Toyota Avalon Engine Questions
My mom took her 2000 Avalon in for 40,000 mile checkup and was told a pipe had melted onto the manifold and could not be removed. The entire manifold had to be replaced in order to pass GA emission testing. Two different kinds of metal were used in the original construction of the car and when the car was heated, the melting occurred. My parents are expected to replace at their own cost. Any other reports of similar instances and if so, how was it handled? Seems like Toyota should be responsible, doesn't it?
THANK YOU
Any suggestions or ideas?
I have no idea of why the fuel dilution. Do you know what percent is an acceptical level?
Questions:
How often do you change the oil and filter?
Who changes your oil and filter, Dealer, Local Garage, Self...?
What type driving do you do? Short Runs, Highway, City, How Severe?
What viscosity and manufacturer of oil? 5/30? _________
Do you use a Toyota oil filter?
Where do you have your oil analyzed for contaminets? How large of a sample do you retain for analysis?
How does the data you have on this engine compare with other vehicles you have driven?
I understand that many short runs, mile or two, then the vehicle sits for hours before other short runs will cause condensation and other contamination in the oil.
The fuel percentage may be troublesome. If this is an easy item to check, I would like to do this on occasion. Thank you for your information, hope you get a good answer.
I change the oil and filter every 3 - 4,000 miles. All changes have been made at the local Toyota dealer. I assume Toyota filters. They do use Mobil 5w30 oil. Driving habits are primarily highway/rural road driving, minimum of 15 miles with about 75 to 100 miles per day. Less than 10 miles of city driving about three times per week.
I use the Oil Analysis Labs out of Spokane WA. www.oillab.com They provide a 1-2 oz. sample bottle. They provide test results on 27 factors such as the physical data of the oil, metal concentrations, additive and contaminant products. They can diagnose the fuel dilution to 0.5% I have no idea what the Toyota specs are. Apparently, my shop manager has no idea either. He photocopied my report to discuss with technician but I never heard back from them.
I also have a 95 Geo Prizm which has the 4 cyl Toyota engine in it. It has 141K miles and its sample tested at 0% fuel dilution. In fact, it tested cleaner than the 2002 Avalon in most of the categories.
Until you get an answer, I will begin changing the oil on my wifes 03 Avalon every 2000 miles and submit samples for analysis. Before your posting, I was considering changing oil and filter every 2K miles, now with your dilution data I will do so. She only drives 6-8K a year so this will be easy to do. I always change oil at the first 1000 miles, then every 3000 after that. 2000 miles may be excessive but I want the car to last!! Also, I will begin submitting my 4Runner oil for same analysis so I will have a comparison
If you left the oil in until 7500 miles, wonder if the fuel percentage would be greater? And what damage might this do?
Does anyone out there have an answer for jc217 posting #17?
Did you ever get an answer to your question about the pipe melting on the manifold?
Did the 'check engine light' come on?
What 'pipe' actually melted? Can you see it melted? I may be presumtuous here, but it sounds a lot like a dealer trying to find a way to do big $$ work.
Did your Mom actually have any performance problems with her Avalon? If it was running ok, getting normal gas mileage...there's probably nothing under the hood that could melt that would impact emissions in GA or any other state.
I hope she shopped around for a 2nd opinion.
Regards
You are right. If there is nothing in the manual then it isn't required. The only unusual service items that I remember from our 2000 Avalon manual have to do with being in 'high dust' environments and lots of short trips in winter.
Call your dealer back and ask them what they actually do when they flush the engine. My guess they are talking about the cooling system.
There's not much you can do that I am aware of to actually 'flush' an engine. That's what happens when you change the oil.
Regards
Highly recommend you keep oil change reciepts and change within 5000 miles. A flush is normally a waste of money especially if you have been changing the oil. Just a great moneymaker for the dealer and since you have the 8 year warranty I would definitely not have an engine flush.
If the dealer suspects sludge them them pull the valve cover at their expense. Experience has shown that if sludge exists the flush will not help, it is too late
We should be out of the shop tomorrow with a bill substantially lower than any dealer would have presented.
While I was there, I asked about throttle body cleaning, and the tech said they sometimes get sludged up from nearby PCV crankcase vapors. This makes more sense than the Toyota service writer that said they need to be cleaned because gas gets them gummed up.
Does anyone have an annoying rattle that seems to be coming from the muffler area? Heat shields, clamps, brackets, all OK. I read on Car Talk that there is a "bypass valve" in the muffler. Any ideas?
If not, When will this modification be done?
To prevent possible sludging, should I use a synthetic oil like Mobil 1? I am scheduling oil changes every 2000 miles because of the fear of sludge. With Mobil 1 maybe I could go to 5000 miles.
Appreciate comments and suggestions.
While all those things said about the coolant system were technically true, usually the level in the overflow tank should stay roughly the same - if the siphon hose to the radiator is leaking, it can be replaced. Evaporation out the top usually does not occur because the cap of the expansion tank has a rubber gasket. However, if you get the car really hot sometime, and the system was already very full, it could expand enough to actually discharge a little out of the expansion tank on to the ground.
Bottom line: 2 inches a year is not a sign of a major problem, although it is a little puzzling once the level has been adjusted appropriately. Just keep topping it off. if it were a major problem, you would be losing a lot more than that.
randykidd: at idle when the car is in gear, you may feel a little jerking as the A/C compressor cycles on and off - the idle raises a little when it kicks in, in order to provide more cooling. So if the A/C is on, or the defrost, that is normal.
It's the same engine as the Camry V6, the Sienna, The Solara V6 and the Lexus ES300.
Do they any of them whine? I don't think so.
Ok so now I own a 2000 Avalon and am reading all these "sludge" posts about 2000 mile oil changes, etc.
So are there a bunch of extremely careful people on this website, or are Avalons really THAT hard on oil that it turn it to "Gel" ? Even modern oils? What about the "Synthetic Blend" oils or the "pure Synthetic" oils. Can I get 7500 miles out of them??
Or can I just use regular good oil like Castrol or Valvoline and dilligently change it between 4k and 5k?
Thanks for any responses
Toyota has warranted your engine against sludging out to eight years from the date it first went into service, regardless of mileage, so you do not need to worry much until 2008 anyway.
The sludge problem was overblown. They still have less than 400 engines out of more than 1 million that needed replacement.
By contrast Honda has already had several thousand fail out of the 1.2 million automatic transmissions they recalled this year.
I have the stock stereo, and have since replaced the back and front speakers with Infinity 6.5 inch coaxials in the back, and these amazing Alpine 6.5 inch seperates (SPR-176A) in the front. The total cost of the upgrade was less than 300 dollars, and the sound improvement is incredible.
I will add an amp and some kind of woofer/subwoofer system next, any ideas anyone?
this a photo from when I started my car this morning. This is actually a lot less smoke than it made over the previous few morning. it slowly declines over about 5 minutes till it is gone. the smoke smells strongly of burnt oil. I got out my receipts of the work performed under warranty approximately 1 year ago, and it shows they replaced all the valve stem seals. since this has happened again in only 1 year, with oil changes and maintenance being done always on time, and always by the dealer, what should be done to fix this once and for all? should they use the new redesigned valve covers and completely redo the top end of the engine? or should I insist they replace the engine completely.....
Its a shame to see that kind of smoke on such a shining looking unit.
My dealer tells me the only sludge issue they have seen was in a Sienna mini-van and the oil had not been changed in over 35,000 miles and when it was changed before that the person did not change the filter.
Avalon failed smog check because of "malfunction of vacuum valve in emissions system". Took car to Toyota Carlsbad: vacuum valve replaced @ $207; smog certification @ $58.
A week or so later Toyota Hdqrs sent warranty letter to me saying several emissions control functions in Avalon were subject to a new, extended warranty. One such was "vacuum valve".
Yesterday received a check for $257 from Toyota after I submitted claim under "new, extended" warranty. I'm a happy camper. Good on Toyota!!!
Come on toyota! where do you want to be in a few years? stand up and do the right thing. Stand behind your reputation, repair the cars. Do this and people will continue to buy your products. Sitting on your hands and blaming the customers for irresponsible engine designs will only propel other companies to the head of the charts in sales. Take a good look at Hyundai, they may just give you more trouble than you can imagine.
Does this seem reasonable? Has anyone reached 200K mi on a Avalon?
$315 seems a little much to replace it though...check a couple of independent places to find out their price.
I find it extremely interesting that since I had all my maintenance done at 3,000 mile intervals, and done by the toyota dealer themselves, that I could have a maintenance problem that was not due to design or workmanship. If sludge is caused by stupid owners, or quick lube joints, what happened to my car and why did they fix it?
BUT some people posted here at Edmunds that didn't sound like the ranting sort, that had engines maintained perfectly and still affected by sludge, so that pushes me back to leaning toward "poor design".
Either way, one thing is for sure - people who lease cars very rarely maintain them by the book. They know they will be turning them in in a year or two, and they just do enough not to get dinged with charges when they go to turn it in. That is why "fresh off lease" in the advertisement has never been much of an incentive to me personally to go see a car.
But for you wmunn, one thing is definitely in your favor: between the certified extended warranty and the special sludge warranty, you are well and truly covered for some time to come!
Is it just me? I have been very patient, and the comedy of errors continues. What do I need to tell the service manager to inspire them to get their act together and resolve the leaky seals? There is no lemon law in florida for used cars, however maybe I should speak with an attorney anyways. I don't know what if anything could be done legally....... I really don't want it to come to that. Both for my sake as well as the dealer's. I have never been an unreasonable person, however, I feel at this point I am being backed into a corner. Are there any qualified mechanics here that could explain what I should insist be done at this point? I have had a valvetrain overhaul, and a SPA sludge repair , and now the seals around the heads keep blowing out. It sure seems to me the only thing left would be a complete engine replacement, although the service manager insists he can fix the problem. sugesstions on what to do are welcome. I have lost all patience at this point.
Has anyone done it?
bjk
So what's up? Did the $6.95 oil clerk strip the plug, did they not getting it tight enough, or do all Avys leak oil?
What type of restitution should I get from the dealer Monday morning? I consider Saturday to be an abnormality - Monday is going to be a pain in my bumper.
