2006 malibu Maxx Problem
When I am driving down the road at at least 60 km/h and I let off on the accelerator my rpms will fluctuate up and down. It almost feels like the transmission is kicking in and out. Can anybody help me?
I complained to my service advisor and mentioned another call to Chevy (that's what it took to get my steering fixed) and he said I should get the shifter fixed first, which currently will not cycle through the gears when in L(ow). He said it might be related, but can't guarantee it. $400 fix. He also told me an investigative tranny tear down would be about $2k. This is bugging me as I go on vacation next week, and had been mulling a drive to DC to visit my son. Not sure I want to risk it. It is going to an independent garage for the first brake job this week; maybe I'll see if they can shed some light on what is going on.
Glenn
pao, a familiar login name from way back in '04. I thought we had a lot of miles on our Maxx!
Does anyone have any suggestions. :mad:
you might want to check the aftermarket auto parts stores online....I like RockAuto....they state its a non-stock item...and 12 business days to get
For what it's worth, two codes from Augo Zone both pointed to possible wiring and/or Accelerator Pedal Position Sensor issues.
If you have any info on the shift control switch that was replaced and how it's done I'd appreciate it! What I'm wondering if a do it your selfer like me can do it and find some directions on how to.
2 up front on either side, 2 at the back on either side and 2 under the cup holder. Once it's loose and out a bit there is a harness to the lighter and traction control switch that has a plug. With the console out it stares you right in the face, a broken yellow wire. There is a pink and a yellow wire going across the bottom and drivers side of the shifter that go up the shifter shaft to the switch. There was no hunting for an internal break in the wire, it was completely broken, insulation and all, just like it had been cut. I cut the pink wire too and spliced in an additional 2 inches on each by soldering and wrapping them. Put it all back together and everything now works as normal. No weird shifting problems and the +/- button works again. All in all it took about an hour and was quite easy. But without this forum it wouldnt have been near as easy!
I am from GM Customer Service. Can you please email me more information on your vehicles concerns, so I can look into your situation further? You can get my email by clicking on my name. Thank you,
Mariah GM Customer Service
I would recommend taking your vehicle to a GM dealer to have the vehicle diagnosed. Please keep me updated on your progress.
Christina
GM Customer Service
