Buick Regal Transmission Problems
I have a problem with my transmission, when I drive my car on the freeway it will not go on overdrive, even if I put it on overdrive manually. I had the transmission flushed and since then I have this problem. Where would I start to try to find the problem? I sure would like to know were to start looking. Could it be that something happen during the flush?
Additional thoughts: If you had what is called a Power Flush done, it's possible some crud that was once firmly attached to the inside of the transmission was loosened and is floating around clogging ports. No matter what, I'd definitely take it back to whoever did the work.
Are there some engine codes that cause the transmission not to go into the OD gear as a way of protecting the motor or keeping something from being damaged. I think I recall that from somewhere. I.E., if the motor is over heated the trans only goes into third based on the idea that a faster turning motor is able to circulate coolant and cool itself. Does the trans do same for trans temperature errors.
Does the trans shop that did the flush has the proper code readers to find out what part they affected or what's happening
I'd check the plugs and cables. It could be just aging catching up with the motor. Did it smooth out when you gave more gas before it downshifted? That still could be plugs and wires. The coils might be a source also. EGR valve or fuel filter is another possbility. Doesn't sound like fuel pump-I assume it's not been replaced. Has fuel filter been replaced?
i took the car to the mechanic today and he is pretty sure it is the ignition coil packs so you were pretty close on your predictions. he said hes not sure how many of them are going bad so i dont know whether i should just replace all of them or try and pick out the broken one or two. its about $80 a coil and labor is about $200. just wondering what you would do.
Might be time to price a different repair shop. I would replace the coil pack myself, frankly.
Check price at Advance auto and Pepboys.
But if you need for him to do it, I'd to the one that he says is bad. And then plan a different strategy for theothers if they go bad in the future.
Thought I solved the problem when the tranny shifted and ran quietly for 50 miles. However the noise comes and goes and now shudders slightly when I start out from a stop, then shifts okay.
Right now the car is quiet and shifts smoothly. However I know that the noise and jerking will come back. Anyone got any ideas?? suggestions.
Did take it to a transmission shop and the mechanic said it will need a total rebuild at a cost of around $2000!!! HELP!!!! A GOOD DEAL GONE BAD?????
Since I have changed the fluid and filter,250 miles ago, the fluid level remains full with no leaks..
Someone recommended that I try some LUCAS TRANSMISSION ADDITIVE.
As for the overhaul--I was told my 98 LeSAbre transmission was junk, all GMs are, and would cost 1800 or up to repair. He wouldn't know until he took it apart. Needless to say I got second opinion and 60K miles later we're doing fine without his repair. He must have needed a boat or summer home payment the day I went in for professional opinion! :P
I would just keep asking if it continues to use trans fluid. Maybe it just didn't get exercised enough.
I think all trans shops say a trans will need a rebuild even if it's not got a real problem.
Stick with the General...He want let ya down :shades:
Before agreeing to a new/used/rebuilt transmission, I plan to add a transmission additive (LUCAS) and drive it for 100 miles plus if possible, and then drop the pan and change filter and fluid again. This time I will crack open the tranny filter and examine for any metal particles.
The transmission repair shop asked me if I saved the filter after my first draining/refill and filter change. Unfortunately it went out in the trash. Repair people normally crack open the filter of problem transmissions and any debris/metal can help in diagnosing a problem.
Anyway, rebuilt transmissions range in price from $1250 to $1850 and that doesn't include core charge. Installation is extra.
The hoses, plug wires and everything under the hood looks like brand new. However, the water pump did have a leak and was replaced at 27,000 miles by the dealer along with the serpentine belt, battery plus oil change to the total cost of $722...
The last servicing on this car was a dealer oil change and 19 point inspection at 28,962 miles on 4/26/05. Cost $27.
No mention of low transmission fluid.
I did call the 83 year old that sold me the car and he was surprised that the tranny was down 4 quarts and that I was having a transmission problem.
I told him to make sure the dealer checks the tranny fluid in his new LaCrosse because my guess is that the dealer service department never checked it on this 96 in 10 years!!!! Can't lose 4 quarts in 1,030 miles when there are no visible oil leaks under the engine. At least I don't think so..
Previous owner had all records, receipts and was meticulous with the care of this automobile. Unfortunately the transmission may have to be rebuilt.
According to the repair manual you check the vacuum modulator by removing it, then, you look to see if any fluid comes out of the vacuum connection, if yes, it's defective. Then you do a vaccum test to see if the VM will stay extended when vaccum is applied with a pump. My VM leaked transmission fluid and nothing happened when I applied some vacuum.. It was totally shot.
I guess that's were the 4 quarts of transmission fluid went. Anyway, this Buick Regal is shifting smoothly, no stumbling/shudder and the noise is gone!!!!!! I'm really very happy that I don't need a transmission rebuild for $2000, which was what the transmission repair shop said was needed..
I guess my experience mirrors yours, now, if I can get 60,000 miles out of the car I'll really be doing great...
This car is turning out to be a good deal after all!!!
Trans changed how they control the shifts and pressures so some don't have the vacuum modulator.
I had no reverse, drive, or 2nd gear. the only gear working was 3rd. I also noticed trans. fluid on the ground. I had the car towed to a buick dealer and had to rent a car to get home. As of now I'm waiting for the dealer to fit me into his schedule.
I searched the internet and found a Tsp bullitien (tps-00-07-03-022c) with the exact symptions except for the fluid leaking out.
My regal has 59k miles. Has anyone had this problem?
Can sure use some help as a senior citizen.
Tony, thankfully nobody was hurt! The very same thing just happened this morning to me as I was driving my daughter to tennis. I have a 2000 automatic Buick Regal with only 30,000 miles on it. The whole bottom of the car sounded like it was churning and going to fall out! Then it would not go anymore and when I put it in park it wanted to roll back so I had to put the emergency brake on. None of the gears worked. There was no fluid leaking at all. Nor has there been. It was riding a little rough lately before this happened, for about the first 10 minutes of driving. It is now in a transmission shop. We have yet to hear what is wrong. I have to say, GM waits a long time for a recall on their faulty parts. We have owned exclusively GM cars and it seems we can spot a trend before the recall takes place.
Please post when you find out what is wrong and I will do the same.
I was told the transmission was beyond repair and had to be replaced. I had no recourse because the dealer was over 200 miles away. I picked the car up 2 days ago at a cost of $3500. (this included tax, labor, fluid, etc.)
I'm was thinking to call and report this to the Hi-way safety commission as being dangerous.
I being a retired mechanical engineer, took the old assembles apart and found the cable that brings the window up and down is to thick and binds on the plastic pully thats attached to the motor gear; on hot days it sticks. After a length of time the cable will pull out of its socket and the window will falls down.
I consider this defective parts and I think GM knows this.
Anyone any ideas?
Roy
Anyone any ideas?
Roy
Lately some more problems cropped up. Driving home in rushhour about 30miles stop-and-go traffic... the transmission was giving some ugly shuddering/slipping once at around 15mph and again somewhere around 20mph or so.
One more symptom, when coasting in stop&go traffic I'll start to brake and take the car down slowly to a stop ... right before it comes to a complete stop it will start shuddering again but will stop when the car is not in motion. Once i try to pickup again it will give some hesitation slippage but then go back to normal.
the 50-60mph slipping has been there for maybe a year now [over the period of 5~6k miles, i dont drive a whole lot]. When i asked the mechanics at GM they said for me to not change the transmission fluid, seeing how its current distressed state is somehow keeping everythign in equilibrium and if i were to get it changed it would open a can of worms. I've been able to confirm this judgement, but I would like to know if there is any prognosis that can be given as to how much life i have left in this transmission? at 128k ... i THINK the transfluid might have been changed at 100k [dad had it before me and I cant really vouch for him being mechanically minded and observant]. What i can tell you that at 70k this car had a transmission swap. So with 58k on the dial for this 2nd transmission ... any takers as to what kind of life expectancy im looking at?
Thanks in advance for all responses.
Maybe the rebuilt 4T60-E don't have a vacuum modulator?
I went to Mitchell's & the exploded view didn't even show the vacuum modulator, but did mention part 47 which was not on the view.
HELP, transmission shifting hard and not shifting right.
my 2000 supercharged regal , soon after 140k out of no where
started to slip and buck at about 40 to 50 mph it kind of started when i took the gas to pretty much 0 i barely made it to the station . i thought it was it . but next day it continued , the next got worse and a small whine came from the bottom, soon after ,like the next day , i drove my first 1/2 mile of the day and my transmission went in neutral all at once , no reverse no gears at all. i shut it off , after a short time the car was fine for another 500ft then the same . could a transmission go in 4 days with no previous symptoms , and all at once . please reply to egoist22@gmail.com
Is this a Speed Sensor Problem or something a lot worse?
Over the last couple of weeks the 95' Regal has starting jumping as it switches gears, more and more violently. As I was taking it to get looked at, it went out of gear completely into neutral while I was driving and I had to stop and start the car again to get it back into drive. When I got to the mechanic, they checked the fluid level and everything was full and fine as far as that was concerned - they recommended a transmission specialist.
Has anyone else had these problems? Any suggestions?
I love the car and have owned it for several years. It has 86 thousand miles on it and the transmission is acting up.
Sometimes when I go to pull out it will make a bad shuttering noise. If I let off the gas it stops. The car will start to move but the shuttering noise is bad. Once I let off the gas and apply the gas again it goes on like nothing happend. It only does it once in a blue moon and there is no rhyme or reason that I can figure why it is doing it. It shifts fine in all gears and drives like it always has. It is just this one thing. It use to do this when I would go from reverse to drive and hit the gas quickly. If I let it sit for just a second and then hit the gas it never did do it. Now it is doing it when I pull out off and on. I changed the fluid and filter about 10 thousand miles ago but when I did it the first time it made no difference. To me it seems like it is not fully engaging into gear or it is coming out of gear partially and then reengaging. Any help would be greatly appriciated.. :confuse:
Thom
