Nissan Altima Hybrid Real World MPG
1st full tank we got 36 true mpg and electronic gauge said 39. So that sounds about what everyone else is doing-- take about 2-3mpg off what the electronic gauge says for true mpg.
One question though, when our gas gauge and light went on and electronic gauges said only a few miles left on this tank, my wife filled up.. However the tank only took 16 gallons? That means there were still 4 gallons left.. At our mpg, that would have been another 140miles! Does everyones light go on so early??
Thanks for your help!
Short hops on local streets will return miserable mileage because the catalytic converter must warm-up using the ICE so the car won't go to EV mode except for full stops for the first 5 minutes of driving.
For the gauge to indicate better miles you need to be on trips that are at least 5-10 miles and at some fairly stable speeds, not lots of stops and starts.
We live in San Diego County and our daily commute involves about 22 miles mostly downhill and 22 miles mostly uphill. The gauge indicates 40 at the end of the downhill leg and 32 by the time we get home. We have been averaging about 34 indicated and 32 actual once we slowed down on the freeway from limit plus 10 to limit plus 5 on the way to work. We are still at the lower end of the user experiences.
Give it a while.
Thanks for your reply. My trips are definitely on the short side (5-10 miles) with lots of starts and stops. I drive mostly on surface streets up and down canyon roads in the LA area. On longer trips, I'm usually on the freeways going with the flow at 65-70+ mph.
Getting a solid 34 - 35 mpg, mostly highway. The computer in the vehicle is overly optomistic, usually will show about 2 mpg higher than actual. Most of my driving is highway.
Also purchased a second NAH three weeks ago for my wife. Right now only has about 1700 miles on the vehicle and, after a few fillups getting similar mileage.
On trip trip this week, filled up "to the brim" Went 618 miles before low gas light went on. At that point computer indicated 37.3 mpg. Drove another 7 miles & put in exactly 17.5 gallons (to the brim, again) thus actual average of 35.7 mpg (and trip computer still at 37.3) So, based on my actual mileage, the 2.5 gallons would have given me another 90 miles or so, thus could have gone just about 700 miles before running out. I hope this information addresses concerns of those about low fuel light going on prematurely.
Oh yeah, computer read 37.3 mpg and I got 35.35 mpg at the pump. However it took a LOT of slow driving to accomplish it; very easy starts and almost never going over 70mph unless down the hill. Very frustrating to drive so slow but that was my little experiment after reading some postings here from people who keep getting good mileage. I'm back to my regular habits and will probably get 33mpg max on next fill up (that's in warm NY weather, mpg drops about 3 mpg in winter).
Happy driving...
During the 15 days I reset the trip computer MPG calculator a few times so I don't have an overall car indicated MPG; but I did get a feel for how well it did on highway only (one estimate of 36) and how well it did in my usual daily commute (multiple daily estimates ranging from 39 to 45). With this tankful I will not reset it until fillup so I can see what kind of difference this car has between it's indicated and real MPG.
The conditions that gave that 40.6 estimate were:
- less than 3% highway driving, a single time for about 20 miles
- I used every hypermiling technique I'd read about
- the weather was very, very hot (90+); don't know if that has an effct or not
The car is used as a commuting car and to run around town errands. Roads driven typically have speed limits of 40 or 45, really ideal for a car like this as I can use EV mode often and rarely make the guy behind me mad!
Don't know if I'll be able to keep that 40 MPG pace as I definitely focused on high mileage these first two weeks.
I filled up the gas tank and reset the readings before the trip. I filled up the gas tank again when I got back. The whole trip is 2368 miles and the computer says 35.9 mpg. This is similar to what consumer reports says.
However, I only used 56.573 gallons of gasoline. That means 41.86 mpg!!! I kept good record and my calculation is correct. Any idea for the difference???
My 73 posting was incorrect. I found another receipt that my wife stuffed in her purse.
The correct mileage calculation should be:
2368.4 miles / 68.811 gallons = 34.42 mpg
The NAH computer said 35.7 mpg.
This is similar to what Consumer Reports's test.
I always fill the tank to full, every ounce I can get. Today, low fuel light went on after I had gone 582 miles. At that point the trip computer showed I was averaging 36.2 mpg, and computer indicated 52 miles range. Drove another 36 miles when trip odometer read 618 miles and put in exactly 18.3 gallons, thus my hand calculated mileage was 33.8.
Hand calculated mileage on the two fillups was 33.8 and 35.8, per trip computer was 35.4 and 37.2. Thus in line with my previous comments and those of others, the computer is always optomistic by 1.5 to 2 mpg.
I am not a very aggressive driver. Obviously do a lot of highway driving to put on so many miles in a short period of time. On the highway will rarely go over 70, probably closer to 65. I "hate like hell" to step on the gas for any reason & see the mpg on the computer drop a notch as a result. It has become kind of a game driving the vehicle around town, always trying to keep it in EV mode as much as you can.
My wife also got a NAH one week before mine, and now she has approx 1500 miles, and mpg similar to mine, both calculated by hand as well as on the computer.
To a point, it is dangerous. I coast down hill and step on the brake when I am really really close to the car in front. On flat roads, I believe the EV Mode will kick in when your mph is between 32 and 38. So, sometimes, I am driving too slow.
Both vehicles seem to be identical in that the EV only mode will kick in after 1.5 miles approx. We both have driven upwards of 1.5 miles in EV mode only, but you have to drive like there is an egg tween your foot and gas pedal, and you can get up to 40 mph & it will stay there. I think maybe one time I pushed it to 1.7 miles only in EV mode, but the battery by that time virtually empty. Actual mileage on both vehicles pretty consistent around 34 mpg, computer perhaps 3 mpg higher.
The car calculated MPG was 43.0 for the first 300 commuting miles and 41.5 for the entire 700 miles.
Hand calculated mileage at the pump was 697 miles driven, 17.93 gallons used, for an overall MPG of 38.9. This was nearly 3 MPG below the car calculated MPG.
The low fuel warning came on at about 660 miles and indicated 70 miles remaining distance. The numbers then declined erratically....70, 75, 66, etc., a general downward trend but with a few bumps up. The general downward trend was probably averaging about 1.5 miles for every mile driven.
When the trip odometer got to about 690 there were 28 miles remaining; at about 692 it went to 23, and at about 624 it went blank. I am guessing that when it gets to about 20 miles left it goes blank.
All in all I'm very happy with the mileage. Average for the first 1278 miles is 39.6 MPG. That's been with maximizing the use of the battery in commuting driving and keeping the highway speed in the 60-65 range.
While I have babied the car so far with respect to mileage there was one occassion where I had to hit the gas to avoid a bad situation. The battery kicked in and the car quickly accelerated; in that instant this car I'd been treating like a 4 cylinder gas miser turned into a sports car. Nice to know you've got that pickup when it's needed.
Interestingly, I do notice that, because it's harder to get into EV mode, even seen higher charge levels!
Eph
Check out some of the postings in The Inconvenient Truth About Ethanol
I keep very accurate mileage readings. Throw out the mileage indicated by the computer as it is always 2, perhaps 3 mpg higher than actual.
Until a month ago on my vehicle I was getting a good solid 35 - 36 mpg for mostly highway driving. In the last two weeks, three trips totaling a little over 2000 miles and actual average between 30 and 33 mpg.
I can attribute that driving a bit faster on one of those trips -- pretty consistent 70 - 72 mph and the mileage dipped down to not much over 30. Two of the other trips, including two this week same areas I visit quite often mileage down to 32 - 33 but the weather not bitter cold, but in the 25 - 30 range. Plus, maybe (I leave near Providence, RI) seeing the "winter fueld" now
For my wife's car, much more short stuff I just filled it recently almost 700 miles on the last tank, actual mpg was 38.2. Clearly the car will get better mileage at slower speeds -- ideal in the 40 - 50 mph range
The heater works fine, in fact, once heated up difficult to keep the car just "warm" I don't like a lot of heat but problem is even if down to 62 or 63 still comes out to warm for me. Of course you put it on 60, than you get virtually no heat. However, this seems to be the case with most cars I have owned. Either too much heat, or not enough.
I also notice yesterday morning took some time for the heater to be blowing out really warm air. But, once it got going, it was fine.
More impressed with the rear window defrogger. Of all the many, many cars I havfe owned over the years, this one is the quickest I have ever owned. Within 30 seconds of putting it on, you can see results.
Last week, however, with weather a bit warmer averaged 33 mpg on two long trips.
So, I think a combination of winter fuel and colder weather having a negative impact.
Usually I drive conservatively up to 70 on the highway.
Got to run...
When I p/u car this afternoon will fill up as just completed another long trip, computer reads 34.1 mpg and I expect actual mpg will be around 32, now dropping a bit cause of the cold weather
I can't understand how everyone seems to get so much better mileage than I. I do live in a hilly area and in the Northeast if that has anything to do with it. I am going to call the dealer and have them check things out but I have a feeling they will tell me nothing is wrong and try and blow me off. Any suggestions on how to handle this? Maybe I have a lemon?
It wouldn't surprise me at all if that's the culprit. You can read more about it in this discussion:
For anyone to be getting close 20, something is wrong!
