Hyundai Entourage Battery Drain
I purchased a new 2007 Entourage in September 07. It has left
me stranded with a dead battery 5 times. The dealership and
another shop say my battery is good. I turned off the electric
doors, and the interior lights. My latest test seems to indicate
that if I leave the rear hatch open (all lights off) it drains the
battery in less than an hour.
Is anyone else having similar problems or found a solution?
It is getting very annoying....has anyone found a dealership or mechanic that can fix this???
I'm taking it in again tomorrow for the 4th time. I've told them there is a parasitic drain on this darn thing and they need to have it fixed. I love the van but I can't have a car that I cannot rely on, especially having a small child and another on the way.
I'm frustrated that the service people at my local dealership seem to be unaware of all the tsb's out on this thing.
Has anyone had any sort of resolution to this problem?
I should of towed it in dead instead of jumping it and driving it in.
They are also investigating the strut/creaking noise issue that occurs whenever you are not driving on a flat surface. They are going to keep working on the car and hopefully that will also be resolved soon. :sick:
We have a 2007 entourage..bought may 2006..currently 13900 miles. On Jan22, 08..it wouldn't start at the mall. Called Roadside assistance to jump start battery. THEN....Feb. 1st..wouldn't start at home. Called Roadside assistance to come have the battery started again. Drove it to my hyundai dealer (I go to Brad Benson in NJ) and they changed battery...the IPM (as per the TSB) and the junction box (is that the same thing as the IPM? I am car illiterate). Then..the other day..on June 25th...DIDN"T START!!! This time Roadside assistance charged me 59 dollars because apparently only 2 free services a year! I can't find that written anywhere. So..back to the dealer..very upset...because the other thing is ... the sliding doors on one side creak and cringe when trying to engage like they are misaligned. They couldn't find anything wrong with the battery but I was mad..I have two young kids and planning a trip to Toronto (an 8 hour drive) in 10 days. SO...they are willing to look at it thoroughly next week and give me a loaner.
What should I get them to check? THe mechanic that jump started the vehicle the third time insisted that the battery wasn't changed...it looked like the manufacturer's battery. I don't want to think the dealer "lied" on the service forms. I never asked to see the old parts.
I don't know if it is the same problem again..or if there is some kind of parasitic drain on the battery that perhaps is caused by my door problems (which is on and off since the time we got our van). I've read of a parasitic drain problem from someone else on here and in regards to the Sedona as well.
I want to make sure they get to the bottom of this..and I might request my 59 dollars from the dealer as well.
Has anyone had similar problems? THAT IS....the passenger door problem AND the battery not starting EVEN after changing the IPM ?
Carla
You know this may sound a bit nutty but if worse comes to worse and you need to take your trip before they can figure it out bring a little socket with you, I believe 10mm but check, and if you need to park the car for a long while pop the hood and disconnect the negative. This will reset your radio stations but at least you can stop the parasitic drain until they figure it out. Hope this helps
The mechanic is waiting for Hyundai for the go ahead to fix what he thinks is the problem with the sliding doors often seen.
Dealership called and said it was the ICM junction box fuse. So now it's back on the road and I'm keeping my fingers crossed that this is the answer this time. As much as I love the interior of the van and the features, this will be the last Hyundai that I ever buy. I just can't have a car that is not dependable especially when I have small children that I tote around.
America's best warranty is needed for sure with this vehicle, too bad you can't have it towed more than twice with roadside assistance even when it's their vehicles problem again and again. :mad:
I almost blew a gasket when Roadside Assistance told me they would only pay 2 tows in one year. I brought that up with my dealer and they too were shocked...so they gave us a free oil change for our next visit.
I like my dealer and I am trying not to blame them specifically for my issues.
When I pulled the fuse for the audio system, my battery stopped draining. MPG went back up too. I'm now researching a replacement . . .
IF THE IGNITION KEY IS TURNED OFF WITHIN 30 SECONDS AFTER OPERATING THE POWER TAILGATE, THE INSTRUMENT PANEL MODULE (IPM) MAY STILL REMAIN ENERGIZED.
The energized IPM will drain the battery reasonably quickly - a couple of hours or overnight. This will also contribute to poor gas mileage because a lot of engine energy goes into recharging the battery. When it happens on my van, city mpg goes from 18 to 15.
