Toyota Sienna hatch problems with struts
The struts on my 2006 Sienna have been replaced once and now I need to have them replaced again. It has 63k miles on it. Between the tires, struts and number of times I have aligned the RFT tires I cannot believe the whole car hasn't been recalled!
Curious to know other's experience with the hatch struts...
5
Toyota issued a tech service bulletin and limited recall on struts used in association with the power rear liftgate as it has the potential to damage the motor and raise the cost of repair considerably. You could say that doing this was in their own best interest as it saves them bigtime on warranty expenses should you subsequently fry a motor. For those of us without power lift, it is merely an inconvenience and doesn't appear to be on Toyota's radar.
Runflat tire issues are an industry-wide issue of consumer discontent, and not something specific to Toyota. Just talk to any Honda Odyssey owner with PAX tires. Although the construction of the tire is different (PAX requires a special wheel), the end result is the same. Poor ride, short life, high replacement cost, unavailable when you need a replacement.
At least with the Toyota system you can mount conventional tires to the stock rims and just add the spare tire kit behind the 3rd seat. It's an added expense for the hardware kit and you won't be able to drop the left seat, but at least it is an option.
As an aside, when I was waiting in th eservice area, I overheard the service rep talking to another customer about about the RFT tires. The rep said people are getting 15-20k miles from the tires and a lot of customers are changing over to conventional tires. They offer a kit for $1,300 but you cannot put down the 3rd row after installing it. In my opinion, they should offer it for FREE. Sorry, but putting down a $1,000 every 20k is unacceptable!
Hope is helps others...
The basic kit is not that bad (under $400), and still under $800 if you want the fancy trim cover.
Wheel 42611-AE050 $100
Tire (T155/80R17) $200
Carrier Assembly 51900-45010 $15
Clamp Nut 64777-32030 $13
Protector 64778-08010 $12
Optional Spare Tire Cover Deck:
Gray 58410-AE010-B0 / Oak 58410-AE010-E0 $410
There is a Sienna spare wheel & tire listed on eBay right now for $190
According to Toyota, the part has already been replaced under the recall so they won't replace it again. In my mind you have a failing part already recalled once. It is failing again and a major safety issue. The door continued to close on my husband who is not a small man and it took quite a bit of strength to push the door back up and off him. If it had been my son who is 9 it would have been a major injury.
I called Toyota and was given a "case number" but no corporate authorization for repair. I was told that it is up to the regional service manager if the part would be replaced. When I pressed what recourse I have as a consumer if the regional manager does not approve the repair, I was told none.
I urge anyone who is having this problem to take the time and report it to the NHSTA. I just did and it took 5minutes. According to the representative, if a recalled part fails again, it is MUCH easier to issue a re-service on the recalled part. Given the nature of the safety issue he urged me to let everyone know to call or go online and report this problem.
I simply can't believe that given the nature of the recall, the safety issues involved and the simple nature and cheap cost of the repair, Toyota is not issuing a service bulletin and simply replacing the failing replaced struts.
The only other car I have ever driven was a Honda, who stood behind a recall re-repair, no problems, no cost. Why I came back to Toyota I will never know.
Please please please report the recall struts failing to the NHSTA!
http://www.amazon.com/Toyota-Sienna-Liftgate-Supports-Struts/dp/B0077HE8PM
