Lincoln LS miss at idle - low speed
I have a 2001 Lincoln LS. It has a miss or tumble at low speed idle. Otherwise, it runs great.
All suggestions welcome.
Thanks, but the check engine light never went on. Will a scan still show which cylinder has the bad coil?
BTW it's a 3.9 v8
Now I've noticed an intermittent miss at idle and had a check engine light for a couple days then it went out. If it is just a coil going bad it appears to be a fairly easy fix to remove the center cover on the valve covers and replace it. In doing that is there any hidden pitfalls like bolts holding the coils leaking into the spark plug well? If oil is found in the spark plug well does the valve cover need to be repaced again? Thanks
