Mazda CX-9 Audio, iPod, Bluetooth, MP3, AUX questions
denyrunner
Member Posts: 5
in Mazda
When I plug my MP3 into the aux port in the center console, I only get a single channel. I have changed cords and I either get one channel or the other depending on the cord. Does anyone know why or do I need to purchase a certain cord to satify the aux input port?
Steve
I noticed the sound weak and then figured out the sub-woofer was not working. Then found the sub was unplugged. I had to take the back floor panel out (easy) and plugged the sub in. Plugging the sub in enabled the AUX jack to work.
Looking closely in the console area where the input jack is located there is a sticker that says: "Due to the installation of Satellite radio on this vehicle, the Auxiliary jack is disabled. To activate the auxiliary jack, part number TD13-79-CFZ (switching box) can be installed. Please see your Mazda dealer for further information”. OK, so I go back to the dealership and they say they can order the part and install it for around $175.00 but cannot guarantee it will work because Mazda tech support says it won’t.
Is there anyone who has been able to get the auxiliary input to work along with the navigation/satellite radio options?
Hope that helps
Paul
Thanks for the info. Because you said it worked I ordered one and had it installed yesterday (03/16/07). It works great. Doesn't play video but does play my music. :shades:
I'm wondering if the iPod module would now work? The switch box is great but if the module worked it would charge the ipod as well as play it. And I would bet it would display the ipod info on the nav screen.
If anyone tries it let me know.
Take a look at the first post of this thread. I had the switch box installed by my local dealer.
If you have nav and sat radio, the aux jack only works if you install switch box. If you install switch box, can you also install iPod integration module? The integration module would allow you to control iPod through steering wheel controls and would also charge the iPod.
We recently looked at a Mazda CX9. Salesman said there was a mini-jack connection between the driver and passenger seat to connect my iPod. It seemed to work okay, but I was hoping that, in a new $40,000 vehicle, that I would be able to connect to the 30-pin connection at the bottom of my iPod - so that it could be charged, and I was also hoping that that I could use the audio controls in the vehicle to skip between sounds (instead of having to mess with my iPod while driving).
The salesman said there was no option for this. But today I received the CX9 brochure that I ordered from the Mazda website, and it has a sectiom that talks about an Apple iPod Integration Module. It shows an iPod with a cable being connected to the 30-pin interface.
Does anyone have this feature? Is it a factory option? Dealer add-on? Can you use the steering wheel controls to skip thru songs?
Any info that anyoen can suplpy would be appreciated. Thanks!
"Switching box - Required
when auxilary console input
and iPod Integration Module,
PhatNoise or SIRIUS are
installed"
Thanks. Just so I am clear...with the iPod Integration module, are you able to beform some basic functions, like skip to the next song, from the controls on the radio and/or steering while?
http://www.apple.com/pr/library/2006/aug/03ipod.html
-c92
Does anyone know if it is possible to unlock access to non North American region codes (eg. Play discs that aren't region 1). We have just moved to the US from the UK and my son's favorite DVDs are encoded for the UK.
Failing knowing how to unlock the DVD regions, does anyone know the OEM manufacturer / model of the DVD unit?
Marinmazdasubaru@yahoo.com
I had already turned of the beep on the nav system but never knew how to do it with the audio system. YOU JUST MADE MY DAY
Some current owners, please comment.
I'm looking for the one in Sport model, but welcome responses with a 6-CD changer or other premium audio options as well.
I cannot find the owner's manual on their website so far. I found the Complete Features and Specs page, but that has only the following information:
Standard:
AM/FM Radio with CD and 6 speaker sound system
Package:
AM/FM radio with CD changer and 10 speaker Bose® sound system with Centerpoint® and surround sound
AM/FM Radio with CD changer, 11 speaker Bose sound system, 9" DVD rear seat entertainment system with
Centerpoint and 5.1 surround sound
Dealer Installed Accessory:
In dash 6-disc CDMP/3 changer (modular audio)
Let me know if you find the user's manual. I will continue searching on google/yahoo to see if I can find some external link there.
SUVs and Smart Shopper
I can’t answer your question directly because you have the entertainment system and I don't, you may have to take a gamble on it like I did and just tell them to do it.
What I’m waiting for is for someone to try the Ipod module along with the switch box. It would be great if I didn’t have to remember to turn the Ipod off every time I get out of the car.
Thanks in advance! You might have made my week!
I am about to buy a CX9 Grand Touring with Nav / RSE and Sirius. I will have the dealer install the switchbox. Two questions:
If the dealer gives me grief on the switchbox install, has anyone installed it themselves? I am not afraid of cracking open the dash, have done it quite a bit before.
Has anyone gotten the iPod module to work with Nav, Sirius and the Switchbox?
