Mercury Cougar Transmission Questions
we just got a 2000 cougar v-6 automatic we really like it but when it is warmed up and traveling about 50-55 it sort of bucks then stops then a bit later bucks again. I call it bucking because i am not sure if it is hard shifting or severe hesitation. has anyone had this problem or know of it???
http://www.2carpros.com/forum/2000-mercury-cougarmercury-cou gar-bucking-vt121761.html
What does NOT seem to fix the problem is:
New spark plugs, fuel filter, carbon cleanout, new EGR valve
What DOES seem to fix the problem is:
New temperature sensor (you need to get this directly from Ford but the model for the Contour looks to be compatible), MLP (mass lever position) switch, and/or the Mass Air Flow sensor. The parts appear to be cheap, but the labor can add up to a decent amount. Hope this is helpful.
going steady 70 mph , every 4 or 5 mi. , car will jerk / shutter , the engine tach will jump from about 2800 to 4000 rpm, sometimes even 5000 - like the trans can't select correct gear . . . .usually will be fine for 3 or 4 mile, then jerk 2 + times ,HARD jerks, then be OK again for a bit. after a longish drive , will even do it at slower speeds , so -- is this related to warm up ??? not warm weather but engine /trans heat ? the engine gauge stays 'N' . . . does the transm. oil cooler have a thermostat or some such ?
new fuel filter. new trans oil, took it too 2 shops didn't find anything. even tried unplug, wait an hour , re plug main battery ( owners man. says the engine computer will relearn.?) note there are 2 service notes about ' reprograming Auto trans control module . . .
drove it 40 mi right after repair, no problem, first time drive more than 10 mi, no prob. since Aug. ... today , drove 90 miles non stop, most at steady 60 , no problem.
Why the Merc dealer I bought car from new couldn't fix 6 months ago ... ?
transmission 4R/70W full electronic automatic with overdrive. At speed of 30 to 45 miles and touching very lightly the throttle, the transmission started to shake (hesitiating) for one or two seconds. Total millage of the 50.000 mile. Overdrive in or out does not make a difference. The car has been inspected by a so called Transmission "specelist" in The Netherlands. Problem still the same.
Engine V8-281Ci/4.6 litre SOHC fuel injected.
Can I replace the engine with a 1999 2.5 that has a standard transmission?? ( i don't want to swap the standard trans because it is broken)
I am new to cougars so any info would be greatly appreciated.
thanks!
I have to rev the cat up to 3000 rpm a couple of times before it launches like it has a stall converter (which it doesn't). Will bark the tires with no tranny slip. If i ride the brakes and keep it above 1500 rpm, i can take off from a stop without reving it up again. Shifts fine once moving, whether in town or hwy. Reverse works fine. Fluid is pink with no "hot" smell after an hour drive. Whats up?
