I have a 2003 Jeep Liberty Sport, about 74,000 miles on it. I have taken very good care and have had the scheduled maintenence done on time every time. I took a 2 hour trip last month and noticed (with my front windows down) that I hear a whistling noise. I know it's not from the back, but from the front. I don't seem to have any problems with the breaks...I stop okay and there doesn't seem to be any tension or problems pressing on the break pedal. The noise is only there when I accelerate and as long as I'm in a moving position. I guess it could sound like metal on metal. Once I stop, the noise is gone. I checked the belts and things around engine that I could. Nothing seems to be missing or cracked. I then took it on another road trip for a few hours and at one time, it seemed as though my jeep was idling different, but I can't be sure because it could have been me in panic mode. Anyways, I finally took it into the shop today and described what was going on. They test drove it and said they heard the light whistling but that they think it's the transmission noise. That some vehicles have that noise and there was nothing to worry about. Unfortunately now I think my steering wheel is vibrating a little, which I would think may be from brake issues?? Also perhaps my alignment is off at high speeds. I am frusterated because the shop tells me it's fine, but I never used to have the whistling until about a month ago. I don't drive it 4 wheeling. It's just back and forth to work mostly... Any suggestions?
You had the same problem as I. The dealer told us chrysler came out with a flash upgrade for the computer to install with the same description. The problem was so severe in my Jeep it did not fix it and now the district managers of chrysler are evaluating the vehicle after throwing a new front and rear driveshafts at it and $3000 dollars. We are now in the process of trying to get a different new one. Good Luck!
Just wondering if you ever figured what the noise was. i have a 2003 Jeep Liberty Sport that makes a whining sound whenever I have it in a moving position... Thought perhaps might be same thing...it could be more of a whistle though...
I did not have the same kind of noise. Nor am I a mechanic at all! But if I had to guess by your description I would have to say it sounds like a belt issue. As the motor speeds up so do your belts that drive it. A cheap and simple way to test that theory is to go to your local auto parts store and purchase a bottle of silicon spray. and while your car is in park lift the hood and on the inside of your moving belt spray a little on it. The bottle will come with a straw for the nib of the can just like a spray bottle of WD-40 for accuracy when spraying. Just a thought. Good Luck and let me know if you had any!
Hi littlemissy442, If you suspect a vibration in the steering at high speed plus a permanent whistle when you're moving, disconnect your alternator 'field' connector. When mine went, I could hear 'another whistle' or vibration around the engine. When you do this test turn the A/C OFF as well.
In case one or more rectifier diodes short out (inside the alternator), the alternator output will fight 'against the battery' and produce a sound you can interpretate as being a whistle
Both alternator and a/c compressor are driven by the serpentine belt, so is the power steering pump. If your belt does not rotate at a steady pace, the steering assistance will vary as well.
I bought a used 2006 Jeep Liberty in February. Overall, it has been great. We had 4 brand new tires put on in March, no word about bad brakes from the mechanic. The car makes 2 or 3 different noises that all stop when pressure to the brake is applied. 1 noise is a louder, metal screeching noise, sounds like its coming from the right rear and stops when the brake is applied. It can happen at any speed, stop randomly and start again. 1 noise is a softer metal whistling noise which also stops with the brake and I think there is even a 3rd different noise but hard to tell. We also noticed a vibrating noise when the car has been shut off for a few hours. Just noticed it while working outside, it almost sounded like a cell phone vibrating but louder. It comes every 5 minutes or so. Any help would be greatly appreciated.
I had the same problem on my 05 renegade. What you need to do is take it to a dealer or certified body shop, and have them adjust the latch that secures the gate to the vehicle when opening or closing. This should take came or the problem. I had to get mine adjusted 3 times. As i was just taking to around the block to test for the rattle. This was a common problem the dealer told me.
I have a 2005 Jeep liberty renegade. I have a rumbling noise and viberation around 70mph then it goes away and come back from around 83 up on. Does anyone have any idea as to what this could be? It seemed to start after I had the rear U-Joint replaced. So I think the U-Joint may either have a defect or is not in place correctly. Anyone else have suggestions or similar problems?
From the sounds of it, you have a similar noise to the one I have in my 2006 Jeep Liberty. I purchased mine in May '09, and after a few days of driving noticed the same piercing metal noise coming from the wheels. This only happens while the Jeep is in motion, and like yours, happens at multiple speeds, randomly starts, and stops when the brake is applied.
I have taken mine back to the dealer twice. The first time they replaced the rear rotors as they had corrosion from sitting on the lot (a fairly common problem according to a friend who is a mechanic). However, the noise returned after a few days. I have been told that the noise is a result of the metal pads and rotors used on the Liberty. However, it seemed odd to me also that the breaks would be squealing while they are not even applied!
kbeast1979. So I took the 09 liberty in and they told me the exact same thing about the flash updates and gave me some crap about the adaptive transmission? I can not drive it without getting fumed about it so it is going back tomorrow. I can at least pinpoint where the issue is this time. As soon as the tranny hits 4th (50mph), the low end has a pulsing growl, especially when a small load is put on the engine such as a slight road incline. It mostly goes away as I go faster but I can still hear it through 80mph. I would love to hear more about what Chrystler has decided to do for you because I am in the same unsatisfied boat that you were in?
Let me know, you can email me directly if you want.
mcarver82. Ok, well we weren't happy to say the least about how it was all handled. We took it in, they did the flash update, luckily she had a free car rental policy in her contract when my girlfriend purchased the car, gave her a car rental, returned the next day and they said they thought it was still doing it. She drove it and agreed. They said they wanted to leave it there and contact the Chrysler engineers to see what there thoughts were after replacing the front and rear driveshafts at this point. They had the car for 3 weeks until the 2nd representative could come out from Detroit and take a look at it just to tell us afterward that there was nothing that they were going to do about it nor would the dealer. They said that it was just something that was a characteristic of the vehicles for the 09' and 10' Liberty models. How many miles are on your vehicle? I later found out from a friend that knows someone that works at a Chrysler dealership that when that flash update occurs at the dealership the computer reads how you drive your vehicle after that point, shift more effectively and completely adjust itself at or right after 4500 miles. Hope this helps. I think we were one of the first to report it to Chrysler. So I hope that by now it has become more of a routine issue and they will know how to handle it better for you. I will say that the vehicle does not now have the issue and hopefully will remain that way. I will be keeping my fingers crossed for sure. I don't know how much of the issue was helped by the replacing of the parts that were replaced with even newer ones. (She had 3600 miles on the vehicle.) The parts were the front and rear driveshafts, and I believe the gear-box.
KBeast1979,Mine only has 950 miles on it? I did not want to drive it too much knowing what was going on with the vibrations. I got two people to ride along last night to ensure that they could pinpoint at what shiftpoint the vibrations start and stop. I at least got acceptance from the dealership that something was wrong. I'll keep you updated when I hear back probably today or tomorrow, and unfortunately they nor I have rental coverage if they decide to keep it for a while.
Do you really like the vehicle? My girlfriend absolutely loved the style and all the neat stuff on it. She is now glad, because of that, it does not do that anymore. Good luck and please keep me posted.
Oh, also you should probably have them, if they don't already, contact Chrysler on the issue and nip it in the butt ASAP! I would tell them you are aware of the issue and don't want a lot of the dealership guessing and replacing unnecessary parts in an attempt to address the issue. I would certainly hope that by now Chrysler will know what to do.
Yeah the vehicle is great, I have had a 98' Cherokee forever and this seemed to fall right in line with what we needed, just big enough but not huge, momma and new baby are happy too!
I picked the Jeep up this morning and the dealer said they can not do anything unless there is an error code or something obvious the Chryster would approve for warranty work. They said the vibration was caused by normal exhaust fucntions, I told them I wasnt an idiot and took my car back. They keep pawning it back on to me and will not follow through with the complaint. I have yet to call Chrystler but I had a few questions about the flash updates for you.
Once the flash update is completed, we must drive an additional ~4500 miles for the adaptive stuff to figure itself out? or is it total miles on the vehicle? I am hoping that when we get that many miles on the jeep it will fix itself and not have to worry about working with these people any more.
Yeah she had a 99 cherokee classic. (which she loved) And obviously felt the same way you do about the new Liberty. To answer your question I was told it was total miles on the vehicle. She now has a little over 4,000 on it and it corrected itself before the 4500 mark. I was told the flash needs a little bit to see how you drive the vehicle to know how to correct it properly. YOU MUST HAVE THE FLASH UPDATE INSTALLED FOR THAT 4500 MILE MARK TO BE VALID! The Chrysler rep had explained the vibration to us to have something to do with the gear box or ratios or something that has to do with the vehicle trying to save you gas. I would tell them now that you have found all sorts of stuff about this flash update and that you want the description of what it is for. They can provide that for you. It is an exact description of your problem. They may not know about it. And if it was a vibration in your exhaust they should be able to fix it no problem! Good Luck and keep me posted!
Doneill I am sorry I can't help you but.....I HAVE THE SAME PROBLEM with my 04 Liberty......new tires and brakes and rotors all around and it is occuring more often now. Did you ever find what the problem was?
Hi Kate32, Does your car challenge sound exactly like the one I described? If so, it's a long shot but I found out what the problem was last week! It was my rims. Apparently the owner of the car before me hit something hard enough to damage the rims. While replacing the back two tires last week, once my mechanic took the tires off of the rims, he told me the rims were damaged as if I hit something really hard. It did not make sense to him though, as my two front rims were in perfect condition. There is a crack in one of my back rims, where the tire and rim are connected, which could not be seen until the tires were taken off. As I drove my car slower, the weight of the vehicle more noticeably shifted around the rim, creating a pulsating creaking/grinding noise. The bad news... $200+ a rim. Hope this helps
Thanks for the reply but....my tires were rotated all over and even had the spare on At first I was told it was a bad tire. I got new tires and I still have the problem it hasn't done it for two days now. I got new brakes and rotors and nothing is loose.I really think it is a caliper hanging up. I am working 7 days a week and it is my only vehicle so it is hard to get it back in the garage. I guess I will have to just keep replacing parts until I find the problem. No one else ever hears the noise so I feel as though I am being blown off at times by these mechanics. I won't take it to the dealer since I've done that with other vehicles and know all to well the price tag.
Hi All - Same issue for me this week 02 Jeep Liberty w 99K - anyone have an update on the Whining Noise at start up in the cold? I have changed the belt - fluids topped - no change. Hate the fact I wake my neighbors up every morning with it....
I have a 2003 Liberty which I bought new. I have had so many problems with this vehicle. 2 motors, 3 transmissions (the 1st was replaced at 4000 miles) bearings, air conditioning problems nonstop......etc.
A couple of weeks ago I noticed a growling noise with matching vibration, during acceleration. We checked bearings and differential then changed the fluid in the transfer case because we saw that it was a dark brown color. Growling noise didn't go away. A few days after that, a medium pitched whining noise that sounds like it's coming from the tranny or transfer case area. Few days later, the transmission is slipping.
Have similair sounds from my 05 CRD that I am trying to diagnose. What was outc ome of your problem back in 08? At idle mine is quiet but it screems at higher rpms and seems to come from the rt fwd (looking fwd) area of compartment but no sound when the belt is removed and all the pulleys etc spin free and quiet by hand. Idlers were quoted at $81.00 ea so I'm trying to be cautious. Comments anyone?
I own a 2002 Liberty and recently I have noticed a noise coming from the front while braking. I had my rotors checked and they are fine. The noise is odd, not metal on metal, kind of a pulsating whine maybe, it is hard to describe. If you stop hard you don't hear it as much but if you brake slowly the noise starts.
Any thoughts on what this could be would be greatly appreciated.
I have a 2005 Jeep Liberty Renegade Edition. It has been very well cared for and just went over 100k. We had a major snow storm here in MA on Wednesday. I put it in 4 wheel drive to get through the snow and it seemed to be fine. I never use the 2 low or the 4 wheel drive. After the storm I put it back in the normal gear and now it is having a hard time reversing. I put it in reverse and sounds like it is in neutral and when I turn at very slow speeds (i.e. parking there is a grinding sound). This sound cannot be heard at any other speed. Both issues only occur occasionally and I have no clue what it could be.
At first I thought it could be stuck snow but it is not. Since I do not use the other 2 low or 4 wheel drive could this be a factor? Does anyone have any clue what is going on with it?
I've driven my eight-year-old Jeep through a lot of rough roads, and over time it started to make a sort of squeaking, swinging noise in the front wheels or axles. The noise has finally grown so loud that I want to repair it, but right now that I'm in a more humid city it is temporarily not making the noise, and a couple of mechanics who have inspected it have said nothing looks wrong just from looking at it. When I'm in Austin, TX, the noise is very defined and loud with the slightest speed bump or other pothole or hump I hit. Would anyone have any idea what it could be?
I have a 2004 Jeep Liberty with 112,000+ miles on it. When in reverse it is making a "ringing" kind of sound and also when making a left turn. I hear it once in a while while driving. What can it be? I hope nothing major, going to take it to a mechanic since I have an 1100 mile trip ahead of me. Please help and give me a heads up on this so I can give mechanic an idea what is going on? Thanks!!! :confuse:
Monotone rhythmic noise under the hood passenger side of '02 liberty. Sounds like something is rhythmically turning on and then off 5 seconds later, and then back on and then off. This continues while stopped at a stoplight or while the engine runs while in a parked position. It is not a high pitched whine or whining sound but more lower sounding monotone buzz or hum. Any idea what it could be ?
I have a 2003 liberty. I have a shuttering in my car during breaking. When I complete the stop the car seems to "reset". It is felt throughout the car and causes my arms to shake with the steering wheel. Started several months ago, then stopped with no known reason. Started again today. Then shuttering makes a loud noise that can be heard by people on the street. I know because I've gotten looks. Any ideas? Mechanic found nothing.
i have an 03 liberty sport with just over 100k on her and she recently started making a groaning/whine sound when coasting over 40 mph, it gets louder when i accelerate downhill but goes away if i accelerate uphill. im at a complete loss here. i cant afford to be carless as im starting a new job this coming week. any tips/solutions?
Our 2002 Liberty makes a crazy weird whistling noise when we go over 55. It is inconsistent and only started after we replaced the windshield. We replaced it again, thinking something was installed wrong. Still there. It actually got louder recently to the point where it is beyond annoying to drive the car now. Anyone ever hear of such a thing? I can't find any loose trim and have tried taping down different parts of the windshield. Nothing changes. The wipers don't seem to be the issue either. I'm about to drive the thing into a tree!
has any one had a problem with a klinking noise in the rear of the Jeep when you shift from 1st to 2nd.. I had a problem with my 2005 Jeep Liberty Sport.50,000 miles. I just had to replace the rear upper support arm, that goes from the top of the rear housing to the Body, three points. took care of the noise. took about three hours to replace. bought complete unit at Oreilly Auto Parts for $200.00. Dealer wanted $200 just for the center bushing.
I have a 2010 Jeep liberty with 30358 miles. The day before yesterday on 09/02/2013 It started making a sound like a stuck Carburetor plate when you step on accelerator. And when you level out on the speed you want then the noise stops. No warning lights are coming on at all. I was told it could be a bad alternator but I'm wondering how that could be. Does anyone have any ideal what's causing that?
Hi All - I have a 2012 Liberty and since day 1 have had this sound like i was driving over the "wake-up" bumps on the side of the road. Have had it in 6 or 7 times to 2 different mechanics who say they dont hear anything. Its intermittent, have noticed it more in the cold. Anyone whose ever driven with me have heard it and say they can feel it in their feet if theyre sitting in the front passenger seat. I know I read in the beginning of this forum of the same noise in another Liberty, but that was from like 2007. Any similiar issues lately?
I have a 2006 Liberty with 22,000 miles on it. In 2011 with between 11,000 and 12,000
miles on it both sides of the rear windows failed with the windows falling into the door.
I started reading Edmund's and found out about a semi secret extended warranty. My
wife took it to the dealer where she bought it. She asked the price and was told that it
would cost over $250.00 for one regulator plus labor. She left without the parts or the
labor. She called them later and asked about the extended warranty, and they said they
had not heard of it.
In the mean time my brother-in-law said he could order off the internet. We got new
regulators (Chrysler/Jeep) original equipment for $60.00 each. My nephew a ase
certified mechanic installed them fir $60,00 each. I decided to call Chrysler to see
if they had processed my paper work. They had but it wasn't good news. First he
denied me because I hadn't used jeep parts. I then asked him if he was looking at
my paper work, and he was not. I told him that if he had bothered to look he could
see that they were original Jeep parts. He conceded. His next reason for denying
me was that my Liberty was not a 2006. I told him that it was most assuredly is a
2006. My registration shows 2006 as does my title. He said that according to the vin
number my Jeep was manufactured in 2005. I then told him it was obvious they were
not going to waive the requirements. I knew when I sent off the paperwork that they
would have to bend the rules, because the Jeep warranty is 3years or 36,000 miles,
and the Jeep was 5 years old with 11,000 miles when the failures happened. No
mention was made that it was out of warranty due to the year.
I told the consumer affairs guy that he should tell his CEO and anyone else that he
could find who would listen that I would never buy another Chrysler or Jeep for as
long as I live. I also told him that I would bad mouth their products to anyone who
would listen. From here I go to FACEBOOK.
I have a 2002 liberty with 135,000 miles ...I recently noticed a tapping or knocking noise coming from rear ...you can not hear it in the engine compartment just towards the rear ... has anyone had this issue?
I have a 2012 Jeep Liberty it started making a clunking noise in the right front end. We have changed the axle and the wheel bearing and is still making the noise what else could it be
I own a 07 Liberty running with 67k miles on it. Runs good. No issues there. The issue is that lately it's been really squeaky when I turn my wheel or if I go over like a couple of bumps you can hear it squeaking. I also have noticed a audible clicking or popping sound coming from one of my tires on my driver side I'm assuming. I want to come here for some advice or what to look for before I take it to either mechanic or to the dealership so I have a clear idea what it could possibly be so that they don't try to cheat me out of anything and like add on anything. I also did get a recall notice for the Jeep not too long ago about the rear and the front maybe axles I can't remember what the recall said but it's something about excessive corrosion and they could break and I can lose control of the vehicle so I definitely need to get to the dealership to have that fixed.
I often wonder how we got here. "Here" being a place where people who may have never worked a day in a shop, have no formal training or experience, and most of all cannot drive your car and experience the sounds first hand and follow that up with actually putting it in a hoist and inspecting your vehicle end up being the authorities on judging what might be wrong with your car. If you stop and think this through I think you would realize the best anyone could do in this setting is a blind guess as to what might be going on. Imagine with that guess in hand you then go to a shop and the technician does his/her job correctly and gives you accurate information regarding what your car really needs only to have it be totally different than what someone else guessed. Tell me, how exactly would that help?
If you want to have it looked at and then come back and ask for some opinions about what was found, you still are leaving a lot of room for error and confusion again for the same reasons, things like noises really have to be observed and investigated first hand to have any measure of accuracy. But at least then you would have at least something tangeble to work from. If you really believe a shop is just out to rip you off, you are at the wrong shop. If you think that all shops and technicians are like that then you need to look closer and learn that they are not.
Still searching for a solution...
Good Luck,
kbeast1979
Thansk for the info.
I have a 05 Liberty-Sme issue- There is a Technical Service bulletin on this-
http://www.edmunds.com/maintenance/recalltsb.html?type=tsb&styleId=100002263&zip- =
Any suggestions are very much appreciated.
Thank You
Becky
Thanks for any help!
new subframe from jeep was told to be 475 for the part. they don't sell the bushings I guess. i never fixed it
i
i********
