Chrysler 300M: Audio
P.S. (F.Y.I.)
How to remove door panel / speaker access / Fix speakers.
In case anybody has to fix/replace speakers, or fix window rollup/down problems.
Remove metal speaker screen by prying it off.(Tricky part)
Remove 3 speaker screws and/or 3 panel mount screws.
Remove 2 screws holding window vent speaker, remove speaker.
Remove 2 screws holding Window speaker bracket.
Remove 3 screws along bottom of door.
Remove 1 screw in door opener, behind square plastic cover.
Remove 1 screw in cup of door handle.
Remove 2 screws below speaker, in the indentation part.
At this point, less I am forgetting a screw, simply lift the door panel up and away from the door.
You will have to detach the piece of plastic that holds the door lever rod.
The hardest part was that it took me a while to figure out that the screen mesh just pry's right off and snaps back in.
The speakers have a plastic cover with screening that needs to be pryed off. Using a screw driver, pry the plastic cover away from the speaker assembly at the speaker mounting brackets.
Bret
I had a problem with the door speakers vibrating. You probably want to make sure it is not those that are vibrating. I had originally thought it was the window speakers that were rattling. The small window speaker just come off with 2 screws.
I wrote up how to fix the door speakers on 1306-26111 & 26112. There is another msg about speakers on 1305-26088.
HTH,
Bret
Bret
Yeah, the manufacturer of the speakers did not use enough glue (Cheap Skates, Mass manufacturing). The tricky part of removing the door panel is realizing the screen covering the speakers just pops right off.
You can still repair the old speakers by prying off the plastic circular piece and gluing the cone back to the frame. Total cost is about $3.00 for a bottle of glue.
Later...
Bret
Bret
a few months ago my cd changer (4 disc) stopped working, not sure what happened, but it looks like a disc got stucked or something, because when I press eject it tries for a while and then displays an error message and moves to the next disc and so on.
I'd like to replace the cd changer, somebody told me that unless I use a factory model I will lose the on-wheel controls and I will only be able to control the new stereo via its own knobs, not sure if that's true?
And, since I'm at the subject, I'd like to be able to plug my iPod to the car stereo, is there any way I could do that? I've read on this forum that the 6-disc model has an aux port - that should do the trick, but is it compatible with my 2001 300M?
Also, how easy is to replace the cd-changer, I have little experience with this stuff, but I'd hate to go to a dealer and get charged $1000 or smth like this when I could buy everything I need off ebay and do it myself.
Yes, you will lose the use of the steering wheel buttons with an aftermarket stereo.
There is an adaptor you can buy to hook up to the factory radio that allows you to plug in MP3 players. I can't remember the company that makes it though, sorry. Do a google search or go to the 300M club website forums and search the Audio Upgrades threads.
I just bought a 2001 300M, and I love it. However, I was putting CD's into the player and the whole stereo is frozen and reads 1SEL. the 1SEL stays on even after I have taken the keys out of the ignition.... Any advice out there.
thanks,
The Paj
Mark
- Remove the lower seat cushion. Just give it a firm jerk upward on the driver and passenger side and it pops right out.
- Unbolt the seatbelts. Those bolts also hold the seatback in place.
- Get a good grip on the bottom of the seatback. Pull the bottom forward to clear the mounting studs then lift up on the entire seatback to unhook it. This is a very awkward procedure.
- Remove the C-pillar trim. Use firm, but STEADY pressure to remove the trim, otherwise you will break it or a mounting tab. Once you feel the tab pop out, lean the trim out at the top (toward the opposite side of the car) and lift out.
- Loosen or remove the lower trim beside the seatback. It's probably better to remove it. To remove it, you will have to take out the door sill cover. It just pops right out.
- Once the trim pieces are out of the way, slide the parcel shelf forward and pull it out.
Now you have access to the speakers. The steps to getting to the speakers will take you 20 minutes or less, depending on your comfort level. Good luck!
I have a 2000 Chrysler 300M and my “premium infinity” sound system is starting to become crap. The driver-side door speaker is all static/vibrations so I turned my front speakers off. However, now my rear speakers are starting to get a little vibration to them. I do not blast my speakers by any means, but by the sound of them one would think so. I have to admit; I am not car repair savvy so doing a personal repair may be difficult. I took my car the Best Buy and they told me that they would need to rewire my whole sound system for the new speakers. So I guess my questions is “Is it possible to buy high quality speakers and install them myself?” Or am I looking at spending some $$ to fix the problem. :confuse:
Thanks for the help in the matter.
Dont go to best buy for car installs. You will only have to go behind them and do it over.
1. I bought a new stereo for it and when i go to plug it in it turns on fine, but there is no sound coming from the speakers. I reinstalled the stock stereo and the speakers work as usual. How do I get the speakers to work?
2. I am hearing some buzzing from the mioddle dash speaker, but cant get the dash piece all the way off to access it for repair/replacement. How do I get that piece all the way off?
3. I am planning on replacing the rear speakers at a later date but dont know how to access them. How to I access them for replacement?
thanks.
