2 MECHANICS AND NO ANSWER..?ALOT OF BOGGING..HESITATION..HELP!
grandprix34
Member Posts: 2
in Pontiac
I have a 2001 pontiac grand prix SE MODEL....The car has 97500 miles...car ran great till about two weeks ago...brought it too one mechanic and he didnt know what was the problem and did not want too continue with the work for some odd reason.
So the second mechanic did a full diagnostic and saw no problems. He then did a full tuneup that was well needed but still the problem seems too be there...I will describe the problem now as best as i can.
When i step on the gas from a dead stop the RPM lets say go too 3 but the car does not move as its supposed too, lets say the 0-60 is not there.....It takes a while for the car too get too 60.There is also a loud noise coming from the car when i step on the gas....I also find it strange that engine sounds fine its only when i press on the gas the car does not move and the words that i can describe the engine too be doing is "BOGGING" AND "SPURTING" "HESITATING".I really like too use the car still but this is unsatisfactory for me too drive 100 miles a day in...
What do you think is the problem?
Have you ever heard anything like this?
Any suggestions on what i should do?
PS: I also seen this problem happen alot more after i changed my fuel filter?
ANY HELP WOULD BE APPRICIATED THANK YOU!!!!
Mine would hesitate at a dead stop and while driving at city and freeway speeds. At a stoplight, the car would even lurch forward slightly and the tach would jump while my foot was on the brake pedal. A diagnostic indicated that the Mass Air Flow Sensor (MAF) was receiving intermittent signals and a replacement was suggested. This sensor is located on the air intake and is very easy to replace. I Googled a schematic of my engine, went to UAP, bought and installed a replacement unit which solved my problem immediately.
If this sounds like your issue, replacing the MAF may give you relief, however, you should get a diagnostic done to confirm this before committing to a new sensor ($200+).
A full "tune-up" isn't really required on cars these days - whatever "tune-up" really means. I also find it odd that you say your mechanic would go no further with repairs. Did he install the fuel filter? Do you have custom mods? This may be why he hesitates to continue working on your engine.
Also b4 you go buying a new sensor, there is an MAF cleaner you can buy from the parts store for around $6 that might not be a bad idea to try 1st. I have used it with success twice now on 2 different vehicles.
I don't know what you mean by "full tune up" but I assume it means air filter and spark plug change, maybe wires and fluid checks. I just wanted to say that YES that still needs to be done even on todays cars so don't listen to anybody who tells you otherwise. That is if you dont want your car to be in the salvage yard in a few years. Good luck on fixing your current issue.
