Lincoln Town Car transmission
hi my name is michael i have a 1991 lincoln towncar with approx 150,000 miles on it. my problem is when you put the gear shifter in overdrive it will rev up to a high rpm and wont pull. but if you put it in drive it will shift to 3rd but no overdrive iam open for any help thanks michael
Check the transmission oil level & top off as needed.
We have a 1991 TC with 120,000 miles. Former owner is our landlady who took very good care of this car.
Yesterday I was driving on the hiway after a weekend of putting close to 400 miles on the car over the course of 3 days. While I was in traffic the check engine light came on and went off 3 times. After the traffic lightened up I was going about 40 mph and tried to excel but the car did not respond and I lost speed. I pulled to the side of the road and stopped the engine. Upon restarting the engine, it did drive and I continued on a lesser road for a while but when I came to a red light, I had to practically stand on the brake to get the car to slow down as the engine was racing like mad. I put the car in neutral and kept my foot on the brake but the engine continued to race. I don't know if this is important, but I did use Speed Control earlier in the day. We ended up calling a tow truck to get us home.
This morning it was fine - although I only drive one mile to work and that is obviously not a good determinator as to whether the issue will pop up again.
Someone suggested that it could be a hole in a hose.
Anybody else have any experience or information on this type of problem?
We checked the transmission fluid and it seemed fine. I am probably 2 months behind in having my oil and fluid changes which I will now do this weekend.
If coolant level is too low, the "check engine" light will come on, but that is only one of many possibilities.
You lead in: "Re: tranny slipping ", but your verbiage didn't mention a slipping tranny so while inquiring of when the MAS was replaced ask about when the transmission oil was replaced.
Some people sell a car when it needs considerable maintenance and some folk accomplish the needed maintenance so as to sell the car.
The cause for the "shutdown" and "speed-up" is a "protection mechanism" that is built into the engine (electronically) to prevet against overheating (in my case, because of a blown thermostat gasket) or low oil. This IS mentioned in the owner's manual which I FINALLY read! You know, it's like asking directions: Men don't do it, that is, until ALL ELSE fails!
When someone told you it may be a bad hose, they were correct!
After you fix the cause, you will enjoy many more miles from this fantastic vehicle!
Also, OIL IS THE CHEAPEST THING YOU CAN BUY FOR YOUR CAR !!
BUY THE BEST OIL POSSIBLE AND IT WILL KEEP YOU VERY HAPPY!!
Paul
Now - we are looking at a new sound system as ours doesn't work. Any advice on this?
L & B
Most common fault is a blown fuse which may have some other minor functions connected to it. Do you have any other minor outages such as lights someplace?
If so, you may just need a new fuse in the box under the drivers side of the dash.
on it for a long time since I had it from 2004 until now the car would drive
pretty smooth but the overdrive would always shift or change hard
now it is shiftting but only when u reach over 40 u can not rush it or try to pass
some one because it will hestiate and then later change ,
would a filter and fluid /strainer change suffice for this car or am I looking at a transmission over haul , the car is in such pristine condition I want it to drive like it did in 1988 and especially being that this march will mark its 20 yr old birthday
open for the effective economical solution
email me hglaw@ureach .com
Daryl In NC Lincoln town car lover
Daryl
hglaw@ureach.com
Due to only having 59,000 miles on the car...........
My only suggestion is to suspect you have the original transmission oil in the tranny and suggest it and the filter be replaced as well as making other adjustments.
When looking on Lincoln websites all I get is the run-around.Help! :mad:
So, why do it yourself? :confuse:
Any luck of maybe a fluid and filter change would help? And maybe another something to look for or is an overhaul in order for it? Also what is the trans. name so I could look for a rebuild kit. I have done rebuilds in past on C-4 and C-6 but many years back and my son is wanting to get his hands dirty and cut!! So this might be an opportunity for him to learn a little auto mech.
Thanks for any help from a very informative forum!!
When you change the tranny fluid remember to drain the torque converter as well. Remember to install a new filter while you're in there.
1988 Lincoln Town Car Signature Sedan, Well I had a worn out linkage gomment
that only cost ten dollars, and it was located near the top of the engine
the guy snapped it right in no time and it is shifting fine
once again thanks for all your assistance :shades:
Replace all other hoses under the hood especially the little by pass hose on top of the engine. Clean or replace the coolant lines running to the transmission. Now that the transmission fluid has been overheated, replace the fluid in it and the torque converter. While the pan is off, replace the transmission filter as well.
Is this normal for Towncar? If not, any ideas?
What concerns me is the acceleration. I'll gas it lightly and it'll take somewhat of a while to speed up. The first gear hits around 14-18 mph. Then I feel another at 26-28 mph. They are quick and you feel the pull. On my brother's 91 TC (160K miles) the gear shifts are smooth and you have to feel for them though. Also the engine's rpm (the 95 TC) will shoot up for some time before 3rd gear comes in then it levels off. Upwards 50mph+ its good. The lady claims her husband took care of it regularly. Is it wear and tear or is it something more simple? any help is appreciated. I need some wheels for work.
I took my 100K, 99 TC in for a trans tune up (Fluid, Filter and the Ford approved Valve Body upgrades) . Drove it home with the same issues, bucking and erratic shifts.
Had buddy sneak it in to The Ford Lab (ain't it great living right here by Dearborn and the Glass House?) where they put the REAL Factory 'puter on it.
#5 and #7 COP Coils were bad. Yah just 2, not the WHOLE set of 8 the dealer or ripoffs try to sell you. They checked the MFG codes on my original Coils and they were "D" = Really Early.
Replaced them with 2 new ones from NAPA @ $38 each.
I have been driving it ever since (clock shows 122K now) with NO ISSUES or complaints AT ALL.... Smooth like a TC should.
Note here: When replacing the COP Coils (#5 and #7 are almost always the culprits) make sure you clean (brake clean) off the tops (where the apoxy is poured in to seal them) of ALL your 8 coils. Spray a healthy thick wet coating of Permatex Spray-A-Gasket - Sealant (Red stuff) all over this epoxied area. Let it soak in for a few hours. When it skins over/semi dry you're all set. It will soak in and seal the gaps in the epoxy (which shrinks with age) and keep the moisture out.
Have a nice drive.
I took my 94K mile - 99 TC in for trans work with this SAME problem.
Lucky the trans shop is owned by a TRUE friend / REAL HONEST businessman. Tested all 8 with a spritz bottle of Windex. Just sprayed on top (where the epoxy seals it) of each coil.
He only replaced the 2 bad (#5 & #7) coils @ $50 each (from NAPA) installed, instead of all 8.
BTW: Its a $480+ job at the dealer for all 8. THEY don't want to just replace the 1 or 2 bad ones.
Runs smooth as silk ever since.
Note also the factory recomended trans fluid and SCREEN clean and change on a TC is 90K miles. A GOOD trans shop should also do any Ford recomended trans & valve body field upgrades out there at the same time too.
Mine didn't need them because of the trans working perfect, so they (and the fluid change) weren't done.
I'm at 124K today and still one happy smooth TC Owner.
Terry
Thanks in advance!
Am having vibration/shudder problem with my 1999 Town Car (89,000 miles) , exactly as you desribed in June, 2008. Was it a torque converter clutch problem? My independent repair shop suggests same. What was cost to repair? Thanks.
This is the first time I have owned a Lincoln so I am not sure what to expect. Is there any of you that can save me a buck by enlightening me as to what to watch for driving this model and year .. so far it the nicest ride I have owned !
Recommend Mobil 1 for the engine. If you just got the car, check all fluids for quality and quantity. The engine coolant will need to be replaced now if it hasn't been. Air filter?
