2008 Mazda CX-9
Unless, of course, the trip computer is an entirely different chip that we don't have here, which Mazda might offer at a reasonably inflated price in the future.
It's called a ScanGauge II and you can read about it here;
www.scangauge.com
It can do all sorts of things but the menus take a little getting used to. It's small, easy to install (took me less than 10 minutes) and can provide some useful information about your gas mileage, engine performance, etc. You can also easily use it on more that 1 vehicle - it just takes a minute or two to communicate and 'learn' the new vehicle it is connected to.
It plugs into the OBD II connector which is under the dash, just to the side of the steering column. Plug it in, and it's ready to program....and by program, I mean, tell it which 'units of measurement' you are using, engine size, gas tank size, and fuel type. Quick and very simple. You can even change the background color to better match your dash lighting - something I keep forgetting to do.
The computer gets its power from the same cable connection to the OBD connector, so there's nothing else to plug in. It comes with some Velcro for mounting it. I mounted mine centered on the front edge of my dashboard. It only blocks the odometer and tripmeter, which I can still see but I have to look over it.
It can easily unplug and store somewhere if you're concerned about theft. I plan to have my wife sew a little black cover for it. I think if she can make something, it will become just about invisible with the dark background of the dashboard.
It lists for $169.95 from the company's website, but I bought mine at Amazon for $159.95 with shipping. If you like 'gadgets' and have some extra money for a non-essential purchase, you'll probably enjoy having the computer.
Hope that helps!
And No, there is nobody else who drives my car except my wife who has driven it maybe a total of 4 times, tops. And we have no kids that would be playing in the car.
I'd be curious if anyone else is experiencing this same condition.
If so, maybe it has remembered a position that isn't the one you want to be using.
There must be some way to reprogram it, if that is the case.
I've got the 'dumb' key... on my 'Sport' model.
But thanks for the reply/thought, it just isn't the cause of this issue in my case.
Hmmm...interesting, thanks!
Because I typically fill-up nearly every day that I use the vehicle and always at the end of the day, I wonder if perhaps that is what is happening here. I'll have to be more aware of the seat before and after I fill-up.
Speaking of the fuel fill release door.....boy, I don't know about the rest of you, but I can barely get my hand between the door and the seat to pop it. If I have a coat on, I have to open the door to get to it. I'd be more bothered by it if I lived in NJ, but 'self-serve' is about all you can find around New England/NY, so I have to open the door to get out anyway. Folks in NJ get their gas pumped for them, don't freeze their butts off in the cold, and pay less than I do! Yes, I'm jealous!!
The radio goes on, but the climate control is completely off. Any idea on what to do?
http://www.finishlineperformance.com/pdf/cx-9/bulletin/01-046-08-1963.pdf
I had a local tire shop put on new tires because the belts were exposed on the old ones. I tried Goodyear this time. I had them preform an alignment (recommended by Mazda) Before the new alignment there test showed there were alignment issues with all four wheels. It does not pull on the rural roads and the pulling on the highway is better but still exists. We'll see how it does in a few thousand miles.
Let's hope Mazda realizes this is a dangerous issue and steps up to fix it.
