Changes for 2009 Impreza?
Those who dislike the DRL LEDs on the Audis also should not they are also found on the Porsches....
-mike
Motorsports and Modifications Host
Since all 09 WRXs are 5MTs they do have a viscous center diffy as have all manual trans wrxs up to this point.
-mike
What are 5MTs?
Also, would you say that generally speaking the all-wheel-drive system in a 09 WRX will be as good as the all-wheel-drive system in my 08 Legacy?
I don't want to unintentionally take a step backwards.
5-speed manual transmission
What do you have in your 08 Legacy? 5MT or 5EAT (5 Speed Electronically controlled Automatic Transmission) or 4EAT?
If you have an 08 Legacy w/5MT, then the center diffy is the same on the 5MT 09 WRX.
-mike
I need to make a quick decision, so really don't have the time to go over hundreds of messages, sorry.... I want to know what kind of issues this car have.... I already know the engine is a bit noisy (sporty car, I know), but other than that, being a revised model, and/or having AWD, are there any problems, recalls, or things to pay attention to?...
Thanks in advance!
Bob
The car we actually got a week later, the same '09 hatchback (basic), just a different color, but it seems to have the Auto-Lights feature.... The lights shut off when the engine is off, and there is no warning beep..... Which, of course is very welcome here (I've been driving cars with automatic lights for years now...)....
I checked the manual and the window label, but there's no mention of Auto-Lights.....
Bob
The question is, when we test-drove the other, comparable car a week earlier, we got that typical beeping sound when shutting the engine off with the lights left on? Or was the beep telling us something else?
Not sure? Are you sure it wasn't the car locking? If you hit the master door lock button on the driver's door as you exit, when the door closes, it will beep and the lights will flash.
Bob
I don't have the car with me, my daughter drives it (and she called me asking about it), but I sure will test it when I lay my hand on that car.....
Bob
Also, with the key in the ignition, the remote entry/lock system is disabled. It is actually quite difficult to lock yourself out of the car. If you try to lock the car with the auto-lock feature on the door, it will immediately unlock itself. The only way to "trick" the car into being locked with a key in the ignition is to get in, close the doors, lock the car, then manually unlock the driver's door only, get out, manually lock the drivers door, then close it. Yes, more than you wanted to know, but handy if you live in a cold climate and want to warm the car (without leaving it unlocked) without having an auto-start system installed. The one caveat? You better have the spare key handy! :P
BTW, you mention locking yourself out of the car.... Last time I had to drive an hour to save my daughter's [non-permissible content removed] was when, with her previous car, while loading the trunk with groceries she left her keys inside the trunk and then, when finishing loading, she shut the trunk's lid...... If your car doors are still locked, and you use your remote to unlock the trunk only, and then slam the lid close, then without your remote and/or keys -- you can't open it again, do you.... See, if that's the case, I'm offering here an excellent way to lock yourself out of your car ....
As to asking the dealer? I have been solving issues with my new cars by posting questions here and on other forums, not asking the dealers, who are usually quite IGNORANT about the cars they're selling.... We all know that....
Depends on the dealer. My most recent WRX purchase was from a Subie salesman who was very knowledgeable about Subaru products.
Bob
Haha! That's for sure! It sounds like, in your daughter's case, the car needs an auto-unlock proximity feature wherein the car is unlocked anytime the key and/or remote are within, say, a body's length of the vehicle. Fool-proof the fool. :P
But then if you first unlock the car doors, that also unlocks the trunk and it can be also opened, right? Then, if you close the trunk lid, you can still open it again from the outside, pushing that little pad (I love it...) under the handle, right?
So, in other words, it's safer for my daughter, loading stuff into the trunk (not much room there, heh...), to use the remote to unlock the car doors, not use the trunk lid opener. Am I right?
It is probably best if she hangs onto her keys. Although, if she did unlock all doors first, it could be a good learning experience for her to have to crawl through the car to get her keys out of the trunk!
