As an aside, after Buckeye Honda, Lancaster, Ohio, advised that I would have to "live with it" I filed a customer claim with BBB Auto Line. BBB Auto Line refused to arbitrate with American Honda because the mileage on my CR-V was in excess of the Honda warranty (36,000) at the time I filed the claim (even though the mileage documented by Buckeye Honda for the first of five attempted repairs was less than 36,000). It was explained by the BBB that I did not meet the "Time Period for Filing" for the claim to be eligible under their program. Since I put my misguided faith in Honda by allowing five months to elapse while Buckeye Honda dithered around before they told me to "live with it" the claim was determined to be untimely.
Today I was informed by a customer service representative at American Honda that this body vibration is [quote] an inherent condition in this vehicle and not a defect [unquote]. Supposedly Honda engineers verified that this body vibration does not present a safety issue (this is debatable) and since the 2009 CR-V which I test drove [apparently a determining factor] demonstrated the same vibration, that this car has no defect. I beg to differ and advised him that my next car will be a Chevrolet. Also, Buckeye Honda has seen the last of my continued patronage.
Given the LACK of Honda support it appears others have received, I will immediately begin taking this to my Honda dealer to document the issue. Further, I suggest we start a "Twitter" campaign to get the attention of Honda marketing. This is a serious problem and the response you received is crazy. Imagine if they said, "Not starting in cold weather is an inherent issue with this car but not a safety issue"! Crazy. Look for the hash tag #honda and #hondacrvvibration for the campaign.
Kevin
Remember Richard that a CRV is a truck. You'll get use to it.
My biggest problem is the "head rest" leaning too much forward. It could be because I'm short.
Compared to the Nissan Versa I tradeed in, my CR-V, it rides great. It's about the same as our '08 Nissan Alitma on most surfaces, with a little more road nose, wind noise, and because of the shoirt wheelbase it rolls and ptiches a little more. But it has longer travel suspenson, so on really, really bad roads, the CR-V rides great.
I've NEVER had it bottom out, whereas my other cars would have easily bottomed out on a variety of surfaces.
I suppose some folks are more sensitive ot certain vibration and frequencies than others I gues for me, if it's not loud enough to be annoying and I know where it's somming from, it doesn't bother me at all.
For example, when I ride my motorcycle wiht a helmet on, there's a LOT of wind noise. But that's to be expected, so it's not a complaint.
All of my cars with 4 cylinder engines have had soem sort of low freqency vibration at low RPM's. It's difficult if not impossible to design a durable engine mount that can reduce all high frequency vibrations and now all low frequncy as well.
I think hte simple solution most American cars have to vibration is making the chassi stiff and heavy enough, and isolate the suspension, steering so much that the vehicle 1) has no road feel, 2) weighs 300+lbs more than the competition. This is how Chevy resolved the issue on the Equinox. It's a fat overweight pig. 30 more HP than a '07-'09 CR-V, but the reported accelerated numbers are the same even though it has an extra gear.
Your vehicle displays engine oil life and maintenance service items on the information display to show you when you should have your dealer do engine oil replacement and indicated maintenance service. Based on the engine operating
conditions, the onboard computer in your vehicle calculates the remaining engine oil life and displays it as a percentage.
Whereas my Honda Dealer (Paulmiller Honda) Suggest: that I should go for oil change every 3000-4000 miles and do major services after every 7500 miles (A - B- A) services.
My Car is running good and I reach upto 50% in 6 months or 6000 miles.
I just wanted to know do we need to follow Dealer or Manufacturer...?
Kindly let me know your input...
I searched all forums and from what I've been reading it seems I have
the Harmonic Tingle. So apparently it's happening in 2010's also.
Love the car and will live with the tingle as some of the repairs are too drastic for my taste...at least on a brand new car.
My question is - if Honda has known about this problem for all these years why can't they eliminate it? Too much to ask? (-:
I've two 4 cylinder cars....an older Honda accord and a Mazda Protege5 and never had a rumble.....
Thanks for info though......
2010 EX-L CRV
Otherwise, my '03 Accord also "lugged", rumbled, vibrated, whatever you want to call it a in 4th and 5th gear at low RPM's. I consider it parts of the cars character and not uncommon for a 4 cylinder. Our Nissan Altima does this as well. Worse, from 35-40mph the CVT, noticeably "hunts" or "surges" a little.
I think all Hondas vibrate a little at low RPM. It's part of their character to a certain extend. I remember test driving a Odyssey and at low RPM's in top gear it vibrated a little too.
Modern, lean burning engines when under load at low RPM's tend to vibrate a little with the extr atall gearing they now have along with increased weight. It causes the engine to work a little harder at low RPM's that older cars might have.
Go test drive a few other 2010 vehciles and pay attention to how hte engine sounds at low RPM's when in top gear.
I answered three surveys complaining of this problem and maybe, just maybe Honda will fix it?
Honda isn't going to fix anything as long as their CR-V sales remain constant and until perhaps [if and when] there are multiple fatalities related to the way the car handles (difficult to control in high winds and during high speeds due to the severe vibration of the body).
Either way it's not dangerous so far (X fingers crossed) and doesn't cause any difficult handling, etc. Just annoying at times....but if I blast my favorite Bob Segar CD, don't hear a thing...LOL
The explanation I get now is that there is a software error in the system controlling the fuel/air mixture. Apparently there is too little fuel in the mixture at certain speeds that have some cylinders not firing correct.
They say that Honda Japan is working on a fix and that this fix should have been available several months ago.
Still love the 2010 but you would think since 2008 they would have corrected it....
You can test if your tires are "chopped" yourself by rubbing your fingers over the tread (I find the outer tread-line next to the sidewall to be the most pronounced). Rub it 1 way towards the front of the vehicle and then the other way towards the back of the vehicle - it will be smooth one way and "choppy" or difficult the other way if they are chopped/cupped.
I only recommend someone buying a CR-V who likes to gamble - knowing they could lose all their money. You may be OK, or you may have the nightmare scenarios that many of us with 07 thru 10 models are having. I wouldn't do it if I were you.
Did you get any help from the Swedish dealer.
If so, what was the fix? (was it software related)
I also experience a slight juddering/vibration while driving on cruise control set at 100km/h. The vibration starts just before downshifting occurs due to increased load (or if I change from 95 to 100 km/h on the cruise).
Did you have this problem?
CR-V 2010, 2,0L petrol, 5sp AT, 9000km, Adaptive cruise
Stockholm/Sweden
After a decade long mutually destructive relationship with my Honda or Hate (HOH) I'm ready to do it right this time. I read the forums and goodle the hell out of all the forums but I'm delurking because...well...it's kind of overwhelming. My mom took the car to one shop (I already called for the repair history, "it's in the mail") about twice a year for an oil change every 3000 miles.
Heres what I know needs attention...well first those bumper stickers need to go. Only the magnetic ones transferred to her new Outback and now Im suck with a dozen stickers about dogs, the beach, life is good, kayaking, etc...i love my mom but I want them gone. Any recommendations for a paint safe glue remover?
More important stuff: The New V has finally worn out the original continental tires. Its battery is dying. The ivory colored interior cloth is really brown around the door handles. And the back brakes squeak. I saw the notice about reimbursement for the a/c compressor clutch but it didn't seem like I have to take any action.
Today I met Maintainance Minder (mind blown...and frustrated), which claims 70% oil, an A, and 1500 miles to a B (at least that's what I think the MM said, bear with me, it's only been five days). The sticker on the New V's windshield says I'm 300 miles past due for an oil change; I'm assuming that's based on my moms 3000 mile schedule. After reading these and other forums, and based on my experience with the HOH, I think I can go for another thousand miles or so before changing the oil.
But what about rear diff? brake fluid? ATF? Flush or just replace? and what about cabin and air filters? And while I've still got your attention, does this thing have a timing belt or chain?
I'm disappointed that the 2008 models lack a formal maintainance schedule (I did grab the 2006 one though, thanks) because I need a lot of guidance with car care. My ten expensive years with the '03 CRV honestly taught me nothing...I sucked, the car sucked, glad its over. So this time will be different. I really want to do right by this car and figured that by now other Edmunds members must know a thing or two about maintaining a 2008 CRV with 36,000 miles. So...what do you suggest? Any tips? Warnings? Thanks!
"Removing stickers, labels, decals, glue, sap..."
Or just take it to a detailer and let them do it while they work on the areas around the door handles.
The Edmunds Car Maintenance Guide should give you more details on what the maintenance schedule involves.
I won't be recommending CRVs to my friends anymore which I been doing for quite some time.
BTW I just called a HONDA dealer asking about the vibration, and they told me they will need to see my car to test the issue, but i am pretty sure that according to his first response after hearing the word "Vibration", he's seen enough similar cases.
