Volvo XC90 Start Problems
It happens randomly. When I turn the key to position III (ignition) the car doesn’t start. All lights turn ON, but the starter doesn’t even click. I have to turn key off, wait few seconds, turn the key again and HOLD it in III position for 5-10 seconds. Sometimes it starts from second-third try. Does somebody have same problem? Thanks
There is a reciever in the steering column that sometimes goes bad.
also one more question: i have this message tells me on display " Coolant low, stop engine"-- what do i need to do? also " time for regular service"--??
please help i have no knowledge about any car.
The service message is telling you to get your oil changed.
How many miles did it have when you bought it?
As to your noise, it is quite possibly the auxiliary air pump. They can be a bit noisey. It doesn't necessarily mean anything. If it gets worse, then you might worry.
