Ford Fusion/Mercury Milan Audio
I've had my 08 Fusion for 3 months and I love it. A few days ago the rear speakers started to make popping sounds when the brakes were applied. I took it to the dealer and got it back yesterday. They said there was a problem with a ground wire and they fixed it. When I picked it up it seemed to be fine. But today they started making the same noise only not as loud. When I called the dealership they said they fixed it according to the Ford regulations but it could be something else. Has anyone else had this problem.
I would have hoped that the 08s solved the problem.
Mark
anyone have any info on this? thanks.
no big deal, i can adjust the balance/fade to mimic the occupancy mode if i feel i need to. thanks for the reply.
Also, don't let your dealer tell you the problem is a ground wire, it is much more extensive a problem than that, and having a ground wire adjusted is only a temporary fix (less than a day before sound starts again).
