Can you elaborate on the wire. Just to recap the issues, here they are again.
1. Door locks operate by themselves while driving. (lock and unlock)
2. Key fob lock button does not work.
3. Key fob remote start does not work - probably because I can't lock the car.
4. Factory alarm automatically sets every time I leave the car. It flashes in the gauge area the padlock over the car picture.
Any additional words of advice would be great.
Kevin
Chuck
I am getting real tired of driving on a sunny morning with my sunglasses on and still have full headlights on. The damn sensor doesn't seem to recognize daytime. It does work any time after about 11am when it's sunny. But really seems to be defaulted to lights on way to much. Has been like this since new. And for some stupid reason big brother GM made it impossible to override turning off the lights in Canada like you can in the US. The only time we can override the lights is when in park, now ain't that useful?? I asked the dealer why it was done like this, he said it was mandated by the Canadian govt. Funny how Ford, Honda, Toyota, Nissan, and Chrysler don't seem to have to do it, just GM....MMMM the Canadian govt. must really have it in for GM.
My left turn signal just started showing a fast flash indicating a burned out bulb, which I replaced...The bulb lights up but does not blink when I try the left hand turn signal...Tried reversing the right hand bulb with the left hand side...the right hand side continues to work while the left although is lit doe's not blink...
Hopefully some-one can be of some assistance with what might be the issue and solution...thanks in advance...
Simon
the blinking is controlled by the ECM or BCM, dont know if you have a problem there or not....128K on my 04 Maxx LT
as far as the headlights burning causing a reduction in gas mileage......your belts are still turning always charging your electrical system.....regardless of the power drain...
It may be a relay or fuse(s), if you want to try swapping similar relays around and check fuses, go for it, but with electrical things I suggest just going straight to a reputable, independent auto electric shop. Good luck!
Is there some kind of clip or fastener that I am missing which are supposed to attach to these two square holes in the sheetmetal which are supposed to hold these two "posts" firmly, in order to keep the bottom of the lamp housing from shaking?
Anyone had the problem? Fix?
I also assume you tried this close to the vehicle to eliminate distance as a problem. Did it not respond at all (not light the headlights?) or just fail to crank the engine?
Also, I disconnected the car battery for a reset - no change.
So most items of the remote start system seem to be functioning except starting the engine.
Good luck and hopefully this is the problem.
No other problems - just no remote start.
On an older car I once had, the doors locking and unlocking by themselves was caused by water/moisture in the controller.
Hood interlock switch is attached to the hood locking latch.
Haven't determined if that's the problem.
I have a 2006 malibu maxx and recently both my fobs stopped working or they worked only intermittantly. When they did not work I could not lock or unlock doors or remote start. I replaced the batteries, but that did not resolve problem. I turns out that the metal clip that holds the battery is soldered to the circuit board and the solder joint broke, but not enough to notice it. Car was still under warranty, so dealer replaced both fobs and all is working again.
If car was out of warranty I would have tried to resolder the battery clip to the board myself before buying a new fob. I did some checking on internet and you can purchase them online for less than dealer cost, but only the dealer can program then to work with your car and they need all the fobs as they must all be programmed, even if one of them was working.
Have you checked the driver information center. A menu item in there lets you disable remote start. Make sure it is still turned on.
Also, remote start won't work if your check engine light is on.
I just tried to remote start my maxx with the hood open. The lights flash when you push and hold the start button, but engine does not start. That is what is happening for you, so the hood latch/switch is most likely the problem.
Yes
Also reajusted hood latch - loosened the bolts and moved it to different positions - no change.
I think the flash of the parking lights(if you get that response) indicates a detected fault on the input end, not output connections problems. I'm not sure where the remote control box is located but too bad you can't locate another Malibu owner to swap boxes as a test of whether the box internally is at fault.
Since your lights flash when you hold the remote start button on the fob, the transmitter and receiver are working (the BCM knows you requested a remote start). The BCM must also sense the following conditions for remote start to work: Remote Start enabled in DIC; Shifter in park; key not in ignition; 4-way flashers not on; door lock button pressed before remote start button; check engine light not on; no DTC codes stored in history in the engine control module. If there is a problem in any of these circuits, remote start is disable until the problem is fixed and the codes are cleared from the ECM. Unfortunately, you almost have to take it to dealer or some other shop with scan tool and knowledge of how this all works.
I'll check/jump the wires referenced to confirm the possibilities. All other factors mentioned are ok – the only other unknown, excluding the hood switch or wiring, is if any DTC codes are set.
If anyone has experience with a scan tool that is recommended – I could buy one and give that a try to check for codes that may be set, and for future use. I have a laptop, so a diagnostic system using a laptop or a diagnostic stand–alone device would both work.
It works for a week then kaput.
I'll replace again and see what happens. D~
you can get the socket at parts.....and its apparently easy to replace
Took the car to the dealer and they said it was a open circuit resistor on the blower fan. While waiting for the parts, the fan has been working fine.
Any ideas? Why an open circuit resistor would cause the fan to be intermittently come and go?
I once had the driver power seat not moving and it is fine when I brought it to the dealer. It's been fine ever since.
As I mentioned previously I do not have the manual. Perhaps someone else can help, but since you're under warranty I'd have the dealer make good on his work (tell him to be sure to wiggle ALL the wiring and connections this time while checking the operation of the fan)
First I went to Autozone for a free scan – no codes were reported. From the comments on this forum the next best guess was the hood latch/switch. It may be a common problem since the dealer had the part in stock. I Installed the new assembly and now remote start functioning again.
To save some cash maybe should have just jumped the wires that sqr5516 mentioned and not gotten new part.
Is there anything I can do without taking it in and having the dealership charge an arm and a leg?
not sure if you go through the interior or if you access through the wheel well??
I am having an issue with the Resume/Accel feature with the cruise
control on my 05 Maxx LS.
On a recent trip, the Resume/Accel feature would intermittently stop working.
Pressing the rocker switch up for the this feature would have no effect-no
increase in speed and/or would not resume a previously set speed. It would started working again after stopping for gas. It then quit working after a bit.
Can anyone point me in the right direction?
