it.
I have read through this thread, and haven't seen anything about the mode switch.
I have to question why this would fail again within 6 weeks of the last repair.
I love the vehicle, hate the transmission and all the trips to the dealer.
At this point, I don't feel confident driving anywhere long distance as it is completely unreliable.
I apologize for your frustrations. Can you please email me your complete contact information including mailing address, VIN, current mileage, and involved dealer? I would like to report your concerns to GM and set up a case for you. An agent will work with you and your dealer, as well as involve Technical Assistance as needed, to resolve your concerns. I look forward to your response.
Christina
GM Customer Service
I will email you outside of this forum with my specifics.
Honestly, I'm through with this vehicle, so I'm not sure there is anything you can do for me.
I'm heading to a Lexus or a Mercedes after I decide which vehicle will replace this enclave with only 15K miles on it as of today.
I've also got a MB E350 (in addition to an Enclave) and the MB service through the dealer network has been outstanding. Repairs will be quite a bit more expensive though - so be ready for that. Given the responses here regarding the Enclave transmission I would have expected GM to issue a note to have them checked.
I apologize for your frustrations and inconvenience. If you would email me directly I would be happy to set up a case for you with GM Customer Service. Please include your complete mailing address, VIN, current mileage, and involved dealer. I look forward to your response.
Christina
GM Customer Service
I think that the transmission is not programmed properly. Has anyone else had this problem?
I'll check our 2011 at some point to verify.
I do love my Enclave but the mechanical issues are giving me a headache: Failed water pump, replaced rack/pinion for steering noises and locked steering, emissions issues, now transmission. I haven't even addressed the issue of when we get a hard rain, it leaks into the cabin. Don't know if it's from a replaced windshield or "fix" to the sunroof.
We can look into the situation further (see if any recalls are associated to your vehicle specifically/follow up with your dealership and help work with them towards resolving this concern). Please email us with your name/user name, contact information, the last 8 of your VIN, and your involved dealership.
Best,
Sarah
GM Customer Service
Best,
Sarah
GM Customer Service
The power steering pump and water pump went out at the exact same time. There was fluid leaking in my garage. I will NEVER buy another new buick enclave. I was so pleased with it at first, that I recommended to all my family and friends. I am retracting my "love" of my car. It is still a brand new car and has had TOO many issues NOT under warranty. I cannot afford to keep throwing money at this car.
Best,
Sarah
GM Customer Service
