Mazda Protege5
Bruno
Bruno
Tire and wheel sizes can be confusing - what else can you conclude when width and aspect ratio ("195/50") are stated in mm while diameter ("16") is stated in inches? Wheel sizes are in inches, while offset is in mm ("ET30" stamped on a wheel means 30mm of offset). It's just a special language
I went with Borbet Type H 14in alloys for $75 each instead.
Kev, bliss vs. limited knowledge. NHTSA has always struggled to get it right. They either over generalize or make it mind numbingly complex.
"you know that pro's a real piece of crap because it has all these TSB's out on it. Should have bought a Civic!"
My friendly $.02...which I can't give you b/c I have to go shell out $400 for my stupid rim.
peace people....
I noticed it well before my current 1480 miles. I was scared bc I was thinking why is it misaligned so soon!? But people told me don't worry too much about it.
We are still working on fixing the rattle coming from my front passenger door panel or it may be coming from the seatbelt pillar. They ordered a part so I have to bring back my car next week.
Have a nice weekend everyone.
Bruno
First of all...the license configuration I finally decided on....dmv website was updated on Tues...and somebody took my choice! =( Scrambled to find new choices.
At the point of leaving the dealership...my mother(who was driving my old car back)...took it upon herself to toss her purse, sweater, and magazine on the hood of my nice new shiny car to search for her keys!! Yikes!. I had to go buy one of those special cloths to wipe/buff clean after.
Then...stopped at grocery on way home...parked all alone when I went in...came out about 5 minutes later and some big ol cargo van was nose to nose with my car...I walked up slowly...and started inspecting(while a woman was in the passenger seat)....fortunately...another woman had been sitting in a nearby car and said she watched and he didn't hit...she was thinking he was going to and made a point of watching...he was THAT close! At that point I thought I'd better not press my luck and get the car home!!
And Bruno....I never said the wheels were ugly! I just would've preferred the polished.
Sharon
Sharon
The dealer should have installed the wheel locks. Take them back and have them do it.
Bruce
by seminole_kev
Enuf said, lol!
Revka
Hatchbacks & Station Wagons Boards
Did anyone have a rattle coming from the rear driver side door? I can't tell where it is coming from, but I can hear it. Just wondering before I go on the hunt.
So then I brought it in again the day after. I test drove my car with a technician to pinpoint my concern. He says it seems to be coming from the b pillar/seatbelt area. Yesterday I picked up my car, I have to go back again next week because they ordered a part(nosed channel?????). Anyone know what that part is??
I heard it took someone 3 tries to fix a rattle. oh wells
Mnkyboy: I'm no electrician either, but that sounds like it may be hard to do...Good luck!
I noticed that when I started the car, the engine rpm would go up to 2000+ then go down to 1200. After about 5 seconds, it went up to 2000rpm and then go down to 1200rpm. Then it was kind of jumping/vibrating between 1200-1300rpm.
In short, when the engine is idle, it doesn't stay steady at a rpm. Is this normal?
The relevant Federal Motor Vehicle Safety Standard here is #108 (FMVSS 108). The text is publicly available on the web but is very dry. I've had to look through it and interpret it at my job.
Here is my read on this: There is no question that those front side marker lights need to be on all the time when the headlights are on. I do not see any reason why they couldn't also flash with the turn signal. You would need to replace the bulb in that front side marker (single filament) with a dual filament bulb. One of the two filaments should be attached to the ground and signal wire currently attached to the side marker. Then you would need to splice into the turn signal signal wire and run it to the second filament of your new dual filament front side marker.
You need to make sure that both the current front turn signal and side marker and the new side marker are the same type of light, probably 12v incandescent lights, and not some odd LED light. Also, small chance that you might blow a fuse on the turn signal circuit. It was made to run 2 lights per side and you are putting 3 per side on it. I work with large trucks and the OEM wiring is always very comfortably over engineered in anticipation of after market modifications. This might not be the case with cars. Your probably safe, but I can't be sure. In any case, you'll know pretty quickly. Also, whatever dual filament bulb you find probably won't fit in the socket for the current side marker, you'll have to be creative there. I also can't help you with which wire is which color, thats what the multimeter is for.
Does anyone else have these in their car? At this point I'm waiting until I bring the car in to have the wheel locks put on to ask if these things can be removed.
Sharon
But I'm surprised that your speed vacillates between 1200-2000. That's a huge range, and could mean lots of things.
Also, initial idle speed after start should be around 1450 or 1500. certainly not 2000.
I'd have your dealer look at this ASAP.
--Chris
Wheel locks. You can use the emergency wrench in your trunk, stashed with the emergency spare wheel, to remove replace one nut per wheel with a wheel lock nut. There should be a "key" that fits onto the heads of the security nuts. On the flip side of the key will be six-sided bolt head that your tire wrench fits over. You use the key to turn the wheel lock nuts.
You might want to invest in a torque wrench (and a longer-armed racheting wrench and socket) as well, so you can rotate your wheels yourself. I find most auto techs use air-driven power tools when rotating wheels. This can easily damage (usually by cross-threading) the studs on each wheel hub. I now do my own, after having to replace two studs for $45 each, and noticing some damage to three other studs (on my '89 323...nobody else is touching the wheels on my '99 Pro).
On the ISOFIX bottom latch stickers, if they look and feel removable, they're probably intended for you to remove them. They'd probably get stuck to someone's pants or shirt anyway, if they are like that. They're probably more for your initial info than anything else if they're not permanently attached to the fabric.
Mazdafun- you make me laugh....me? rotate my own tires?? That'll be the day. I'm just not mechanically inclined...and wouldn't trust my work even if I did make the effort! Thanks for the instructions though...maybe I caN FIND someone else that'll do it for me.
As for the 'stickers' I'm speaking of. I dunno if they are meant to come off or not as they weren't peeling off readily...and didn't want to push it. I'll just wait til I go into the dealer---probably tomorrow - hockey tonight(priorities!), and I'll ask them there.
sharon
Sharon - congrats on the P5. I saw two red ones this saturday, the car looks absolutely awesome in red.
Bruno
I've been waiting since May 1st, going to the mailbox like an expantant kid and coming away with nothing but bills (and AutoWeek). Bummer.
Can't wait!
-jim
