The donut is $7.95 at autozone. It's the exhaust flange seal, if I have my parts straight. You could also have leakage at a crack in the manifold that's bolted onto the motor if it's been damaged. Listening while the motor is running under load will let you locate the source of the sound while the hood's up and someone gently brakes and gives the motor some gas.
I'm not sure why the vacuum brake booster that helps the pedal push the master cylinder needed to be replaced. I can accept that the master cylinder needed replacement.
The proportioning valve might keep the rear from getting enough brake fluid pressure
to operate the drums, but those help only very little in most stopping conditions. The fronts do most of the work because of the weight on the front wheels.
The ABS unit might be doing something wrong or not allowing pressure to flow. But I'd give that a very low possibility.
My thinking is about the recent stoplight incident. Did the pedal become hard and high like when you get in the car in the morning before you start it. Or in an open area with no other cars turn off the key to the OFF but no lock position while driving slowly and then press the brake pedal, then let up and press again. As you repeat this you'll use up the vacuum in the reservoir that was supposed to have been replaced. The brakes still work, but require lots more force to stop (like in the 40s and 50s without brake assist). See if the pedal begins to feel like during the stop attempt at the light. There might be a vacuum problem with your motor operating at lower vacuum because it's mechanically worn or with a leak in a hose to the booster from the manifold.
And a personal opinion of mine, I'd find another mechanic from a recommendation of a friend to check the car for you. I recall recently I took my newer car to have the tires rebalanced and rotated all paid for when I purchased my replacement Michelin tires. The mechanic instead took it on a test drive without permission. thendoing the the checks for other work they might do presented me an estimate for $700 to replace front rotors and pads and do rear pads all of which he showed me were supposed to be "thin as cardboard."
I replaced the front pads with quality GM ceramic and bought new rotors for the rear. His estimate for replacing parts not needed was about 3 times what it should cost. I go to another store in the chain of tire/repair stores and drive by 2 stores on the way where I'd had poor service. Some guys don't get about honesty and knowing what to do or suggesting going to the dealer and paying for analysis even if you don't get the work done.
Stopping the car is critical.
May I ask: what does that have to do with the subject matter of this particular forum?
Thbaks agaib
When my LeSabre shifts into overdrive at about 50mph, it starts missing. Now, if I downshift it manually into the next lower gear to bring up the RPM's it runs fine. Or if I gas it and get the RPM's up it's ok. Another thing I have noticed is that it does not do this when I first start driving in the morning when the engine is not up to temp yet.
Now the short answer is to never put the car in overdrive until I'm on the highway running 65mph, but that still doesn't make the car right.
Does anyone have any suggestions on what to start looking for? It's had a tuneup, the tranny has been checked, my check engine light does not come on, and there are no codes on my code reader coming up. I am at a loss.
Thanks for any ideas you can give me.
Gary
Pataskala, OH
What you're feeling may not be an engine misfire but a failed torque converter solenoid. The solenoid is supposed to lock up the torque converter, to eliminate slip and improve fuel economy. If the transmission is shifting into OD at low speed (below about 45 mph) then the engine will "lug" (run too slowly to run smoothly under load).
If the solenoid fails, it may only partially engage the lockup function, or it may engage and disengage repeatedly, creating a nasty surge and possibly a clunking noise.
Either that, or you may have a failed speed sensor in the transmission (assuming the trans is electronically controlled). If the trans isn't electronically controlled, then a vacuum leak could cause the behavior you describe.
I ran my Monte Carlo with no problems for 65k miles after the symptom first appeared, just by waiting till I was up to freeway speed to engage the overdrive. It's not an ideal solution, but it didn't create any additional problems.
But I believe you'll find your problem in spark plugs and wires. If not replaced in 4 years or 50,000 miles or so, replace with the proper AC Delco plug per the books at PepBoys, e.g, and replace the wires with a Delco AC replacement or Belden from NAPA. Don't go for fancy or sporty or racing wires in nice colors. You want OEM resistance wires.
You might make sure the wire in back isn't close to the wire for the Oxygen sensor in the exhaust pipe. Some people think the electromagnetic induction can affect the O2 readings.
Then check your coils. Use a resistance meter between coil terminals. Compare all three. Then take off each coil one at a time, put in a paper clip or pin to measure the resistance of the terminals on the primary side underneath. Compare all three. While they're off check the prongs on the contacts that stick into the coil and make sure they're clean and lube with dielectric grease just like you use on the plugs to prevent the wires from sticking to the porcelain.
My rpm metter free floats from 0-7000rpms and above, the car itself never stops running at normal rmps, never revs, nothing, but the meter is all over the charts. if i rev the engine, it will take off from where ever it happens to be and begin to read and then fall to normal areas, for instance if i rev the car and its already floated to 4000, it will jump to 6000 cause i reved it, then fall back down to 800 or so for idling. Happens while driving, while idling, anytime the car is on.
Any ideas? My one friend said its probably one or 2 of my sensors that went bad.
Any help would be greatly appreciated...Thank u
I thought the RPM gauge got its reading from the PCM (computer). I'd look for a dirty connector but first I'd suspect it's in the actual cluster assembly. I'd look for contacts there that have corroded where the cluster connects to the wiring harness. Bonneville people have some trouble with corrosion there. You might try the vibration method-hitting the cluster to try to break through any corrosion with movement enabling a fresh connection metal-to-metal. And there may be a module that interprets the signals from the PCM that's a part of the cluster. That may be failing. But I'd suspect connections first.
The other actuator is inside the programmer and extends its rod along the bottom of the box to a white plastic arm that moves a door inside for the driver air temp.
the other actuators are vacuum and they are on the driver's side of the HVAC box.
Take off the 7 screws along the bottom hinge of the glovebox. With those both out of the way you'll be able to see both and watch their actions with the key ON and when changing the settings on the dash or on passenger door.. One does passenger, one does driver. And I believe it's the bottom is driver.
There are places on an engine where gas can leak. There are connections on the flexible fuel lines at the fuel rails that holds the injectors.
There is a FPR (fuel pressure regulator) which controls the fuel pressure based on engine vacuum, sensing the demand for power from the engine. These in some cases were recalled because they could leak into the vacuum tube connected to them and let raw fuel get into the intake manifold where there usually is only air; occasionally a spark would ignite that mixture and the upper intake manifold would crack from the pressure inside.
There is raw fuel at each injector. There are o-rings around each injector (two) and these might leak with age allowing raw fuel to seep out.
Your brief description sounds like you are smelling gasoline and believe it's in the engine compartment.
You also can have fuel leak at the metal line from the gas tank which is under pressure by the right rear tire.
You also can have a fuel leak at the fuel filter in that line from the tank. The fuel filter is under the rear passenger's right foot. It's about the size of a caffeine drink can (Red Bull?). the connections there might be leaking.
At the back of the car rust is a major problem if the car doesn't get sprayed off regularly when the car gets salt underneath in the winter in the northern parts.
There
Wrong resistance is because of breaking wires in the tilt region of the steering wheel or wear on the two metal sensors that touch the contacts on the key in the lock cylinder.
If the VATS is not flashing, it might be battery connections at the double positive cables. Sometimes corrosion between them causes funny things to happen.
Had the security light been on or off at times while driving? Is it flashing now?
http://vats.likeabigdog.com/
Fred
Another issue, with a quarter tank of fuel the guage moves back and forth from full to empty to half to a quarter after we get under way then finally settles down. Another sensor??
Thanks for any help.
The pressure sensor is above the oil filter (remove oil filter). People with some undercar ability have replaced their own sensor.
The high pressure might just be when the engine is cold. Look at your pressure reading again after the engine is at operating temp.
I get a similar "high" reading when engine is cold.
Fred
I remember a black tube near the battery but don't recall what it was.
What you really need is a Helm service manual for that year Buick LeSabre.
The cover will be like this.
http://cgi.ebay.com/ebaymotors/1992-92-Buick-LeSabre-Shop-Service-Repair-Manual_- - W0QQcmdZViewItemQQhashZitem255967efacQQitemZ160413773740QQptZMotorsQ5fManualsQ5f- - Literature
I am not recommending any particular auction. I believe the manual actually is a two part set for 1993. But you are in need of a 1992. I did see one offer for an electrical manual for 1992 and that may be the other part.
Helminc.com is the official supplier and the cost will probably be $120-$135 there exclusive of shipping to UK.
Click on my user name for this post and you will see a box with my email in it. Send me a note and I'll suggest a couple of other help ideas for you.
(mine had two screws holding it). With that panel removed you can see the motor. Mine had an air hose which slips onto a pipe. Remove the back screws of the motor first as the front screw will hold the motor in place. Clean the motor as described above. When installing the motor put the rubber hose on first and the front screw, then the back two screws. Took me less than one hour.
