Hyundai Santa Fe Engine Problems
Hi!
Hoping someone may help me with this.
My SUV has had hesitation at about 45mph. Today, @45mph my car starting lurching & check engine light came on. As I slowed down, the lurching stopped and the light went out. I parked my car & will have it towed to the shop in the morning. Any idea, is this something major? It has 104000 miles on it.
Thanks for all your help!
maybe o2 sensor problem
what state are you in? maybe i can help for less $$$ !
In FL.
I'm just hoping it's nothing too major.
should the 2.7 liter V6 be replaced by this engine Yes or no?
The 2.4 in my opinion has great advantages like timing chain, plus better fuel economy, easier to maintain.
Here is what I would like to see:
Fact: the next coupe will have 2.0L turbo four (rumored around 223hp) and 3.8L V6 (300hp+) (2.7L V6 removed)
Speculation: the Tuscon redesign should come with 4 cylinder only (2.7L V6 removed)
Speculation: I know Santa Fe's 2.7L V6 is there mainly to keep the price low but I think Hyundai should offer only the 3.3L V6 on the SF.
300hp is nice on the 6 tho'!
I can see the coupe with V8 but why when the V6 produces upwards in the 300hp range. Hyundai could, however, with 400hp output in the coupe :-)
On August 20.2010 with 4222 miles on the odometer The Hyundai Technician diagnosed "main bearing failure" need to replace "short block".
As of today September 6.2010 I'm still without my Santa Fe.
I've contacted the Hyundai Corp. for a replacement engine to no avail.
Has anyone experienced engine problems on the new 2010 3.6L engine?
Thank you,
Can anybody help?
Chalie C
It has 191000 and no the timing belt hasn't been changed. Compression test was done on the 3 right side cylinders and their all pushing 120. No noise when starter is engaged trying to turn over engine, so I don't think valves were bent. Fuel & spark are getting to plugs. Gone to try the crank sensor next, even though they didn't get that error code. Do you know where that is located on the 2.7 Delta?
The first time, I was driving on the expressway at 65 mph and suddenly I lost the ability to accelerate. I would push down on the accelerator, the RPM dial would increase, but the car would not accelerate and started slowing down gradually until I pulled off to the side of the road. 3 lights came on -- The ESC (Electronic Stability Control) and Check Engine (Malfunction Indicator Light) had a steady light. The AWD System Warning Light flashed. I pulled off to the side of the road. Shut off the car, and then restarted it without problems. The check engine light stayed on, but the other lights went out. The next morning I took the car into my local mechanic (the check engine light was on as I drove it there) and of course by the time they looked at it, the check engine light was off. They kept the car for a couple of days, test drove it several times and couldn't reproduce the problem.
The 2nd incident occurred about 3 weeks later...same scenario except that I was driving about 40 mph at the time. The check engine light stayed on when I used the car a couple of times over about a 16 hour period, but then went off. I'm taking it to a local dealer this weekend for them to check it out.
Has anyone else experienced this, or have any suggestions of what to look for?
Thank you,
But it currently has a problem, in high traffic at speeds between 30-40 MPH the car does not seem to want to switch gears, it gets noisy as though it stays in third gear. Then it decides at around 2300 RPM that it needs to switch gears and acts fine. But again I am in traffic and as I slow down again, it fights to get back into gear. The first thing I did was try to manually shift it in traffic and the gears worked fine.
I took it to Hyundai today, I could not replicate the issue of course, with the tech in the passanger seat, but he did tell me my tires are out of round. Duh!!! I aint buying new tires again, these are only 2 1/2 years old, and they aint cheap.
Anyway they put it on the scan machine and they saw an active code for the Throttle position sensor, when I asked if it was covered under the 100k mile warranty they said no?????? It's part of the drive train come on.
Well I had also purchased the extended warranty and they had called Hyundai up to make sure it was covered like. I have the highest end warranty you can get it better be covered. Of course they want me to pay 100 bucks for the copay. I dont think I should pay anything.
I checked online and bad Throttle position sensors are common with these models. Anyway why wouldnt this be covered on the 10 year\100k warranty in the first place. I havent gotten the car back but will let you know if it fixed it or caused more issues. I want this think checked over good since its close to 100k now.
Hyundai replaced gasket and alternator under warranty. Had to get new battery under Sams Club warranty.
I think this problem may be more common then you think, so check for leaks, perhaps check the torque on those bolts.
I looked at the alternator and it looks to have oil on it.If the valve cover leak caused the problem then that tells me they are not doing a good job at fixing the leaky gasket. The value cover gaskets have been replaced twice on the truck both at no charge.
Does a bad alternator kill a battery? or does the battery kill the alternator?
I really need a solution to this problem this shouldn't happen 2 years later.
I really thinking of selling it and going back to a Chevy product!!!!!
I am from saudi arabia and I am facing the same issue , I sent my car to Hyundai dealer , I came to know that according to them that hyundai aware of this issue, to me it is been three years of frustration this issue and more like ESP and The 4WD are never solved not even with the new recall (replacing the break switch ).
