2005 Honda Pilot Shudders
My 2005 Pilot Shudders in the speed range of about 35-40 mph, with light pressure on the gas peddle. I seem to feel a Shiver at higher speeds but this may be from tire balance. The dealer said the Shudder was due to the EGR valve being carboned up. I replaced with a honda part however it's still happening. Anyone experienced this problem and what did you do to fix it?
I took it right back. They told me their tire balancer was not calibrated properly and they attempted to fix it. Once back on the highway it was improved, but not gone. I drove it that way until I replaced the tires. Shudder is gone completely now.
Never did go back to that dealer again.
Any luck since your post?
The other funny thing is that we bought the car new from a fairly large dealer in our town, financed it through them and bought the extended warranty at the same time. Come to find out the warranty is maintained through a third party. Honda says the vehicle needs a new transmission, but the third party warranty group is sending out an inspector tomorrow to verify everything. I don't remember hearing about this when we bought the vehicle. Thought anyone reading this might like to know.
what was the final outcome of this situation? did you replace the transmission? did is solve the problem? how much did this cost you...the dealer?
i have over 125k miles and not sure what options i have... any recommendations?
thanks.
I my case it was the transmission. Fortunately we had an exteneded warranty and it was covered. Problem was completely corrected after the new tranny was put in. It seems I started hearing about other folks have transmission problems with their Pilots. I don't recall teh exact cost, but I believe it was in the $3K or $3.5K range from the dealer.
Wish I had better news.
http://www-odi.nhtsa.dot.gov/index.cfm
Also, the NHTSA has issued a "service bulletin" for this exact same problem for all Acura's for model years 2003-2004. To view the service bulletin, go to the following web site:
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
Enter NHTSA item# 10022468 in the "quick search" box. Once you get the record, click "get summary" and you will see the exact explanation as follows:
"Torque converter shudder or vibration between 35-40 mph"
This is exactly the same problem that is so prevalent with the 2005 and on Acura MDX and Honda Pilots. Do not understand why a service bulletin has not been issued for more recent model years???????
Acura Service Bulletin 06-003 pdf
There is also a statement in the document that addresses "out of warranty vehicles" the the procedure for obtaining a "goodwill consideration" repair. It would appear that Honda/Acura was expecting a significant number of vehicles (both in warranty and out of warranty).
I have a 2005 Acrua MDX that was one year "out of warranty" and through persistence and documentation from web sites such as this one and also the 15 complaints filed with the NHSTA, I was able to get Honda/Acura to move from not covering my $2,000 repair to covering 100% of my repair.
Has anyone had any luck with getting the repair done even if your car was not part of the original recall?
I had the transmission fluid changed, and it came out black as coffee with friction materials present. Since the change, the frequency of the shudder has decreased, however it did not disappear completely. I don't know what to expect, if the transmission is going to fail soon, or if I can get some use out of it before it dies. The car has 127K on it, which in the past meant that it was just getting broken-in. I am begining to wonder if that's a true statement anymore.
I've filed a complaint with NHTSA and printed the Accura SB to take to my dealer. Other than what I have done, does anyone have any advice on further preventive maintenance or steps I could take?
I took it to another dealer, one that I usually work with, and they suggested drain and fill service on the transmission. We discovered the fluid was black as coffee (Apparently the previous owner didn't have the fluid changed in about 100K) and there was some particular material on the drain plug magnet. At the time, they did not recommend a full flush, as that could cause more issues.
Since the drain and fill, my issues have pretty much gone away, with only an occasional burp. Since the noise stops when I place the transmission in D3, I am pretty confident that it is the torque converter that is responsible. Being that the frequency between events has dropped dramatically, I am hopeful that I can get a few more years out of it before needing a new tranny. The pilot has 128K on it right now. I'll probably drain and fill the transmission this summer myself, just to make sure that any particulate matter that is still in there can hopefully be removed.
Hope this helps.
Scott
We had the transmission changed, rebuilt unit, by the dealership with all work covered under the extended warranty. From memory the new tranny came with something like a 90 day warranty, with rebuilt being the only option. I was told a new transmission just wasn't available. Fortunatley, because we were having the work done under the extended warranty we got a three year warranty on the new (rebuilt) tranny.
So fast forward to 2011 and the problem is creeping back. Everything is out of warranty, so we are SOL. We have 145,000 miles on the vehicle and planned on keeping for at least 250,000 (My 4Runner has 320,000). That's just how we are as a family and why we came back to Honda after runnig away from our 2000 Volvo wagon. So it looks like we are going to wind up spending $2500 - $3000 for a new (rebuilt) trans as everything else about the vehicle is pretty good. Funny thing, my 4Runner is a 1994 model and back just a few years ago I got a safety recall notice in the mail. Imagine that, on a 14 or 15 year old vehicle they were willing to accept responsibilty and fix a potential problem free of charge to me.
Good luck to everyone, doesn't look like there have been enough complaints to warrant Honda coming forward and fixing the problem.
There is a temporary band aide, Don't laugh it sounds silly, "Mr. Shutter Fix", is an additive to the transmission fluid. Its a small plastic red tube about 4in long and 2in. around, but you have to have the fluid changed b4 adding it and make sure the place you take it to, has only Honda Made oil. Apparently, Honda makes their parts to run only on THEIR oil. It has additives in it that only Honda makes, w/o this you may get worse problems later. This is coming from 3 different Mechanics and a Junk yard owner. It seems that Honda has created a Monopoly - which I though was illegal. It did work by reducing the noise and frequency, but not completely. Like I said, its a band aide to buy time to get money together to fix it permanently.
I have only bought Honda's and this is the first time I ever had a serious problem so early on (just under 100k). I opted to fix it because everything else is fine and I don't feel like having a car payment. So pass this along to anyone you meet or know with this issue & maybe Honda will consider helping all of us. After all they do want to keep their customers happy and coming back, especially since they had suffered such tragic natural disasters. They don't want to start developing a bad reputation after having such a good track record for so long. After all, everyone knows that bad news travels faster than good new.
I still haven't decided if my next car is going to be a Honda. It seems like they are slipping on their reputation. Look around the internet you'll see that this is happening more often than not. :confuse: :mad:
I was hoping to keep my Pilot over 250k miles, but now I worry about the coming $4000 expense. Even so, you lose that much driving a new one off the lot I guess.
http://www.autobarn.net/inshudfixbyd.html
Now bear in mind I'm licensed mechanical engineer and not one for amazing fix pookie mix fromulas, but I figured I didn't have anything to lose. So far so good. For the current term the shuddering has subsided. I'll try to remember to check in at this forum and give upadates.
Electrical Engineer from Va Tech, Go Hokies!
I found this site and others that contained complaints about the shaking issue I was concerned about, now i'm terrified :sick: because some individuals have had complete transmission failure and I now know that the little shudder that I feel could be the only warning and I still don't know how long I have until it fails and I can get a rebuilt transmission but that is doomed to fail also.
I am also reading that Honda is in denial about the situation :mad: , I don't understand how they can ignore it because to them it's a "COST" issue, when people are PLACED IN DANGER because of the failure, that's a "Safety" issue as well. I am afraid to let my newly licensed 16 and 17 yr old drive the car because drivers education didn't teach them how to handle transmission failure and I don't want them hurting themselves or anyone else.
This is a safety issue that requires a new transmission replacement, not a patch or code or a rebuild that's going to breakdown after a few ten thousand miles. Clearly this is a problem and some investigating on behalf of the consumer needs to be done to keep us safe.
In the meantime I am going to go to my local dealership and see what they know about the situation and possibly call USA Honda just to get my voice on their logs then I am going to take my pilot to our local transmission specialist and have them inspect my tranny and do the ATF drain and fill (no flush) and see if that helps, I will also see if they've heard of the pilot/mdx problem.
will keep you posted.
