05 Malibu ?
I was wondering if any one could tell me if there is any recalls on a 05 malibu for the past year my powersteering will just go out on me and then I have to pull over and shut the car off and turn it back on and it is fine also for about the past month my gas gauge will start going nuts on me it will say it's full then empty and sometimes it will go past full and set off a code and I will get a cel and i reset the code and it is fine any help would be great .
you may need an ECM reflash or update....only the dealer can do that....as far as the AC goes....sounds like the compressor perhaps......but again...would get a second estimate....what does the 1200 buy you now?
I apologize that you are experiencing an issue with your vehicle. Can you please email me more information about your situation so I can look into it further? You can get my email by clicking on my name. Thank you,
Mariah GM Customer Service
I can check if there was a recall for you. I will need you to email me your VIN in order to do that. Has the blinker concern been fixed, or is it still present? I apologize that you have had concerns with your vehicle. Thank you,
I just replaced another blinker last week and now the same side headlight, not sure what is going on, but the mechanic thinks it is eletrical and if that is the case it has always been an issue. Can you please email me privately, it says not to post the email address though. Is there an 800# I can call?
Thanks so much,
Donna
In both my 05 Malibus, some blinker bulbs had to be "replaced", more
than once; when the cars were under the manufacturer's warranty, a
dealer "replaced" them.
The "replaced" above is quoted because I don't know if the bulbs were
replaced, indeed -- that was on the bill (paid by GM) and the blinkers
started to work.
With the car out of the MW, I had to take a look myself when one
blinker stopped working. Well, the bulb didn't need a replacement --
it was as good as new. I just had to fix it better in its socket. A
20-minute no-cost job if you read the manual first.
I would be glad to speak with your further about your concern. I clicked on your name and your email is set to private. You can email me and you can get my email by clicking on my name. Thank you,
