Hyundai Entourage Steering
I believe this is a fluke and not a chronic problem but my Entourage is getting a new steering mechanism between the steering wheel and the power steering rack. At least, that's how the dealer service person described it. The steering would hit an increase in turning force at about 1/4 to 1/2 turn in either direction and would occasionally lock up for 1-2 sec as if the pump stopped working.
The dealer folks have been very helpful and motivated to fix this since it is a safety item. I should have it back on Monday. RG
RG
RG
RG
There is a fix for the sliding door problem. The techs put a piece of vacuum tubing into the door frame to keep the doors from sliding too far forward. When the doors travel too far forward, they don't latch properly. I'm guessing this is because the rubber stops compress over time. I had it done on the passenger side and the fix seems to work. The tech who did the repair explained this to me but didn't say exactly where he put the tubing. I looked and couldn't find it - otherwise you could probably do it yourself.
RG
waiting for a part....perhaps it will be fixed by Nov 9th.
Only 7 more days after that for the Hyundai to be considered a lemon by OR law. Service and sales departments are both frustratingly incompetent.
One of the things I hate is to say, "Oh no .. you have to use the X fluid made by your car's manufacturer."
So I did more research about PSF-3. Of course there's PSF-4, the next generation of power steering after PSF-3.
Of course .. here's the Hyundai Part Number of PSF-4
Hyundai Part 00232-06010
So follow me .......
Here's the MSDS data sheets for the fluids that Hyundai uses
http://dcs.hyundaidealer.com/files/resources/msds/msds.pdf
Search for the part number of the PSF-4 = Hyundai Part 00232-06010
You'll find it .. and here's the MSDS on the PSF-4 fluid. Check out who makes PSF-4. VALVOLINE! smile.gif AH HA!!
http://dcs.hyundaidealer.com/files/resources/msds/ch67.pdf
What do you think?
Can the "off the shelf" valvoline PSF fluid work?
Anyone have the same problem? If so what was the fix??
