Are Chip Upgrades Worth It?
I own a '93 infiniti G20 and am considering making
several modifications to try and add hp and beef
up the performance a bit. I found a chip upgrade
at stillen.com for about $300.
Anybody had any experiences with using these chips
in an infiniti or other small cars?
See Also
Performance Upgrades: Are They Worth It?
See Also
DMK
Re. install it varies. It helps if you liver near a tuner. I was lucky. Wetterauer was only a hour from my house so I drove down and was chipped in less than an hour. If you can't do that the next alternative(and most common) is to mail in your ECU. Go to Wetts site for more info on this as well. Their address is www.chip-tuning.com
DMK
The Traction Control permits you to start and drive normally when it is on. If you turn it off, it forces the transmission to start in 2nd gear. If you put the TC back on, it will allow 1st gear starts again.
Richard Moore
'97 Eldorado Owner
I'm skipping the chip for my SUV -- it aint worth it, not even if I change the headers, exhaust, etc. (Translation: too much money for too little performance increase ... 'might as well get a sports car.)
Also since you have one of the older SR20DE engine, you might wanna try some JWT S2 camshafts, HotShot header, Unordothox Racing underdrive pulleys, Place Racing cold-air intake and a good exhaust system. With those changes and a JWT ECU programe, you can make 150-160hp at the wheels easy.
You should check out freshalloy.com, se-r.net and SR20.org
Tony
Automakers, beware: hot rodders do software, too
Steve
Gentlemen, Start Hacking Your Engines
Plus, he surely didn't buy a Civic AND make 300 hp on 8 grand.
Mr Aguilar did not have such restrictions. I believe this is possible, especially since Honda engines are rev happy. Pity there are not more technical details but I bet the 300hp are put out in the 7k range.
That article was written by someone who nows jack about cars and believed everything the guy told him.
The other question is "for how long?". There's no such thing as a free lunch, and the Viper and 911 Turbo come with warranties as well as proven track records of reliability: both should easily go a decade and 100K miles without rebuilds. You can pay now or pay later.
-hh
I'll give you a hint - his Honda came in on a trailer.
Bear in mind, also: 6,000 hp Top Fuel motors don't run oil coolers or radiators because they only run for 20 seconds from start, burnout and the race!
I'm not running a stock Cougar and my chip was burned to match the enhancements, so that could be a big part of why I saw improvements and the individual with the Focus didn't. The chip was the last enhancement. The car was dynoed before the chip install and after, so I know for a fact the chip did indeed help. That was 2 years and 36,000 miles ago. No problems at all since the install.
I programmed it for the 93 octane tune, (this is a dual mode 93 or 87 octane handheld unit) 5500 WOT shift points (top of the power band),...
(Stock shifts at WOT were 5200) ....5900 rpm rev. limiter,.......Firm shift mode,............Top speed 110.
All other settings left at factory specs.
SOP feel is killer !...........Nice burnout and 1-2 tire squeek at WOT !
Total pig stock...NO burnout or 1-2 squeek !
Data According to supplied spec. sheets:
Stock... 228 rwhp @ 5500 rpm......... tuned...263 rwhp @ 5500 rpm
Torque.......stock 226 @1250 rpm.......tuned 260 ft. lbs. @ 1250 rpm
Purchased mostly for a little more "pep" and a few more mpg...............
As soon as the novelty of whipping on it is over.........Will report how it
works out using the 87 octane tune and mpgs....................
I kinda doubt those figures of HP jumps because to get any substantial power you just can't keep adding fuel, you have to add air at some point. But most stock systems are made to run quite lean, for emission and fuel efficiency, and a good chip, along with a timing bump, can take advantage of that (to a point).
I suspect your MPG will decrease (really, it HAS to) but I trust not too much.
Also if a chip is leaning out at WOT and you are adding boost to the turbo, that sounds ver-y risky. Fuel is also a coolant as I'm sure you know.
And, yes, if you are increasing boost, the chip programmer needs to take that in to account. If you have a chip programmed for stock boost and then you crank it up, you may have the opportunity to rebuild your engine sooner than you had planned. A number of MR2 guys found that out the hard way. Heck, the programmer even needs to know what octane gas you are running. If you are in California and running 91 octane gas on a chip that was set up for the 93 octane gas available in other states, you may well be on the wrong side of the detonation limits.
Okay thanks for the clarification....yes, I was equating WOT with redline...duh....
I've heard 14.7 is not really ideal....more like 13.1 or so....
But at high throttle positions, when you go into open loop mode, the ECU will determine fuel requirements based on predetermined tables or maps. The mixture ratio will vary depending on several factors like load (or throttle position), air flowrate, engine speed, etc. Typically, the mixture ratio will be higher at low and high RPMs and lowest in the midrange RPMs where detonation is most likely. 13:1 is probably a reasonable value for a normally aspirated car. 12:1 or maybe 12.5:1 is the highest you'd probably want to go on turbo-or super-charged car.
Every factory ECU equipped car I have seen runs below 10:1 in the midrange RPMs, which is why a little leaning out produces some fairly significant horsepower gains.
That said (and of virtually no use), I'd be very, very leery of using that "chip" on my car. It really isn't a chip so much as a device that is external to the ECU. I honestly don't think it is possible to properly design a chip and sell it for $27.50. Real chips go into the ECU and alter the programming of the ECU. They require a lot of reverse engineering of the ECU programming and a lot of time on a dyno with a wide band O2 sensor. This is time consuming and expensive. That is why real chips typically cost around $500.
The ads for that "chip" don't tell you anything about what they do. I would suspect that based on the fact that they are connecting to the MAF, IAT and CTS, that they are merely altering the airflow input to the ECU causing a slight leaning of the mixture ratio and advancing of the ignition timing. This could be a recipe for disaster. It's not a matter of thinking, "Well, it is only $27.50. If it doesn't work it is no big deal." If you start detonating, it could get to be a big deal very quickly.
Frankly, I'm surprised that ebay let's them advertise on their service. The ads state that it doesn't affect your warranty because it can be easily removed before you bring it to the dealer. To me that is recommending fraud and I wouldn't think ebay would want to expose themselves to that.
Thanks!!
HERES A LINK :
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=1044235&imageID=25- 8588582&Mytoken=C7F101CB-A0A1-4846-B5674390A9575ED22639079390
As for the chips, you need to get their technical specs and read carefully HOW they achieve what they claim to acheive. For instance, are they trying to advance your ignition timing? Or do they merely extend your automatic transmission shifts (heck you could do that for free in manual mode). Is it a real chip or a re-flash? What proof do they offer for their claims? Who tested it for them? Are they impartial and independent testers?
You need to do your homework and the BEST thing is to talk to someone who has installed the chip and tested it themselves.
