Ford Expedition Advance Trac Problem
'03 Expedition - Message center says to get Advance Trac serviced. On a trip, 75 miles before it first began to act up, I had the right front tire balanced. What could I check myself before I turn it over to a dealer? Like maybe dirt in sensors? When it first happened, I was going straight at 65 on an Interstate. I think it was raining. I was in 2wd, but had used AWD earlier that day, maybe 140 miles earlier, while climbing a steep gravel drive to a hard road. No wheel spinning took place.
The dealer I bought from has closed. What about where I stand outside and turn the wheel lock to lock, to re-center the system? Are there connections to jump, to make this work?
Just got back from the Ford dealer where they charged me 73.00 to tell me its going to cost me 725.00 to get my crap expedtion fixed . I have been told its the ABS Module that will need to be replaced and reprogrammed . Not happy . Hope you make out better .
Take care ,
Roger
I know the manual suggests using the parking brake until vehicle begins to move. it says this will help to stop will spin.
I wonder if this has anything to do with traction control, ABS or Advance-trac as opposed to an actual failure of the vehicle? Seems like it wants to cut power if it thinks you are braking and accelerating at the same time like during an emergency?
I'll use parking brake next time and see if I still have an issue.
Chris
The "check advance trac" light issue could be related to this. Anyway, the pads looked good with maybe three-eighths of an inch of meat showing. However, it looked like there were SLIGHT vertical lines showing on the pads. Would they be wear indicators? No squealing whatsoever.
Then , for the bigger issue, the "check advance trac" light came on right after the brake inspection. How can I determine if I really should check the light? Do I have to pay a dealer to run a code or is there a way to do it myself? Any ideas?
thanks, Peter
thanks, Peter
