If anyone happens to know, I also have intermittent problems with the auto doors (3 beeps when the door closes) and I wish the transmission wouldn't upshift so soon as we live in a hilly area and the lower end is preferable. I have had the car shift into 5th gear below 45 mph!
http://www.kiatechinfo.com/TechInfo/KMATSB/board_view.asp?docu_no=331&page=
TSB No. KT2007030802
This bulletin provides a repair procedure for fuel pump noise, which may occur on some 2006 Sedona (VQ) vehicles with a production date earlier than 10/19/2006.
Some 2006MY Sedona (VQ) vehicles may exhibit a humming / buzzing noise or vibration from the fuel pump or fuel tank area. To address this condition, secure the fuel pump return line to the fuel pump housing as outlined in the following instructions.
I have the exact same problem and it sounds like the air being let out of a balloon slowly. Its not the radio or luggage rack.. I think it might be coming in from the firewall or something. Looking forward to the noise throughout our roadtrip vacation.
--douglas.wekell@us.army.mil
Our problem has not been consistent enough and could be a gas cap (i hope). It is very strange the two times this hesitation has occurred is on the same hill but approximatley 15,000 miles apart and 1.5 years, that's why the gas cap seems unlikely. Also, the way the van started right back up after sitting a minute leads me to believe the computer reset itself and corrected the problem, but my real concern is that it will cause the van to stall and lose power steering and brakes with my 1 and 3 year children in it!!! That is unacceptable Kia
In my case the awful squeaking was coming from both panels covering rear wheels inside the car. After spending hours in the back of the van while my wife was driving it (and laughing at me...) I finally found the source of these annoying noises.
I inserted padding between the plastic and the steel body at 2 places and the noise has (finally) dissapeared.
location 1 approx 2" behind the place where the 3rd row seat belt is attached (passenger side) close to the floor (it is possible to insert the padding thru the seat belt hole when the bolt is removed)
location 2 appox 6 inches ahead the place where the 3rd row seat belt is attached
(driver side) close to the floor (an access trap make this easy)
I TOO WAS EMBARRASSED TO HAVE PEOPLE IN MY CAR..It sounded like a chalkboard being scratched.
I have also had the ignition switch changed, both headlights and a turn signal. I have 36000 on it now.
Anyway, I should have bought an Odyssey for 50.00 more a month.
Concerning the Odyssey... Before this Kia I was driving a Odyssey 2004 (and before that an Accord for 11yrs and I put 300K+ miles on it so I was a fan of Honda products) and this product (Odyssey) has his share of problems too. Awful squeak from the dashboard after 2 years. At 50K miles their was a lot of clunks coming from the front suspension. My sister purchased the same product (Odyssey 2004) and it unbelievable the number of problems (some quite serious) she experienced with it (to a point that she would never buy an Honda anymore)
Finally in my case the price difference was much more than 50$/months (for a comparable equipped car (my Sedona is fully loaded w leather) it was more
like 200$/month
My opinion is that the Kia Sedona is a good van and a good value but unfortunately some detail would need more attention Now that the squeaking noise is gone I pretty happy with my choice and I am 200$ richer every month
Good luck!
sounds like rear bushes but mine was the rear hatch squeaking.
dealer sorted it out.
now if they can only fix the pull to the left................................ (all standard stuff tried)
a similar problem. Had to do with a misssligned plate above the spring or something similar to that.
burt024.. you might try replacing front sway bar end-links. I had a similar issue with my 06 Sedona.. althought it was more like a rattling/clunking issue over bumps on front left. It's a easy fix and not too expensive. Just make sure you jack up both sides of the van to the same level to replace them. And I recommend replacing both sides at the same time.
Hope that helps.
