Toyota Sequoia Rear Hatch Door Problems
peterson70
Member Posts: 5
I am having a problem with the rear hatch on my Sequoia. Opening it is becoming harder and I must push in on the door as I try to activate the latch. Am I bending the cable holder on the inside of the door??? Anyone else experiencing this or have a remedy?
& unlocking but most of the time it will not open. Dont know how to fix it either.
You may have no choice but to bring it to a Toyota dealer.
Be prepared to pay $$$ for them to look at it. Good luck!
Corporate Toyota phone number is 800-331-4331
Cora
How do you UNlock when your cable is fine but door does not UN lock when I press the remote botton? How do you remove the black piece inside the hatch door that locks the door to the main body?
I already took off all the panels inside the hatch door so I can access the cable and everything.
but we need to get together and let toyota know this should be a safety issue and a recall should happen I talk to the FEDERAL TRADE COMMISSION and unless they get a flood of complaints to push toyota hand nothing will be done. SO LETS GET TOGETHER AND LET TOYOTA KNOW WE ARE FEED UP
Now when I press any rear door button the system beeps twice and then...nothing.
Any insights?
Simeon
i have 2002 SR5 on which the rear latch and window do not work. wondering where you got the part?
how you got to the rear latch. i don't see any access points??
i would appreciate any insights, thanks
First, you have to climb in the back of your Sequoia since you can't open the hatch. Take a flashlight, a 10 mm socket and some patients back there with you. a box fan sitting in the backseat blowing some air on you helps too if Sequoia is in a hot location. There is a pulldown strap that has to be removed first. Slide the plastic cover "up" to reveal the 10mm/phillips bolt that needs to be removed to get the inside plastic cover off. Then you will have to take ALL the plastic molding off to get this cover off. Start with the top molding in the center ABOVE the window. It pops off and comes off first. Then take the molding on the left and right sides of the window. It pops off too. Now you can remove the large plastic panel covering the lower half of the hatch. Squeeze your fingers into the window area and pull "UP" on the large getting the top section of the cover over the metal frame at the bottom of the window. Once over this pull "OUT" on the cover since the lower sections snap on.
Take a deep breath because there is more covers to take off. Now you will need to take the 10mm socket and remove 8 bolts holding a metal cover over the power window mechanism. This cover has to have to cables unplugged if you want to get it out of your way. I recommend this after I did not do this at first and having this cover hanging by the cables and getting in your way just adds to the frustration if you take a few minutes and unplug it.
now with this metal cover removed get your flashlight and look in from the drivers side of the power window mechanism. You should see a cable going from the latch (bottom center of hatch) to behind the license plate (where your broken latch is that you have to manually open). There is a clear plastic cover over the latch and cable. Pull this off. Then feel where the cable ends. Assuming the cable is still in the metal latch mechanism, push UP and to the PASSENGER Side of the car with this end of the latch extending the cable and hopefully popping open the hatch.
If you have made it this far, go in and take a break, relax and regain your calmness. Now, to remove the broken latch you have to first remove your license plate and the screws holding the plate. Then, from the inside of the hatch there is one 10mm bolt holding the key lock mechanism on. Take this bolt off and let the lock down into the hatch. Now for the toughest two nuts to take off. Inside the hatch there are two bolts that are part of the latch that you must remove 10mm nuts from. You can almost see the Driver Side bolt and I took these out with a smaller 1/4" 10mm socket wrench. The nut on the passenger side it really hard to reach. Your forearms get torn up the the large gears for the power rear window, but once you get these two 10mm nuts off the latch from the inside you are almost there. Now with the key lock removed and these two nuts, on the inside of the hatch at the 4 corners of your outer license plate "trim" you will see snap in mounts. I squeezed these from the backside so that the license plate trim comes out. Unless you want to disconnect the power to the license plate lamps, just flip the frame over to remove the broken latch from this frame. There are two phillips head screws holding the latch to the frame. Once you get the old latch off, screw the new latch on. NOTE: Take care to screw the latch on evenly and all the way in or you may have to take it apart again to get the license plate frame to sit flush and snap back in.
With the new latch installed, replace the license plate frame snapping it in from the outside and then put the 2 10mm bolts on either side of the latch from the inside as well as reinstall the key lock. Don't forget to connect the cable to the new latch. I removed the cable from a tydown block to give me more slack in the cable. Using the flashlight, take the end of the cable and thread the "ball" on the end through the slot on the new latch and press the outer shielding of the cable back as it was original. Replace the clear cover over the latch mechanism. At this point, test your new latch and make sure your license plate frame is snapped back in flush.
If so, then reinstall the metal cover with the 8 10mm screws. Plug back in the wire harness (though I am still having trouble with my rear power window). Then put the plastic cover and trim back on in reverse order... large plastic cover, left and right window trim and top trim. Then put the pull down strap back on and replace the plastic cover on the strap by sliding it down.
Hope this helps. I still wish there was a way to get all the power window gear out of the way and give you more access to do this job.
& unlocking but has only opened a few times and that is only when I have the right back door opened, it's a hit & miss situation. The window operates fine though. Before I take it to the dealer for the cost of an arm & leg I would like to repair it myself. Any Help or direction would be greatly appreciated.
We took the car to a local body shop to have the door replaced. But apparently they didn't do it quite right. Over the last year, water got into the door panel and messed up the circuit board, so the door wouldn't open anymore. So I took it to Toyota who said they wouldn't fix the electronics until the leak was fixed and that a body shop should fix the leak. I took it to a body shop who told me they couldn't find the leak until they could open the door and that it was stuck because of an electrical issue. Back at the Toyota dealership they told me this time that they could only open the door by destroying the door in order to access the locking mechanism. Then I went back to the body shop who said that the dealership was nuts and to take it to another dealership. I took it to another dealership who got the door open and the latch fixed. But I got it home and the whole thing froze up again because the electrical system was still broken. That's where we are tonight. Despite many complaints at no time has any Toyota representative handed me any consideration other than another bill.
add mine to the long list of Sequoia owners with hatch problems
The first time I saw how cheaply designed this handle was there was absolutely no way I was going to use the same type of handle again, just so a year or less down the road I could come back to the same job and repeat. I fix and replace the handle for $150 and I have done so many it only takes me a little over an hour. If anyone would like to email me I can be reached at affordablelockandsafe@gmail.com
When my Sequoia's rear latch broke, I checked eBay and found a plastic replacement part for $17.00 and a cast METAL version of this part on eBay for $33.90 (including shipping). My wife, being the wonderful woman as she is, thought she would do me a favor and take it into Phillips Toyota in Leesburg, FL dealership. She was told that the part was not even available in metal and that the plastic replacement part alone was $76.81, with an installed price of $280.34. Needless to say, I bought the METAL part on eBay for $33.90 and installed it myself. Total cost $33.90 for a metal part that will last forever vs. $280.34 for a plastic part that would be broken and back to the dealer again next year.
I will not even consider buying another Toyota vehicle. Their build quality is like the old gray mare: she ain't what she used t' be.
First: In the 2nd paragraph of his instructions, Tom states that you need to take ALL of the trim off including the top trim. Though he is correct that you need to pop out the interior rear window pillar trim off on both the left and right sides, you do NOT need to remove the trim from the top of the window. Just pry the left and right side pillar trim pieces out firmly. Again, be prepared to pull out firmly since there are 3 of the white plastic Toyota trim snaps holding each pillar side trim piece on (I found it helps to use a screwdriver to pry/pop each snap out from the underside of the trim piece).
Second: When the rear door latch is broken and the rear door is closed tight, it's cramped and miserable to squeeze your whole body behind the 3rd row seat and is not easy to get your fingers to pry up the tightly-secured interior trim panel and pop it off from the inside. My first instinct was wrong: I tried to pull the interior panel upwards. No, the panel is snapped in place by 8-10 of those white Toyota interior trim snaps and only THEN it will lift up. My bassackwards approach (which actually worked very well) was to roll the rear window down, stand on the outside at the back of the vehicle, and then use a stubby flat screwdriver to gently and slowly pry the interior panel weatherstrip up and over the metal lip backing it and THEN pop off the interior trim panel by pushing the trim forward while standing on the outside.
In Tom's 5th paragraph, he says that your arms get torn up by the large gears of the power window mechanism when trying to remove the two nuts from the back of the broken handle. I started down this same path too, but fortunately noticed two half-dollar sized rubber grommets at about where the nuts are located. If you pop those rubber grommets out, you can get a 10mm socket wrench with a 6" extension to access those nuts without ripping up your arms.
Finally, I suggest that everyone here buy their replacement part on eBay or Amazon where you can get your replacement Toyota Sequoia rear door latch in METAL instead of plastic for under $35. Don't buy the $70+ replacement part from Toyota (why would you reward a company that makes this known defective part for more than a decade?) and, besides, Toyota only sells cheap plastic replacements when metal OEM versions are half the price and will last for the life of the vehicle.
Any questions, you can email me at paulperk@gmail.com and I'll be happy to try to answer.
Jim
It won't break again. The job should take a competent mechanic about 90 minutes. If you pay more than $120 for the installation by a non-dealer, you're paying too much!
When we disconnect the rear MPX ECU, the electrical problems go away from the rest of the car, but the rear door is completely dead, even with the key. We did a visual inspection of the wires and don't see any frays. I hate to replace the costly rear ECU or body ECU unless I can prove they are the cause. Any ideas out there?
