I have found things online about people having similar problems to this, but theirs usually involves the oil pressure dropping when they're stopped, and rising again as they accelerate. Mine happens regardless of acceleration or stopping, and I have no clue what it is. Could it be the sensor? Could it be caused by the leak? If so, where should I check for said leak? Please help. It's not just my car, it's my baby.
My 07 Grand Cherokee is now on its 3rd tow to the dealership with the EXACT problem that you had and i was hoping before i replace the starter (which they are assuring me that is the problem and i doubt that it is...) if your car is now running fine after replacing the solenoid wire end. Thanks for your list though! When i speak to the dealer tomorrow im quoting it verbatim!!
Thank-You!
It has a smooth idle but it seems to skip a beat or miss and I feel it it, and hear it. Then it is smooth, then it misses a few times and runs smooth... It will do it in Neutral and in gear. If in neutral and given slight acceleration, it will not "miss". I did a few bottles of injector cleaner (chevron) and the problem seemed to have stopped, but it returned again... The stuff I put in is 6 bucks a bottle and the way this thing chews up gas (16 mpg) adding a bottle w/ every fill up is too expensive... Is it a clogged injector? Is there another issue? Any one else have this problem? Is it a sensor? Any and all ideas are welcome!!! Thanks in advance... ABK
My jeep is having the same problem as yours along with several other people. I am wondering if you got your problem fixed with the Jeep transmission over temp and not starting.
by engine when running?
front or back of engine
pep boys
or auto zone sell a mech stescope with a long rod on the end, touch parts of engine (BE VERY CAREFUL THAT YOU DONT TOUCH MOVING PARTS) as it is running and the tapping will be isolated then maybe able to help you find prob.
SUVs and Smart Shopper
Once I got it home and let it sit in the driveway for about 40 minutes the truck would idle just fine then it just cut off on it's own. It has no codes or check engine light, can anyone please tell me what steps I should take?
I have a 2004 Grand Cherokee Special Edition Laredo. Sounds like I have a similar problem like yours but mine is misfiring in cylinder 1.
We replaced the coil and spark plugs, and then found out wrong "type" of spark plugs. My husband replaced the spark plug #1 on Saturday with the correct one, even though I think they all should have been replaced. Engine light went out but only to come back on today.
He also noticed my reservoir for the anti-freeze/coolant was empty. He just put some in about a month ago, when he put the new spark plugs in. No leaks on the ground/white smoke coming from the tail pipe.
I'm taking it in for inspection tonight since it's due, hopefully, they can tell me what is wrong with it.
Best test - most economical - is to disconect eahaust engine side of convertor and go do your hill climb.
Gonna be a bit noisy but if this cures it your Convertor is what is called BLINDED - Plugged.
T
I'm looking for some assistance with the above codes. They are the result of the Electronic Throttle Control warning and check engine like coming on. I've been able to reproduce the codes and warnings with hard acceleration, but also with steady city cruising.
I've reset the codes, numerous times, and also had the codes and check engine light reset themselves!
I've run fuel dryer, and fuel conditioner twice, because i thought I picked up a tank of bad diesel, without results. Latest has been to replace the fuel filter. The codes apparently refer to high and low pressure at the solinoid on the fuel rail. Of course Chrysler won't just sell the solinoid and would prefer I spend $1000 for a new fuel rail.
Has anyone run into this issue with the diesel?
your assistance is appreciated.
Thanks for the post. I am having the same problem with my 11 GC Limited 4x4. Service dept didn't admit there was a problem when I returned it within the first week of ownership back in early Oct. I've finally got them to admit there is a problem but they can't figure out the reason or how to fix it. They are waiting for Jeep Engineers in Detroit to get back to them. Glad to see I'm not alone with this issue... I hope Chrysler stands behind their product!!!
All...keep posting info on these forums and push dealers and Chrsyler for the fix. Just my 2 cents!! DB
Thanks for jumping in with your situation. I've been back to the original dealer who sold me the vehicle and now a second Jeep dealer with similar results and stories from the dealers. They are now trying to give me the same story that it relates to the EDO mode function. I will be talking to Chrysler rep tomorrow to voice my displeasure. As you mentioned, we paid serious bucks for this brand new vehicle and it is totally unacceptable to have this constant fluttering/hesitation. New Jeep GC 2011 buyers beware...
DC
Please let me know what the Chrysler rep had to say to you about this. Mine is scheduled to go back in on Tuesday the 25th. I have told dealer in no uncertain terms that I want answers....whether or not it does any good I will see. Even if Chrysler would just own up and say there is an issue they are working on, it then wouldn't bother me near as bad.
On another note...have you checked your front tire wear? I found feathering on the front tires starting around 3,000KM. It was to be checked last time it was in and they indicated alignment was NOT in spec in "Auto" mode (which is the default ride height setting) but when they switched it to "sport mode" it came into specs. I screamed bloody murder at them for this also and they are suppose to have answers regarding this also. Makes no sense to have alignment specs set in "sport" mode which lowers the ride height a bit especially when the default setting is in "auto".
Thanks for the reply and look forward to reading what the rep told you about running issue.
DB
