jaguar s-type NEED HELP ANYBODY
Does anybody know What is the torque on valve gasket bolts jaguar 2001 s-type 4.0 v8?
thay sed thay add done the" AIR FLOW FILTER " an some thing to do with the TURBO" .
an thay sed if the light came back ON . we add to have the tank flushed .
we add a code reader on an still no codes came up . we got advise to have the "D.P.F " filter removed.
so add this tUCK away an turned off on computer .the bloke that tock the dpf filter.
off sed the car add no code folts .but still the restricted performence light on .it drives ok .
we are not geting no wear fast keep asking difrent forams but no look .
we tested the "BATTRIE" an the "AIR FILTER" an " AIR MASS FILTER" an also "DEISEL FILTER " which was all fine .
an the "E .G .R " valve .turned off aswell .
the garage that did the "D.P,F FILTER" sed the engine was runing fine an nothing wrong with it .
CAN YOU HELP THANKS .
