Just got a few cleanup details to do.
-Paul
Do the additional lights have a square reflector within a round one, or is it just an optical illusion?
The headlight beam/lenses are the same way and IPF's as well. The whole lens lights up, but the shape where I'm standing almost makes it look like they don't work right.
I think I could stand in front of the Jeep now and get a tan - at 2:00 am. :shades:
-Paul
Only until 2:05am when a neighbor calls the police about a guy standing in front of the Jeep in Speedos. :P
I'm using Hella E codes with the 65/55w (in deference to the wiring) 50%+ brightness bulbs. The improvement in both whiteness and pattern is dramatic. However, now the prices are becoming more realistic I'm thinking of keeping the reflectors but upgrading to H4 HIDs.
Me in a speedo *ACK*. I'm in Alabama, I'll go for the redneck tan.
-Paul
I found a beautiful 1985 CJ7 today. Appearance wise, it is superior. I am going tomorrow to test drive it. I am unsure of the mileage.
The asking price is $6k.
If I like the way it drives, I will take it to a mechanic to check out the engine.
Does anyone on this board have any advice or suggestions for me?
Not that there's anything wrong with a CJ, but a TJ is a much more advanced vehicle.........coils springs, fuel injection, better HVAC, better soft top design, etc. etc.
Mac's recommendation for a TJ is sound. I really like the ride on my TJ and it is a bit more 'advanced' and nicer looking on the interior. If you like the spartan, simplicity of a CJ, then by all means go for it. The TJ's would probably qualify as safer given the wider stance, airbags, 3 pt belts etc.
-Paul
I'm wanting to put a 4" lift on my 1998 Wrangler to fit 33" tires however i heard that with 4" lifts the angles of the drivetrain can effect the way the jeep drives. Can someone tell me more about this?? solutions? how big the problem can be?
Paul
Since the rubi sits 1" higher how much if any lift will i get from the OME with the HD springs. I was thinking the 2.5" would be for a regular TJ but i dont know. Just curious as ive got about 2 weeks before it will be installed. Thanks, Jeff
A better option would be a 3" suspension lift and a 1" body lift. 3" lifts are generally less expensive, don't have the steering geometry in a mess (4" and up may require a drop pitman arm, which can lead to bigger problems).
Rubicon Express, OME (my preference), Rusty's Offroad all do decent kits for this size.
My TJ has the OME kit with the JKS 1.25" BL and I fit 33's just fine.
-Paul
My OME netted me 3.25" but my springs were a bit tired, to be nice.
Most OME lifts net about 2.25" to 2.5", so I'd imagine you'd still get about 2" or so of lift. Measure the height between the top of the tires and the bottom of the fender flares on each corner BEFORE you put the lift on, then measure it again after the lift is on.
Even if you don't get a huge lift out of it, you'll still love it!
-Paul
Just wanted you to see the pattern.
-Paul
First, great choice with the OME kit. You won't be disappointed.
BUT, the Unlimited/Unlimited Rubicon have some differences that you should be made aware of and ask questions about. The HD springs that come as a part of the kit may or may not be right for your rig, depending on what you have on it. I have a 2006 Unlimited with an ARB Bullbar and winch on the front and a soft top. I installed the HD kit and found that it wasn't quite right (front sat about 1.25-1.5" lower than the rear).
I did some research and found that there were more factors involved and more options when it comes to the Unlimited.
The HD kit isn't made for the Unlimited, it's made for the SWB Wrangler. ARB/OME recommends a different spring in the back of the Unlimited. The one that comes with the kit is part#942 and the Unlimited spring for that size lift is part#949. It's a thicker coil, made for the extra weight of the Unlimited, especially if you consider putting on a hard top. That being said, I kept my 942 springs in the rear because I rarely carry more than a couple hundred pounds of gear in the back and never plan to have a hard top. The 942 is a great riding spring, but not what ARB (who makes OME) recommends.
For the front, the HD kit comes with part#933 springs, which may work for you, depending on what you've got up front. I upgraded to #934 springs (actually made for a Grand Cherokee) to even out my ride height. A little taller and stiffer spring, but for my Unlimited, with the heavy front end, they turned out to be perfect.
Since you haven't installed it yet, I would definitely ask questions of the shop you purchased from, down to exact spring diameters, heights and rates to make sure that they agree that you've got the right stuff for your specific application. If not, I'm sure they can get you the right springs and make sure everything goes in right the first time.
I mainly got the OME suspension system to improve the ride/handling and a 1-2 in lift would be a bonus for me. After reading your comments I hope the HD springs front a rear work for me but i dont know now. The tech said he has only heard good things about OME and said it was a good choice. The place had to put an order into OME for the system and is why its taking 10 days before its installed.
*I just checked my order and although it does not state exactly what springs #s its an OME system for the unlimited. I will probably call the store to double check.
I did not order the OME steering dampener, should I?
They really only mask problems that should be properly addressed. If your steering is set up right, you shouldn't need one.
Who'd ya order from?
-Paul
I had planned on doing the intall myself with my brothers help but for the price it was easier to let them do it for me.
In the past I had been using Diamond Offroad Customs when i had my 98ZJ lifted and really liked them but they moved about 65 miles from my home.
4wheel parts has been very helpful and has had the best prices ive found given the discounted price.
I did find a nice Bimini extended top for my unlimited for $24 on quadratech, they are having a close out special on this top and the channel was like $29, which was a steal since the bikini top for the TJL is around $100+$29 for channel.
Thanks for the info. I will not order the steering stabilizer as mine is fine...kinda upset though as its the easiest thing to install, LOL....might get it anyway to go with the yellow shocks with the OME kit...Heck im excited and looking forward to the OME system. Thanks everyone here for all the years of input ive read I know its been helpful to me. Jeff
I'll be keeping my Hella 'E' Code reflectors and adding a HID H4 kit. I'm still deciding whether to go with a type 1 (single HID bulb/single beam), type 2 (single HID bulb plus Xenon bulb/dual beam), or type 3 (single motorized HID bulb/dual beam). If I go with type 1 I'll be adding a pair of driving lights for main beam.
By the way, you are going to re-spool that winch before you put a load on it aren't you?
The worst part was when it was new. I hadn't redone it before its first use and boy was there slippage. It is just the top layer that is laying ugly and 'loose'.
Once I spool that out and connect to whatever, the underlying layers are nice and tight.
-Paul
As you know im getting the OME susp system and would like to run 33's as their is a nice special on tires right now, Plus i like the look with 33's. I dont know if i would need the body lift to run 33's with the OME so if its something i can put on great, if not i will have the install done at the same time as the OME is completed. Thanks Jeff
I have the TrXuS MT's (Mud Terrains).
The Body lift is easily doable at home in the driveway. I used a socket wrench for most of it, floor jack, etc. For the grille snubbers, I removed the headlight holders so I could get a pair of pliers in there to pull the ends through.
With the OME, you CAN get by without the BL, but you better not be going offroad. For any kind of flexing, you'll really want the BL.
-Paul
33" tires are big enough to contact your fenders and other parts and can do some serious damage if you don't put enough clearance between your tires and the Jeep.
The body lift is the way to go and is definitely something you can do yourself.
-Paul
Would anyone be able to post the text or intent of the TSB?
If your steering is right on, a steering dampener (steering stabilizer) shouldn't even be required. I would think there is more to it, but perhaps I'm just over analyzing it.
-Paul
i installed a new (well, rebuilt) motor yesterday, got it all in and turned the wipers on. they moved smoothly across the windshield... once. then nothing.
i tried to make sure the drive arm was in the same position as the old one when it went on. is there any trick to installing these that i should know about?
thanks for any help.
Michael
If the power is good, you may want to ensure the wiring is indeed good/non-damaged and all connetions are solid. Some dielectric grease at those points will help, as well as keep moisture out of there. I have experienced situations where wires/cables have gotten eaten due to various things (mainly battery acid after a rolled my Jeep).
If the power is good, I'd remove the arms - wondering if they aren't quite where they need to be and somehow obstruct movement. Then engage it to see where it stops/starts as it goes back and forth. Then do test fits of the arms to get them lined back up properly.
If the rebuilt motor is indeed bad, I would think they'd honor a warranty and replace it.
-Paul
Also, it may sound like a stupid question, but is there a risk of having the spring pop out when the sway bar is disconnected and the wheel is articulated to the extreme position? I am not sure there is 1 or more spring retainer in the front for securing the spring. If I am not mistaken, there is none in the back. Does this mean you can't disconect the rear sway bar at all to avoid the problem?
Having a helper there is good because you can have them reach up with the bolt and you can start threading it right away, since they have those nuts that can slide around a bit.
As for the spring popping out, yes it can be a problem IF your axle droops too far. Between the bumpstops, shock length, and the spring retainer clips, everything should be fine unless you installed a shock with too long of travel. You can fix this by installing limiting straps. In back, since you don't disconnect the rear sway bar (It gets VERY squirelly if you do), it isn't an issue.
However with a 2" BB and 1" BL, you should have no problems.
There is a writeup for the JKS body lift at http://www.mudinyerioffroad.com/jks_bl.htm that covers the process for a typical body lift.
-Paul
What year is your TJ?
For example, fuse 17 is the wiper fuse in a 2004. Your manual should have that information and it should be printed on the fuse block behind your glove box.
There are also some relays in the PDC in front of the battery that may affect it, but if it is only the wipers not working, I'd check the fuse behind the glovebox.
-Paul
The BL/MML combo is VERY popular to do at the same time, but it is NOT required to do both. Your call.
As for the adj track bar, I did NOT get it initially when I did the lift. You will be okay without it, but your axle will be shifted towards the driver side a BIT, which could cause rubbing when turning. My budget just didn't allow for it at the time.
However, I added the JKS adj front TB late last year and the rear trackbar early this year (I had problems with the trackbar bracket staying on - MY FAULT).
Looking back, I wish I had just gotten DPGOffroad's ultimate kit, as that is basically what I'm running now - I just installed it over the course of 18 months, bit by bit.
-Paul
I checked with parts house and they are still waiting on the 2 rear springs from OME which should be in by mid next week. Im scheduled to drop off the jeep on April 6 for the install.
I ordered the JKS BL and MML as a combo sale for $179 free shipping from the 4x4rockshop friday. Im hoping to get it this coming week so I can install it next weekend before the OME suspension system.
Just crossing my fingers no Vibes.
The JKS is even supposed to make the driveline angles better, so the odds are very slim that you'll have anything but a great ride, on road and off.
Good choice going with the JKS combo. Let us know what you think once everything is in.
I hooked my CB to the AUX power line behind the glove box.
The Switched line worked fine, but the unswitched wasn't providing power.
Do I need to change a fuse?
I assume this line leads up to the fuse box under the hood? or is it simply running to the one behind the glove box?
Any help is appreciated.
-Dan
-Paul
-Paul
Either way, his connection to the wire or a fuse are the most likely culprits.
I dont get to do much offroading. For one there is not a place legal within a 2 hour drive, and 2 with my own business its hard to find time to drive 2+ hours to offroad. So i want my Jeep to be trail capable when i get a chance to go AND look sharp like Pauls....
Thanks for all the help I really appreciate everything and i will keep ya'll posted on the JKS BL MML and OME system.
Jeff....
I don't think it's my connection. Once I realized it wasn't working, I simply just touched wires to see if the CB would power on. Nothing happened. I did the same thing with the switched wire (ignition on) and it worked. I'll have to figure out which fuse it leads to.
I subscribed to alldata a while back, do you suppose they have a diagram? I'll check it out.
They should have as it's basically a copy of the FSM put online. However, I just checked through mine and can't locate it (though that doesn't mean it's not there ). It's probably just as quick to serially pull fuses until you find the blown one.
Does the fuse blow if you turn on the ignition without the wiper motor plugged in? If so, the fault is likely in the wiring or switch. If it only blows with the motor attached then the motor is probably faulty.
