I just bought a 2002 Bravada and it has the same problem that you had with the bad vibration/jamming at slow speeds while turning. Where do I find the document that you referred to in posting 52? (GM Document ID# 1242381)
I would like to get mine fixed as well. Thank you, much appreciated. -Joe
The Olds dealer gave it to me. Would suggest you go to a dealer and give them that document number. Can't see why they would not let you see it or copy it.
Not having the shudder anymore so it is the fix.
Mike
I am too also having that problem when pulling into or backing into a parking space and when the wheels are turned very sharp, it sounds like something is about to break. Hopefully it will last me until I can get that fixed later.
2002 Oldsmobile Truck Bravada 4WD L6-4.2L VIN S
Vehicle Level Technical Service Bulletins Customer Interest Drivetrain - Shudder/Binding/Feels Like Stuck in 4WD
File In Section: 04 - Driveline Axle
Bulletin No.: 02-04-21-008A
Date: February, 2003
TECHNICAL
Subject:
Shudder, Rocking Motion, Binding, Feels Like Vehicle is Stuck in 4WD (Crow Hop) When Turning at Low Speeds (Replace Transfer Case Encoder Sensor and Reprogram TCCM)
Models:
2002-2003 Chevrolet TrailBlazer
2002-2003 GMC Envoy
2002-2003 Oldsmobile Bravada
This bulletin is being revised to update the service procedure and incorporate the fluid exchange. Please discard Corporate Bulletin Number 02-04-21-008 (Section 04 - Driveline Axle).
Condition
Some customers may comment that when turning, the vehicle feels like it is binding, or the vehicle feels like it is stuck in 4WD (crow hop), or that the 4WD system is not working correctly. A shudder type sensation is felt.
Technician Diagnosis
This intermittent condition may be difficult to duplicate. The potential is there at all times for the Bravada. The potential is only present in the Auto Mode of the transfer case with the TrailBlazer or Envoy.
Correction
Important : It is extremely important to check all of the tires before repairs are attempted for these types of customer concerns. Mismatched tires may cause these type of customer concerns. Inspect the tires in the following areas:
^ Ensure that the tires are inflated to the recommended tire pressure as listed on the tire placard on the driver's door.
^ Use a tire tread depth gauge to determine the tread depth. The tire tread depth must be nearly equal on all four corners of the vehicle.
^ Ensure that the tires are all the same brand, size, and tread design.
Important: Pay particular attention so that the proper parts are replaced. The parts terminology is somewhat confusing. You will be replacing the encoder (sensor) and gasket not the complete motor assembly.
(Note: Bravada full time 4wd does NOT have the motor or encoder.)
Currently, the General Motors Parts Catalog lists the following names:
^ Motor Asm, Trfer Case Encoder (This is the Encoder (Sensor). It looks like a donut with three (3) contacts on one side).
^ Gasket.
^ Actuator Asm, Trfer Case Four Whl Drv (This is the complete motor assembly consisting of the Motor and housing, the Motor Asm, the Trfer Case Encoder (Sensor), and the gasket).
Use the following procedure to replace the Motor Asm, Trfer Case Encoder (Sensor) and Gasket.
1. If the vehicle is a TrailBlazer or Envoy, place the 4WD selector switch in the 2 HI position.
2. Raise the vehicle.
3. Disconnect the wiring harness connector at the top of the transfer case.
4. Remove the Actuator Asm, Trfer Case Four WhI Drv (Motor) mounting bolts.
5. Remove the motor from the transfer case and set aside.
6. Position an oil drain container into position under the transfer case drain plug. Remove the drain plug and allow the transfer case to drain.
7. Position the motor on a work bench and you will see four retaining tabs that retain the gasket to the motor. Release the tabs to allow removal and discard the gasket.
Important: Gently lift and tilt the sensor toward the wiring connector wiring to disconnect it. You will notice the two wires to the motor. The red and black wires go to an internal connector within the motor housing. The black plastic connector for these wires does not have a locking tab and is easily disturbed.
8. Lift/pry the sensor from the motor shaft. Disconnect the sensor from the wiring harness.
Important: Look at the motor where you just removed the sensor. You will notice the Hex" in the casting where the new sensor will seat when properly installed.
9. Connect the wiring harness to the sensor.
10. Gently insert a suitable tool along side the red and black wires and press down on the black plastic connector to ensure the connector is in the proper position.
11. Properly align the key way of the sensor on the shaft and install the sensor. Ensure that the hex on the sensor fits in the hex of the casting.
12. Install the new gasket assembly.
13. Inspect the positioning of the gasket and the motor shaft. If necessary to align them as shown, perform the following steps.
^ Connect a fused jumper to the transfer case encoder motor connector red wire and the other end to a positive battery terminal.
^ Connect another jumper to the transfer case encoder motor connector black wire and momentarily touch the other end of this wire to the ground terminal of a battery. This will cause the motor shaft to turn to allow alignment as shown.
Important: Inspect the encoder motor attachment face for the presence of the two (2) locating sleeves. If missing from the encoder motor, they need to be retrieved from the transfer case and reinstalled into the encoder motor before installation.
14. Position the motor to the transfer case and install the retainers.
Tighten
Tighten the bolts to 16 N.m (12 lb ft).
15. Apply pipe sealant, P/N 12346004 (Canadian P/N 10953480), or equivalent, to the drain plug threads. Install the transfer case drain plug.
Tighten
Tighten the plug to 27 N.m (20 lb ft).
16. Refill the transfer case with 1.8 L (2 qts) of Auto Trac II Transfer case lubricant, P/N 12378508 (Canadian P/N 10953626).
17. Apply pipe sealant, P/N 12346004 (Canadian P/N 10953480), or equivalent, to the fill plug threads. Install the fill plug.
Tighten
18. Lower the vehicle.
19. Connect the Tech 2(R) and use SPS reprogramming to reprogram the transfer case control module (TCCM) with TIS software version 11, released October 2002 or newer.
Parts Information
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use the table.
Disclaimer
Good luck and let us know how it turns out. I wish I could help you more......
94 bravavda 4.3 cpi
headers, flowmaster, lowered 3 inches
cold air intake, electric fans w/aluminum radiator.
My name is Pete and I'm new to this forum, but not to Oldsmobiles. This is my fifth Oldsmobile. I just sold a nice 1970 Oldsmobile 442 W-30.
Anyway, I now own a 2004 Oldsmobile Bravada AWD. With the exception of not having the option to choose 2wd to 4wd or A4wd, I'm very happy with this vehicle.
I do feel that there is a problem with it. When you are at a stop light and then start to accelerate (On both dry and wet pavement), you can feel a light 'bucking sound'. It sounds like its coming from underneath the vehicle. When you give it allot of gas, you can then really feel it. :confuse:
I had the service department look at it and they couldn't hear or feel anything. :mad:
Now with that said, is this a normality of AWD vehicles? or did someone else have the same issue and if so, what did they do to correct it?
Thank you for your answers.
Peter
I grew up in Detroit, GM vehicles in family since the 20's, family has more than 80 years employment by GM.
-Bought 1998 Bravada (fourth Old's), brand new, loaded, absolutely a marvelous vehicle, leather great, radio fantastic, brakes best ever.
-Probelms abounded, back to dealer second day, ac sensor failed
-End of week back for noise in right front wheel 'a' frames, dealer refused to inspect until 1k miles
-By end of first month, vehicle returned once a week for component failures
-Right front end was missing two 'a' frame nuts (factory), extremely dangerous, we were lucky
-Back for numerous front end alignments, would not hold alignment for more than five days, dealer never could fix
-3k miles trany replaced
-15k miles engine replaced along with the trany again
-15k miles front transfer case replaced
-some other problems within first six months, battery failure, ac freeze up, crunching noise when turning, master cylinder failure, fuel pump, right front wheel bearings, sensors, circuit cards, reprograming, drive train problems and the list goes on
-vehicle spent more time in shop than on road in first nine months
-motor replaced at 15k miles failed at 25k miles along with trany number two
-vehicle returned per 'lemon law' at 32k miles after being parked for four months during litigation, motor #2 was going away, unsafe to drive
-drive from home to dealer, 18 miles, engine blew up and destroyed trany number three
Observation, service area was packed nearly everyday with warranty work on Cad's, Old's, Buick's over basic oil changes and basic service
Net result, bought a new sedan from another manufacturer and it only goes back to the dealer for oil changes and basic service requirements
I agree, the Bravada is a really nice vehicle, only if it could be reliable, you either love it or hate it, it's either a good one or a pain in the keester. We'll NEVER BUY GM products again, NEVER.
By the way, the fuel pump and the 'mouse' house can be bought for half price and half the labor, but not at the dealer.
Good day
Just purchased a 2002 used Bravada w/ 70k on it. Love it thus far, but I did experience the turning issue once.
Did you ever get an answer to this question?
I'm having the same problem and thought I would check here first.
Mine is a 2003 with 35,000 miles.
Rick
The dealership and everyone who I've spoken with who owns a Bravada between the years of 2002 - 2004 have the same issue. Its actually normal because its the all wheel drive transferring the power to the front wheels under hard acceleration.
Anyway, I'm selling my Bravada if you know of anyone who is interested in it. The vehicle is being sold for $16,500 because I decided to buy a new truck. The Bravada is in pristine condition.
Pete
I don't know anyone at the moment looking for one. If you have it on cars.com or ebay, let me know and I will pass the info on if something comes up.
Rick
I have a 2000 Platinum Bravada and guess what...issues. I have replaced both(L/R) front HUB assemblies twice. The sunroof for some reason has come off track, but closes. When it rains water gets stuck in the rear roof area and sloshes around inside some where. I get the same binding/stalling sensation when cutting the wheels in forward and rev. at low speed. Don't get me wrong the vehicle has 110,000 mi. and I love it, but I feel like whenever I fix something another problem pops up :mad: . The latest problem is a pretty bad vibration occurring between 65 and 80 mph. IF ANYONE HAS ANY SUGGESTIONS TO HELP WITH ANY THIS PLEASE LET ME KNOW, THANKS.
I decided to give it a try and change the transfer case fluid, especially since it was cheap ($6.50/quart - 2 quart capacity) and easy to do. The fluid that I drained out was greenish in color. I assume it was the factory fluid and had never been changed. The NEW fluid (GM Auto Trac II transfer case fluid p/n 12378508) was definitely a bluish color. It was as easy as changing the engine oil, but not quite as easy to refill. The fill plug is located high up, and getting a full quart up in there is all but impossible. I used a cheap fluid transfer hand pump that I had purchased a while ago, and never had much use for until now.
I noticed instant results. No more chattering, shuddering, crow hop, or whatever else you want to call it. I have tried to get it to happen again, cutting the wheels hard in a parking lot when pulling into or out of a parking spot. Nothing.
I purchased another 2 quarts of fluid with the intentions of changing it again, but it has been working well. I may just leave it. One thing I was a little confused about was the part of the GM bulletin that reads "The Bravada full time 4wd does NOT have the motor or encoder." I saw what looks like an encoder on my transfer case, and my Bravada is full time/non-selectable 4wd. I don't know what else it could be. If anyone else has information on this, please pass it on. At any rate, nothing needed done but the changing of the fluid.
I just wanted to say that this site, and especially the posts on this particular problem have helped me immensely. I was starting to get really frustrated with this problem, and from the way the Bravada was acting, thought for sure it was going to be a big dollar fix. What a pleasant surprise to be able to fix it so quick, cheap, and most of all, by myself! Thanks again.
HEATED SEATS SYSTEM COMPONENTS
The heated seats system for the driver and passenger seat consists of the following components:
Driver and passenger door modules
Driver and passenger heated seat switches
Driver and passenger seat back heater elements
Driver and passenger seat back heat sensors
Driver and passenger seat cushion heater elements
Memory seat module
Passenger seat module
HEATED SEATS SYSTEM OPERATION
The driver and passenger heated seats have 2 heat zone operating modes with 3 heat level modes and will operate only while the engine is running. The heat zones are determined by which of the 2 heated seat buttons are pressed, while the heat level is determined by the number of times they are pressed. Pressing the seat cushion button 1 time will activate the seat back and cushion heater elements in the high mode. Each time the seat cushion button is pressed the seat back and cushion heat level is reduced from high to medium, low, and off. Pressing the heated seat back button 1 time will activate only the seat back heater element in the high mode. Each time the seat back button is pressed the seat back heat level is reduced from high to medium, low, and off. During heated seat operation the heat zone operating mode may be changed without affecting the current heat level mode.
The heated seat switches are momentary contact switches and are inputs to the driver and passenger door modules. Battery voltage is supplied to the switch assembly from the door module, and when a heated seat switch is pressed and released a brief switch signal voltage is supplied to the door module. Whenever the door module receives an active heated seat switch input, the next heated seat operating mode is determined by whatever the current mode may be. The seat heater elements are controlled by the driver memory and passenger seat modules using inputs from the door modules through Class 2 serial data circuit messages. When activating any of the heated seat operating modes, the seat module switches battery voltage to the heater element supply circuits. All of the seat heater elements are grounded by the seat modules through individual low reference circuits. The heater element low reference circuits are pulse width modulated control circuits and are used by the seat modules to control the seat heat zones and temperatures by regulating the current flow through the heater elements. The seat modules rely on inputs from thermistors installed in the driver and passenger seat backs to control heated seat temperatures. The thermistors are 2 wire sensors supplied with a 5-volt referenced signal circuit and a low reference circuit from the memory seat module. Resistance through the thermistors varies with temperature causing the heated seat sensor signal circuit voltage levels to increase as the seat back temperatures rise. The seat modules allow heated seat operation only while the engine is running which is determined by a Class 2 serial data circuit message from the powertrain control module.
http://www.automotiveforums.com/vbulletin/showthread.php?p=4643734#post4643734
Automatic 4WD
A scan tool must be used to retrieve DTCs from the Transfer Case Control Module (TCCM) memory. The use of a Tech 1 scan tool or equivalent will be needed to obtain both current and history DTCs.
C0300 Rear Speed Sensor Malfunction
C0305 Front Speed Sensor Malfunction
C0308 Motor A/B Circuit Low
C0309 Motor A/B Circuit High
C0310 Motor A/B Circuit Open
C0315 Motor Ground Circuit Open
C0374 General System Malfunction
C0376 Front/Rear Shaft Speed Mismatch
C0550 ECU Malfunction
C0611 VIN Information Error
C0895 Device Voltage Malfunction
good luck
HELP :confuse:
I just bought my wife a 1998 olds bravada.beautifull rig.went on a trip, and now the icon on the dash(little red man sitting with seatbelt and circle in his lap)comes on some times ,and goes out,some times for minute. sometimes stays on all day. is this the service air bag warning,is there a way to reset it, will the air bag go off,
any info
MAC
