92 Cherokee v-6 4.0L won't start
I am not mechaincally savvy at all. Here is what I know.
Can any one out there help me out? I don't live on a bus line and my mom does not drive in this icy winter weather and I do not yet know anybody here... returned to area after 23 years in another state...
Battery tested at 12.6 volts
windows, radio, lights etc all work.
tried to start in neutral and to wiggle gearshift - no luck.
does not click, crank or attempt to turn over.
sometimes makes an air escape/vacuum noise.
here are some pics of a loose wire I disovered: please only look at problem 1 pics (unless you somehow think problem 2 could be causing the car to not start...
http://picasaweb.google.com/ranchokiario/CarProblems#
any guidance much appreciated!
pict 2 is where the shop reads pressures for ac unit
guess I don't need to be in a hurry to figure out where it connects to since it is freezing outside!
thanks for the help with that loose wire!
the answer to the pics are Problem 1 - this is the wire to the under the hood light. The light fixture was so mangled that it does not look at all like they would go together. Another cherokee driver on another forum recongnized it.
Problem 2 - it the differential breather hose... apparently it is supposed to be like that.
so, all problems are solved and I learned to use the multimeter to test my battery.
thanks much!
