Hyundai Santa Fe Accessories and Modifications
Below is the website:
http://www.autoanything.com/deflectors/60A1051A0A0.aspx
How is the new dodge holding up?
How about where I can get daytime running lamps retrofit kits?
Thanks for any help you can provide.
Did you have to remove the tires to install the rear mud flaps?
No, left the wheels on and used a right angle screwdriver. A stubby screwdriver will also fit.
Like I said in my original post - "This was the easiest and fastest installation of mudflaps I have ever experienced." It doesn't get any easier unless someone else does it for you.
JCS
Also, would this void the warranty?
I just installed them, and you are absolutely correct about the ease of it all.
http://www.hitchmart.com/$spindb.query.hitchinfo-2.hitchview.87414
ANY HELP WILL BE APPRECIATED.
REH
http://www.koreanautoimports.com/store/index.php?cPath=31_27
Presently there is no extra charge for the xm feature on any audio package selected.Besides there is a $1000 rebate offered.There was no rebate in Sept.06 when I bought my SF.
We early buyers took a chance on a totally re-dsigned SF.
Wondering what other pre-XM owners thoughts are on this.
There is supposedly a up-grade package available,at your expenese available.But no one at my dealership has a clue.
See more Car Pictures at CarSpace.com
Thanks for the help!
Is there a way to lower the driver's seat so I will be sitting lower in the vehicle? I notices that the metal connecting the seat to the floor is raised a little.
There is plenty of legroom in the SF, by the way, for anyone my height.
Let me know if this works or you dont have these buttons.
I bought a drawtite trailer hitch and wiring kit with shipping $167 from etrailer.com
I installed it in an hour. on a scale of on 1 to 10 I would rate it a 5. I would change the oil no later than 3500 miles
I want to add an auxiliary audio input port for mp3 players into my new Santa Fe.My dealer says it takes $175/- to do this.
-Has anyone done this before ?
-If so how much did you pay ?
-Any problems with your audio system after you installed it?
I found the tail light signal hard to see as well so I replaced the tail lights with these. Much easier to see them now.
http://www.koreanautoimports.com/store/product_info.php?cPath=31_27_51&products_- - - id=492
Regardless of what rack you use, you should tie ropes or straps across the center of the canoe to the rack plus you should tie the front and rear canoe painters to the front and rear of the Santa Fe (hopefully there are some tow hooks or other tie down spots available).
If the racks fail, the front and rear lines will keep the canoe on the SUV. If the painters fail, then the lines/straps across the canoe to the rack will keep the boat on until you can pull over and re-tie everything. (I know this from experience :P ).
You can sort of see the lines on this old shot of my tandem Blue Hole:
link
This model comes with the XM radio. I don't wwant it to look tacky.
Can anyone steer me in the right direction?
link to CD Recorder
Anyone knows if it is available in dealer and how much?
I wonder if it is easy to install by myself.
