Clean water leaks from blower under Toyota RAV4 glovebox.
Saw a post that was very close, but need to find the exact place to clean drain tube.
and thanks for looking.
2003 toyota rav4 leaking clean water frrom passenger side blower just under glove box.
Spoke to my brother who is a mechanic (several states away) and said to post in forum to get ideas on where the drain nipple/condensation hose is (that it is being blocked and causing the condensation to overflow/backflow - so I could diagnose, and probably clean/fix it myself. Problem is locating this system/hose/nipple with out tearing up all the carpet, etc...
Another post mentioned the roof rack, which I have but do not have a moonroof.
Any suggestions would be greatly appreciated.
Rich
Rich
If you pull down the rug in the front area of the passenger side - you will see a rubber tube (on the left side at just below the rug) which is attached to a white plastic tube going through the floor board. - do not disconnect there yet.... I did and got a lot more water in the front passenger area. (Damn)...
I put down a towel behind the right front tire, laid down to get under the car to look for the tube coming out of the floor. There it was... the white plastic tube then connected to another rubber hose that went into a clamp... I disconnected the rubber hose from the white plastic tube that ran through the floor board....
Once that was disconnected, the water ran out, and geese, there was a whole lot of water... I was sooo relieved....
Alas!!! I could see a spider had made a nest in the tube, which caused all the backup of water........ This may not be where your issue is, but it is clogged somewhere in that tube system, so if it isn't in the one outside the car, then it's in the plastic tube going through the floor board, OR the rubber hose in the car that this is connected to.
So cleaned this out, and put the car in the sun with the door open to assist in drying out the carpet and pad underneath... I also sprayed the carpet with a disinfectant to kill germs and reduce the smell...
Man, I hope this helps, I was really freaked out about this. I hope this helps.
Let me know if you get this fixed or need any more info.
Good luck, hope this works for you.
http://rav4faq.kerkerinck.de/xa3/tsb/files/BO021-06.pdf
:mad:
thanks for the tips. My 2006 RAV4 had also this problem last week. Based on your suggestions I got the tube out of the floor; blew air in using a foot pump and solved the problem in no time!
Pull the hose out and either flush it or run a wire thru it.
I would recommend NOT blowing any air through the end of the drain tube while it's connected to the white plastic reservoir. Instead of removing the debris, you would just force it further up through the air duct that leads toward the blower. That's a perfect recipe for plugging the AC drainage tube all over again. Better to vacuum the end of the drain tube to remove debris out of the reservoir and duct.
So if you have a plugged AC drainage tube, you may want to check your in-car air filter to make sure it's installed correctly.
