2005 Toyota 4Runner
Since the 4Runner is well over two tons, with much more of a heavy-duty ladder-on-frame steel construction, plus a significant ground clearance and ride heignt advantage, it would take a pretty large SUV (only) to put a hurt on passengers in any type of collision. 4Runner/GX470 crash tests scores are exemplary anyway!
Running to the Pathfinder is a severe overreaction! Worlds better than the '04, it has a flimsy, Exploder-like 3rd-seat, lacs 2nd-row legroom, has a cheap dash design, and no optional V8. And it looks like 3 different teams designed the exterior. And the Edmunds editors weren't exactly doing cartwheels over the ride/handling of the new truck. It has a ways to go before it an be a quality 4Runner competitor. It is a Pilot competitor.
DrFill
Jeez.
- Mark
Yes, Toyota does state that the side curtain airbag option is available on the SR5 model; however, the fine print states that it may not be available in all areas (as is the case in California). You can only get it on the Limited model here which is several thousand dollars more than the SR5 model.
I'm in Phoenix, which is in the "Denver region".
Enjoy!
-- Jim
Thanks for the info!! I was beginning to wonder where Toyota was really sending the SR5 models built with side curtain airbags. After reading your post, I went to the buyatoyota.com website and put in a Phoenix zipcode to see what option packages are offered on the SR5 in Phoenix. Well, apparently they offer exactly the options I want (curtain airbags, third row seating, etc.). Perhaps somehow a 4Runner with the option package I want can be diverted from Phoenix to a California dealership thereby avoiding having to do a special order... Anyways, something for me to look into. Thanks again for information.
I'm pleased I could help. :-)
Actually, after reading your post I decided to search buyatoyota.com to see if I could find a 4Runner equipped the way I want. Well, I discovered that buyatoyota.com requires me to enter my name, e-mail address, and telephone number. My concern is that I'll be getting e-mail and phone calls from local dealers - which I definitely do NOT want!
Can anyone describe your experiences with this web site?
-- Jim
I'd like to see such a list, because that'll help me decide on the options. For instance, I might go for my second or third choice of color if that's all that are available. Or I might pass on the 6-disc JBL system, if none are available locally.
Does anyone know how to get this sort of list, without actually going to the dealer? (One local dealer promised to get me the list when it was updated earlier this week, but failed to do so. When I called, I got a different person, who claimed there are no new V6 4WD Limiteds on the list. Maybe so.... but I'd prefer to be able to see the list myself.
-- Jim
~alpha
I couldn't agree more! Let's see what the host of the day says. Your are also correct that even though you check the box to remember the password, it doesn't.
Personally, Im just very happy that this service is provided to us for free. And since its free, I dont really feel the need to complain about this particular issue. That said, RIGHT NOW, there is an opportunity to give feedback to the edmunds.com folks, open your eyes and look at the top of the screen. See the big banner that SCREAMS "TAKE THE EDMUNDS SURVEY... WHAT DO YOU THINK? HOW ARE WE DOING.."
~alpha
"I'll take 'things that are annoying' for $500, Alex."
Please post comments in our software topic instead of spamming the vehicle-specific discussions with your complaints. By the way, it's a bug that's being worked on, not an intended "feature."
Now that you've made a mistake by posting in the wrong discussion, shall we "fire" you from the forums?
And now back to the 4Runner.
Kirstie_H
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Aren't the 05 V-6's exactly the same as the 04's except for the 5-speed Auto? Salesman said "oh-no ... the 05's have a new improved engine". But then again when I told him I wanted to test drive 2 different 4-runners he asked "manual or automatic"?
Thanks for any documented info you may on this.
The V6 uses a higher compression ratio than the old V8 and that's probably the major factor in the added horsepower of the new V8; I'll bet the new V8 has a similar compression ratio to the existing V6. Variable valve timing and intake geometry probably make the new engine a little more efficient and yield a little extra horsepower, too. The weight is probably close to the existing V8 and the same transmission and always-on AWD are used.
Speculations: Similar to today, in real-world driving the V8 will probably get about 10% less MPG than the V6, but the gap might narrow a little. With its heavier vehicle weight and always-on AWD, 10% isn't much of a penalty. Due to the higher compression, premium fuel will be beneficial for top HP, but probably not required. The engine will probably breathe a little better at high RPMs, and acceleration at higher speeds should improve a little.
Some things don't change, though. Both V6s and V8s are heavy and not very aerodynamic, so lots of stop/go or high highway speeds (75+ MPH) will yield poor MPG barely above the mid teens. On the other hand, highway trips cruising at 60-65 MPH can give you MPGs (in the V6 anyway) near the mid twenties.
My thoughts, anyway. Other opinions?
Has anyone added daytime running light to a 2005. Edmunds list it as an option, the dealer tells me it's not an option.
Overall I think the engine is smooth and quiet and the slight tick really doesn't bother me. The brand new '07 I test drove made the same sound. Seems to be only the v6's that do it, aluminum block making more noise? Good luck with your ride, you ain't alone, don't start worrying just yet ksemedo!
One is called Classic Soft Trim.
Do a google search!
I have a 2006 4Runner with the 4.0 liter v6. The vehicle has about 12,000 miles on it and at about 8-9,000 miles the engine began to develop a noticeable tick. The tick is coming from the left bank (Drivers Side) and from what appears to be the center cylinder. The problem is intermittent but noticeable about 80% of the time. It does not seem to matter how the vehicle is driven but the tick is only noticeable when at full operating temp.
I have exhausted my resources for investigating this and have concluded that the problem is injectors or valve train. When using a stethoscope you can here it very well between the two cams above the center cylinder on the driver’s side. The right side has never sounded this way and has only sounded like a typical quad cam aluminum engine with normal valve and injector chatter. I have brought the vehicle into the dealer 2 times and I was told this was normal. On my third visit I was a little more aggressive and all the sudden they to could here this noticeable tick. The dealership suspected that this was the result of a bad injector. They claimed that they would need to contact Toyota about this before they could proceed with the repair. After 5 days (Long story) I was contacted by the dealer and they informed me that Toyota was working on this and that it may be linked with the manifolds or something???? OK, I believe that for about one minute. Considering that a manifold problem would not be so sporadic nor would the noise be so centralized above the center cylinder.
I have attempted to solution this myself with doing the following:
1. Driving light, Moderate, Aggressive to diagnose or eliminate a possible valve timing/VVT-I issue.
2. Converted to Mobil 1.
3. Different fuel types including blends.
I could type all night explaining how I have tried to solution this and have came up empty handed. I would like to add though that this is my first post and thanks to all of you and this site I have been able to research and educate myself on some of the issues.
Can anyone help and does anyone have a detailed schematic of the valve train and injectors for this engine. I would like to continue to document and develop my theories?
The TSB reads;
"2005-2006 model year Tacoma vehicles........."
"Some customers may experience a ticking or tapping-type noise from the engine area at 2000-2500 rpm during acceleration that is most noticeable after a cold soak. New exhaust manifolds have been developed to minimize this condition".
Part numbers for the (new) exhaust manifolds are;
RH, 17140-0P070
LH, 17150-0P070
Gaskets (2), 171173-0P010
Warranty Code, EG5027
I like Toyota products so I would think the 4Runner would be a good SUV. Also, how are the cloth seats as compared with the leather? I'm looking for a comfortable ride and a pretty quiet ride also. I appreciate any help. Thanks!!
Steve (Jeepster53@aol.com)
The 06 I bought had less than 30k on and was maintained at the dealer so I had access to the records via my salesman. I paid less than 20k for it.
Brian
