My understanding is that when the clutch is locked up the engine and the main shaft in the trans are locked as one. Then if you accelerate the clutch will come unlocked. This is with the lock switch enabled. In a steep decent there will be a low engine speed and high vacuum (small throttle opening), just like you said. I'm sure you have a valid point that failure is a good possibility I was just hoping for some first hand experience ("My fill in blank exploded with the TC clutch locked up...) I understand the lock up is designed to only work in high gear (like I said originally-opposite of a descent)
Sadly cars and other consumer products are made for the average and even the doltish operators so they last longer in the hands of the "average Joe". To my mind that doesn't mean that useful improvements can't be worthwhile. I sure the first Jeep engineer that saw a sway bar disconnect on a TJ probably had a stroke.
Anyway I'll probably do a disk brake conversion on the rear and continue to stand on the break pedal on those hairy descents. Thanks again.
Packaged with the Jeep were a couple of packages of nylon straps. I think 4 in 1 bag, some with velcro and buckles, and a couple more in another bag. I could not find any reference to them in the owners manual. Any idea what these are for? I used a couple to tie the rear sholder belts to the roll bar to stop them flapping in the wind.
Woody,
still searching for the perfect fold.
The Unlimited also comes with a strap with a hook at one end for securing the top when the Sunrider option is open. It's also mentioned in the owners manual.
The other 2 straps that came with the Unlimited appear to be the ones for securing the top when it is folded down. They seem to be too short for me, so I took the same straps from the Sport (which has a hard top only) and made longer straps for the top. That worked much better.
-Paul
Won't help you any on forward descents I'm afraid, as 99% of the braking load is on the front brakes. The standard drum brakes actually work very well, and rear discs on a Wrangler are of little benefit except when braking in reverse, i.e on a rearward descent.
However, there's lots of other stuff to spend your Jeep money on! :shades:
-Mike
Go to Advance and buy the OE replacement. These will likely "not" have a lifetime warranty. If you buy the lifetime warranty pads, you will soon be replacing rotors.
Use it for what it's worth.
-Mike
Quickie question... After a 4 day trip I started up my jeep and the brakes squealed the first 3 times I used them. I haven't heard a peep since. Should I be worried?
Also, tomorrow I'm putting in a sound system. I am installing for a low key but nice system that can run satellite radio internally and hook up to the ipod. I'm also changing out all the speakers except for the subwoofer. I'll send pics to show off the install in case any of you are thinking of upgrading the sound in your jeeps.
Thanks for any help you can provide!
No, perfectly normal. It's just flash rust on the discs. You probably felt them grab on the first application as well.
Any one, or all three. Could also be a failing sensor.
Start with the easy stuff and clean the plug and socket, then dry it, then use dielectric grease on the terminals when you reconnect it.
If it's still flaky unplug it, then short the ends of the harness plug with a paper clip or similar, then wiggle the wires again. If the light flickers the wires going into the plug are bad, and it it doesn't it's likely to be the sensor.
This would be my first off-road trip and this is my Daily Driver, so I don't plan on getting too crazy.
Here's what I have already:
1. Really cool looking Jeep :shades:
2. 31" BFG AT's
3. Gas Tank Skid (factory)
4. Transmission Skid (factory)
5. Cobra 75 WX ST CB Radio
6. Front Tow Hooks
Here's what I'm thinking I might need:
1. Rocker panel guards
2. Oil pan skid
3. Tow Straps
If you can think of anything else, i would appreciate it. If you think any of the above is unnecessary, let me know. Saving cash is one of my favorite things.
Time is another consideration. The Jamboree is only 2 weeks away.
-Dan
2. Oil pan skid
3. Tow Straps
None are a bad choice, but I've rearranged the list in order of priority if that helps.
1: Tow straps
2: Rocker panel guards.
3: Oil pan skid.
You could also add a First Aid kit and bottled drinking water. Both are good for all occasions.
here's a list that our jeep club looks for on vehicle inspections in vehicles prior to events.
jeff
You have a real good start on the "necessities." Having that CB and tow hooks means you have the essentials covered, except that you didn't mention a rear tow hook. You really need a rear tow point, because it may be necessary for someone to pull you out of a "stuck" from the rear.
As Mac said, a tow strap should probably be next on your list, after a rear tow hook. You really are not supposed to depend on someone else having a tow strap, although it is usually almost a given that someone in the group would have one. Proper etiquette is that it is YOUR tow strap that gets muddy when you need to be pulled out, not someone else's.
Your factory gas tank skid is a joke, if you mean the original skid that came on the Jeep. I would not say it is necessary to replace it for just your first trip off road. At some point it would make sense, if you get hooked on wheelin', which is about 99% sure to happen if you go that first time.
BE WARNED! Wheelin' is addictive, and it usually only takes going once for the addiction to take hold of you.
I agree with Mac that rocker guards would come next. When you are going over big rocks or over logs, those rocker panels are often banged hard. Sometimes a good portion of the weight of the Jeep itself rests on the rocker panels. No way they can take that without damage, unless you have good rocker guards. I have Sun Performance rocker guards, and they are so strong that you can actually use a hi lift jack on them and raise one side of the Jeep off the ground. There are other brands that are just as good, and I'm not promoting Sun Performance over other brands. They have served me very well is all.
There is a world of stuff that will come later, but for this first trip, I think you would be fine by getting a rear took hook, a tow strap, and rocker guards.
If for some reason the rocker guards have not been installed, I would still go to the Jambo, if I were you. They usually take it pretty easy on newbies, so you most likely would not take damage.
Be sure and get a tow strap that has loops on the ends, NOT metal hooks. You'll want at least about 20,000 lbs capacity on the strap. You need that capacity, even though the Jeep only weighs about 3500 lbs. The strap has to handle "shock loads." Sometimes it is necessary to "jerk" a Jeep out of the mud. A steady pull often will just not get the job done.
I haved talked about mud in this post, and mud sometimes cannot be avoided, but I stay out of it if I have a choice. It takes its toll in the long run on the Jeep. Muddy water can get into lots of places where you don't want it to be.
Just get ready to have the most fun you've ever had with your clothes on!
Yeeeeeeeeeeehawwwwwwwww!!!!!!!
I want to hear all about this trip when you get back.
Tomster
Have you hugged your Jeep today?
P.S.
Check out my little website, Dan. I have a section for newbie off roaders.
http://home.earthlink.net/~tsjay49/
Yes, that's right, but hopefully it will just have been a dirty connector. If you do have to bleed the brakes it's not difficult.
Took the 04 "X" out early this morning and took my usual rough asphalt drive that I take daily toward the freeway, first thing I notice was that it took me a while to discover that I already was on the rough section. This Bilstein shocks really work great. On smooth roads, no noticeable difference. On moderate rough asphalt, is where it is amazing, I have not tried it out yet on dirt roads, but I think it woud be just as good. Compared to a stock Wrangler shocks, this improves the Wrangler so much, I wonder why Jeep did not make this standard equipment like Chevy does on its Z71 4WDs. As for handling, major improvements, as for the rocking back and forth or head toss, major reduction again, almost eliminated in some situations. Amazing value even if it cost double the Regular shocks.
However, I think sometimes it's just that I get to the question before someone else does.
Great advice as always. To any other off-road newbies like me, check out Tom's web page newbie section. Very good read.
It's official...I signed up for the Paragon Jamboree in Hazelton, PA. I can't wait!!!
As for the rear tow hook, what do you guys think of the kind that attach to the tow hitch? The guy that owned my Jeep before put on a tow package.
-Dan
the hitch pin is plenty strong enough, it would be what you used to hold the hook in the receiver anyway.
jeff
jeff
jeff
Thanks Paul :confuse:
That sure beats the heck out of an HP-35!
My wife has liked driving my Wrangler so much that I'm glad she's getting her own Jeep tomorrow evening...no, not a Wrangler but a Liberty Renegade 4x4 Rocky Mountain Edition. We deliberated about his one but decided having one Wrangler was enough and having a Liberty with a sunroof will satisfy my wife's desire for open-to-the-sky driving without some of the work dealing with softtop for everyday use...It's OK for me but she says she thinks her hands just can't take the work of dealing with the Wrangler zippers on the rear window each time she grocery shops. I suggested the Liberty and Grand Cherokee. She drove both and fell in love with the Liberty. She really likes how it feels like the Wrangler in the sense of feeling very easy to drive and gives her a nice upright driving position. She thinks it'll meet just what she's looking for in terms of feeling like a 4x4 vehicle but also still having a few extra "creature comforts". She thinks her Liberty will nicely compliment our Wrangler in our family.
I realize this is a Wrangler forum but just in case any one is interested with the employee pricing deals going on currently, I've included pricing on the Liberty below if any one is looking to add to their Wrangler family by bringing home a Liberty for their better half..."OK, now can I drive my Wrangler again sweetie?"
I pick up a 2005 Liberty 4x4 Renegade Rocky Mountain Edition tomorrow evening. Employee price I got was 4.5% under invoice before counting the rebate and military discount. Throw those discounts in and it comes to 14.3% under invoice! Pricing below:
Liberty Renegade 4x4 = $22,144
Trailer Tow Group = $329
4-Speed Auto = $743
Selec-Trac = $356
Trac-Lok = $257
SIRIUS Radio = $176
Loyalty Mailing = $25
5 gallons gas = $8
Customer Preferred Package 28Y = $392
Detroit Outstate DAA = $205
Detroit Outer PPA/EB-PF = $210
Destination = $660
Total Invoice = $25,505
Employee Price Before Rebates = $24,355
Price After Rebates and Military Discount = $21,855
Total Delivered Priced (incl. 6% MI Sales Tax on $24,355 and $23 title transfer)
= $25,839.30
Total Delivered Price After Rebates and Military Discount = $23,339.30
Also, the factory gas skid should be fine for a jamboree, but you'll want to replace it if you continue offroading. I had the factory skid on mine while wheeling with Tom (first time with my Jeep). I peeled it back a good portion as I came off some ledge on a trail.
I now run a Kilby skid and do not even think about my gas tank now. Serious peace of mind.
Rocker guards are nice, but as long as I've had my jeep and some of the interesting stuff I've gone on, they've never rubbed. Maybe I'm picking good lines. Maybe I'm not running hard enough trails. I'd get an engine/oilpan skid before the rockers.
Front and rear tow hooks are good, tow strap... all been covered. Food/water and first aid are good as well.
You may want to bring some tools with you - wrenches, screwdrivers, socket set, Torx bits, etc. In the unlikely event you break something, you'll have (most) of the tools to complete the job. If you're not mechanically inclined, at least you made an effort and somebody can help you. Your tools may even help somebody else who DOES break down.
-Paul
The bar and the zippers on the back window are a pain if you need access to the back all the time. That's the main thing I don't like about the soft top, and the reason I wish I had a garage, so I could have a place to store the hard top. I think next time we buy a Wrangler we'll get a hard top.
I finally took the hard top off of my '05 Unlimited yesterday :shades: (bought it in late March). It only took one buddy and myself to handle the top. It was a lot lighter and less clumsy than I had expected. Thought we'd take a drive to the Northwest Florida beaches, but only got to experience further the devastation of the recent hurricane (You'd think summer was perfect jeepin' weather in Florida, but you never know how a storm is going to affect you). We had a blast anyhow and got nice toasty sunburns. Unfortunately it was back to work today and the top went back on last night Just wanted to let you all know that I really appreciate the forum and everyone's insight into the jeepin' experience. I am a new jeep owner and having a blast; I especially like the waves I catch on the road here in Tallahassee (Go Seminoles!!!).
Keep jeepin'
I was thinking of getting an extinguisher anyway. just to have in the jeep
-Dan
