Chevrolet Cobalt Steering Problems
I was wondering if anyone has encountered the problem that I am having with my 2005 Chevy Cobalt. My first concern has occurred while I am driving in the highway. I am keeping a steady pace with traffic when all of the sudden my steering wheel begins to shake and I begin to hear a rattling noise. The noise ceases when I stop the car (meaning I pull to the side of the road), but since it is the 3rd time that it has happened to me, I am getting concerned.
Another potential problem with this car is the hubcaps. I find these to be very dangerous because since they are screwed into the lugnut, they have a tendency to loosen and loosen the lugnut as well. I have had to tighten lugnuts twice already because of this problem. Has anyone else had these problems? Please post any helpful information. Thanks.
This all assumes you have a completely factory car, no aftermarket wheels or tires.
The steering situation could be serious. Contact the service department as soon-as-possible.
Our Cobalt has begun to exhibit this behavior. The vibration increases exponentially when the brakes are applied. Occurs only on the highway after about a half hour of running, never on surface streets.
Haven't tried the dealer route yet as without a code or known problem they will be unable to duplicate so I'm hoping there will be more incidents showing up (selfish, I know).
I wonder what mechanics relied on before there were computer-stored fault codes... Get your car to a dealership and find out what's going on before you kill yourself (and/or someone else). If the vibration/shimmy occur for you, do not presume it won't occur for a tech under the same conditions. It's their problem, not yours - that's why GM issued you a warranty. (From the perspective of having no access to your car, what you're experiencing sounds like the possibility of a loose wheel.)
Have you been able to get this problem resolved? I am experiencing this same problem and the dealership does not know what is wrong with it either. Initially, I had the tires rotated and the car balanced, but the problem persisted. I was then told to change the breaks, break plates, and do a flushing of brake fluids - which I did not do because it costs about 250 dollars and which is NOT covered by my warranty. Honestly, I think that the dealership is just trying to find ways to take my money. The dealership never seems to find a problem covered by warranty. If they thought it was a balancing and rotation problem at first, why did they come up with another "problem" the second time around? :mad: I am going back there tomorrow, but I would like to know how you were able get this resolved - IF you did get it resolved, that is. Thanks.
IF ANYONE ELSE HAS EXPERIENCED THIS PROBLEM AND HAS SOME ADVISE IT WOULD GREATLY APPRECIATED. THANKS!
My first car was an '01 Corolla. I replaced the motor after 120 k miles and that has been the ONLY problem that I have ever had with that car. I baught the cobalt in December of '05 and have had 3 major issues with it. It just now passed 75 k miles.
Issue 1: I was driving my son around just to waste time and to settle him down because he had bad collic. All of a sudden my whole car starts jumping around like I had air shocks or something. The doors locked/unlocked, my rpm was jumping, all of my alerts were going off. I braught it in and they told me they had to replace the mainframe of the car computer. :confuse:
Issue 2: I hit a pot hole when going around construction (my bad) and I thought I had a bad oil leak. That was not the case, afterall. The person that looked at the car said that my oil was not low and there was not a leak. The leak was coming from the middle of my engine somewhere.
They tore the engine apart and noticed that the part that was leaking wasn't known to go bad until after 100 k miles. :mad:
Issue 3: Now my car has power steering issues. Everytime I start it and drive a couple of miles the power steering alert shows up and I can barely turn the steering wheel. In Walker, Louisiana, where there is no where to turn unles you want to go into a ditch, at every stop sign/light I have to restart my car so I can turn into my driveway.
All I know is I will never own a chevy again.
I was driving along a mostly straight road when the car veered slightly to the right. I steered to the left to correct it and completely lost control of the steering. I did not yank the wheel or anything, I was just driving normally.
I did some online searching and did not really find any reports of something like this. I did see that others had problems with the key getting stuck in the ignition, which happened to me a few times, but I am not sure if it could be related.
Another thing to note is that my engine and traction lights were on, and the car was brought in to the dealer several times but they could not find anything wrong.
Joel
---BE CAREFUL IF YOU STILL HAVE NOT HAD THAT LOOKED INTO, the dealer can read the log from the day you lost control to verify it. Mine was able to read that there was a miscommunication and loss of control to the tires. Your vehicle is very smart, but has errors like every computer out there. Make sure you have your computer read!!!! And as far as the t/c call GM if the dealer refuses to order it, they get payed well from our warranties!!!! please email me if your dealer refuses the problem I will talk to my dealer about it and Email you back!! tiffanniecastle@yahoo.com
And for all the people with the shaking problem when on the freeway, here is a word of advice. The dealer is the last place you want to get your vehicle serviced on unless it is covered by the warantee. They will never fix your problem, only make it worse. Shaking on the freeway after driving is due to balance, if it happens at a certain speed, make sure to eliminate all possibilities. If you are slowing down and the shaking worsens, that is due to warped rotors: which means that the brake rotors are mishapen due to braking- very common especially in non abs vehicles. If both those are taken care of and the car continues to vibrate violently, take it to a tire shop and have them remove the whole wheel and tire assembly one-by-one and spin on their balancer to check if any wheels bent. If there is still no problem and continues to do vibration, request to look for any bends in axle shafts. Depending on how many miles you have and how new the vehicle is, it should be waranteed by dealer.
Now all the balancing and diagnostic check at a professional tire shop, (not Big O guys, because they dont know what they are doing half the time....) like a Lech Swabb should take care of you with little charge. Balancing ~$10 a wheel.... rotating should be free if wheels are off.... and inspection of axle shaft (note just a visual, not removal because a real mechanic can just look at it and determine its bad) could range from $30 to $60. Not bad compared to what i have read from those on the forum spending money like crazy because dealer didnt know what the problem was either. If the problems still occur, even after that much work and time spent dealing with investigating, there still is hope with this last option. You probably got a defective vehicle and need to show all records, or receipts of diagnostics done to it and declare it a lemon. There are those out there in any make and model.
I just cant understand those that blame the manufacture for the problems that happen naturally. No tire ever stays balanced forever. No tire ever holds air forever so check it once a month to save gas.... Yes GAS, proper inflation extends wear and saves gas due to more friction caused by an underinflated tire on the road. And no 2 vehicles are the same so the supplier of the manufacture can give defective parts and can be replaced to prevent a greater problem. And last, being easy on brakes prevents warping of rotors because you have to realize that brakes consist of 2 metallic surfaces rubbing together to slow down, so they will eventually wear and need replacement. OE parts of dealer will wear faster than aftermarket, usually....
Hope that helps anyone. And help save money in these hard times.
I will never buy GM car.
I've lost track of the # of steering columns my car has had and various other steering or front end components. I have an 05 with 35K on it - I have had 56 warranty items fixed to date and there are still a number of items to be fixed. The steering has not been resolved yet & it is sitting at the dealership while I work with GM on what we do next.
You had 1 bad experience with a GM car and you're ready to send every GM cars at the scap yard?
I've been driving and buying GM products since 1974, changing my car every 5 years and only had minor problems (that's normal). I just bought my 9th GM truck and my next will probably be a GM (chevrolet) again.
Hey! by the way.... why make a big fuss out of it ? After 5 days, it must still be on warranty?
