Jeep Wrangler Leaks
Can someone tell me what i can do? I have had my Wrangler back to the dealer for the leak 4 times she swears its fixed this time.they have had it for 2 days and counting On this service appointment i asked about the rusty muffler plus the rust on my hinges her response to me and i quote was " if i change the muffler its just going to rust again in a few months" is this right? this is the same person that said when i brought it in the first time for the leak and she said well there is drainage holes in the bottom so the water will leak out!
What should i do should i call Jeep corporate or what?
Please if anyone could give me their opinion on this it would be greatly appreciated.Im so fustrated by all this! Thank you very much
Correct. Well ok, change 'leak' to 'drain'.
Unfortunately, judging by recent reports, also correct.
That both statements, about which you seemed to have doubts, are actually correct.
You got my opinion, which is worth exactly what it cost!
I'm not trying to be nasty, but just because you didn't like what the service writer told you doesn't make it untrue. I can certainly understand your frustration on the other issues.
Thanks anyway!
However, it's also likely that the replacement will rust too, unless they've already made improvements.
Just my 2 cents, but it seems that major savings have been found, both in production costs and warranty work, since the change of ownership from Daimler Chrysler to Chrysler L.L.C.
Whether those savings are being made intelligently remains to be seen.
For what it's worth, the original muffler on my '99 (complete with drainage hole) is still unrusted after 80K+ miles.
If you really like the Wrangler, ask them about swapping in something like a Flowmaster aftermarket one (they pay what the OEM one would cost and you pay the difference).
My Jeep is such that if I'm not happy with OEM parts, I go aftermarket and Wranglers have a HUGE aftermarket support structure.
I agree that the answers are correct, even though what they say really bites. As for the door hinges, get em replaced. My guess is the paint isn't applied properly and moisture gets in there to get the rust going. My 97's bolts have rusted, but I don't put the nuts on either to cover it. They're off most of the spring/summer/early fall anyway.
-Paul
Thank you tho!
I've seen similar things happen with the 2 piece hardtops that are available for the TJ as well. With the soft top, the leaks actually seem less likely as the primary seal point along the windshield is secure. To me, those multi-piece fiberglass tops would be subject to warp under heat/sun and pressure from driving. Yeah, I know they should be designed to handle that, but I just don't trust stuff like that too often.
If you bought the dual top option, you may want to consider swapping on the soft top to see if the problem goes away. That would at least narrow the issue to the top itself.
-Paul
SUVs and Smart Shopper
