Lincoln MKX sound system problems
We recently leased a new MKX and after
adjusting the stereo, we find that the bass
seems to be missing. We have taken the car to
the dealer and they claim everything is fine.
With the bass turned all the way up, it still
sounds like a cheap transistor radio. No one
would ever guess it was THX because it is so
unimpressive. Has anyone else had this
problem? How was it solved? How does yourystem sound when the bass is turned all
the way up? We think the bass should be so
loud that you can feel it, or at the very least, be
so loud as to ruin the song. Ours is not
anything that you would notice even on a bass
heavy tune.
By the way, we are not audiophiles or overly
picky about sound systems, but know a bad
one when we hear it.
MALKT
heavy tune.
MALKT
Are you sure you have the THX system? It is optional.
What was the outcome of your experience, anything good I hope?
sound system and no dvd player this time my wife picked it up on the fifth of Jan 2009 and she told me when I got home that the sound system did not sound the same as the 2007 MKX well that night I took it for A test drive after dinner and with in the first minute on the road and A good song I put the volume at half and found that their was no bass or very little and for the rest of the sound was horrible I was useing the usb port I then tryed the line in and found the same thing I was not happy I brought it back home and found this Web Site then played some more with the settings and it made no differance next moring I brought it back to the lincoln dealer and explaned to them that the 2008 did not sound the same as the 2007 and also said that I wa not happy with the sound system at all I left the MKX with them and later that day they called me back and said that they tryed other MKX`s on their lot and come up with the same sound they then pulled my 2007 in and tryed it and indeed they to found that their was a differance in sound and this is what they found. with the THX sound system and the DVD player it had the propper amp to power the speakers but if you have A THX system with NO REPEAT NO DVD player ford put A cheap under powered amp in so to solve my MADDENESS Just take A guest what they did oh they did fix it and now my THX system ROCKS.
Well I'm still waiting for Lincoln to resolve the problem. It's been 6 months! System works again after it cools down. 2nd amp and the rear speakers don't work.
Dealer advises unit is set to factory specs and won't do anything.
Anyone else having these problems
Would be interested in knowing what the outcome of this problem by previous owner 'Glakesdivr' was - is all OK now?
Then this summer I figured out that we could download MP3 files (audio only) from our home computer to our Sony Walkman (or Apple I POD if thats what you have), and plug it into our MKX stereo using the USB plug in port. So far I have downloaded about 3 dozen of my wife's favorite programs to our Walkman, which we leave plugged in all the time. It works great. The system even recognizes the names of the programs and displays them on our Navigation screen. The MKX stereo controls also recognize and let you use those controls to navigate files, select programs, and/or control sound from the programs.
My wife just loves it, because it allows her to listen to her favorite programs any time she gets in the MKX (rather than having to wait until a scheduled broadcast time over the radio).
I know this issue is a couple years old now, but was anyone able to find a solution to this 2008 MKX audio issue? RPOITRAS, I have followed your posts on many different forums and I am trying to figure this issue out as well.
I recently bought a used 2008 MKX with the THX sound system. The audio is exactly as you described (Tinny with little bass).
I have now narrowed down the problem to the single amplifier behind the subwoofer in the back right. However, I don't think Lincoln put in a cheap amp on the non-DVD MKX. I think that the physical amp is the same on any MKX with THX, but the actual DSP equalizer is programmed differently on each amp.
Doing some research, I have found there are 3 different amps (all by Pioneer) used on the 2008 MKX with THX. Model numbers are:
8L7T-18B849-AC
8L7T-18B849-AD
8L7T-18B849-AE
There is a 4th model amp, but it is only used on the MKX without THX.
I took apart the back panel on my MKX last night and found that I have the 8L7T-18B849-AE model amp. I called a few Lincoln dealers to try and find a correlation between the amp model number and the DVD feature to figure out which one I need to order, but didn't have any luck.
Going back to what Phil_W said about his 2007 MKX, I believe there was only 1 amp model for the 2007 MKX with THX.
Model: 7L7T-18B849-AL
I am thinking about ordering the 2007 model amp and installing it. Looking at the wiring harness and connectors in pictures, it looks like it should fit. I'm not 100% certain this will work, which is why I am checking if anyone found a solution.
1PD
I like the premium system in my old LS and the thx in the 09 Mks. I paid a lot extra for the vehicle as I had to get the ELITE PACKAGE which adds $3200 to a new vehicle. in order to get the THX audio.🤬
Model numbers are:
8L7T-18B849-AC
8L7T-18B849-AD
8L7T-18B849-AE
The car is mighty quiet, so its worth having a good sound system.
