Mutifunction switch for 1999 Olds aurora 45000
explore2
Member Posts: 6
I recently had parking lights fliker and the insterment lights staying on leading to battery drain and buzzing in the stearing colum. I took it to my local machanic and he told me it was the mutifunction switch repair and cost $779 swich being $600
is this possable for the multifunction switch to cost this much? and could it be something le$$ of a problem.
I found one at a local part store for $322. but the problem being the repairman said it cost him $600 from another vender.
Have you had any other electrical problems or leaks form antifreeze Dexcool?
I've used the Dexcool only. I had about 82K on my 1998 when I got the radiator fixed. A slight crack was located under pressure at the top neck by the hose which had probably been that way for about 1.5 years because I was losing coolant very slowly. Could smell it very sporadically but could never see a leak. Crack= it wasn't the Dexcool that caused it, nor had the car ever overheated.
Radiator part $339 with $187 in labor. Good time to check the water pump, thermostat, and upper/lower radiator hoses if they are original: $246 parts and shop supplies and $170 in labor. My local mechanic is not cheap, but the car comes back fixed first time every time. No bring backs and no breakdowns on the road.
Jack
The problem is caused by a small amount of grease inside the turn signal lever slowly flowing over time between the electrical contacts inside the turn signal - intermittently shorts-out the headlights or parking light switches causing them to flicker on and off.
Cheaper than buying a new Mutifunction switch is to open the existing one and just wipe away the excess grease.
