-June 2024 Special Lease Deals-
Does any one have any experience with this???
Pete
Secondly I would question the need/value for any extended warranty. The manufacturers go to considerable lenghts to ensure the vehicles' systems last well beyond the standard warranty period. Whether it is Toyotoa/Lexus, another import/luxury brand or even the domestics they ALL have a "factory certified used" program that can and does warranty vehicles till 7/years 100K miles. They can do this because the ODDS are great that there will be NO warranty payable repairs within 100K miles.
Third, consider the cost of the coverage. Generally, the most prone to failure systems are the cooling system and elctrical accessories. If you had to replace the water pump it is proably about $600-- less than half what the extended warranty would cost, REPAIRS to an electrical accessory even cheaper -- (don't confuse the 'replacement cost' of the electrical accessory with the typical repair fee, a trick I've seen done many times when trying to convince of the terrific value an extended warranty offers...)
I suppose you could say that the warranty buys "peace of mind" but I'd argue that your choice of vehicle is greater peace of mind. Simply DO NOT buy a vehicle with lower than average reliablity!
Finacially the extended warranty STRONGLY favors the issuer. They make LOTS of money. That is why they can offer the warranty at all. Think about it, do you treat your car 'better than average'? If so the warranty should have 'fewer than average' claims with somebody like you. You would likely do better by depositing an amount of money equal to the extended warranty in an intrest bearing account. If any repairs are needed ODDS are strongly in favor of them being less costly than the amount saved up. After the repairs are done it would be smartest, from financial & emotional perspectives, to immeadiately sell/trade in the vehicle for a new model with new warranty and its new "peace fo mind"...
FINALLY it is NOT SMART to keep a vehicle that was purchased new past 5/years 60K miles. Doesn't really matter what kind/make of vehicle (excepting collectibles) the fall-off in value & buyers is VERY steep after 5 years. While different vehicles may depreciate along a steeper slope, it is smart to trade/sell when the gap between what your vehicle would fetch and a replacement's cost is narrowest (factoring in what, if anything you owe to the lender). Simply put, get rid of your vehicle while it can still help you get into a new one. I would suggest that you graph out the rise in new model prices vs. the 'retained value' in your used model. Low miles are an overated virtue, as the model year is a bigger factor in determining value. Right now the spread between your used RX300 and asimilarly equiped 2002 might only be 3 or 4K. (If you have a loan you probably owe much more than that...) When the 03 is available I would estimate another another 2or 3K added on. The 04 would see the spread increase more 3or 4k.(If you have a 48 month loan it would be paid off too...) 05 might be a smaller add on of another 2 or 3K, but you'd already be 10K or more away from a new vehicle. The 06 might see a gap approaching half of your RX300's original selling price. I would suggest you "map out" the point at which you would feel the least comfortable watching your 'retained value' melt versus the 'purchasing power' towards a replacement... I have seen far more vehicle owners hold on to too long than sell too soon, if that "extended warrranty" makes it too easy for you to "hang onto" your RX300, it will cost even more...
There are a few things you can do to help. Take that "slider" that covers the sunroof and cover its top with the most reflective side of household aluminum foil. Add additional window film to the front side windows. Make sure all of the windows and doors are fully closed.
To most quickly cool the vehicle after it sets in the hot sun "flick the temperature setpoint to max cold, over-ride the recirc function to "fresh" and turn the blower all the way up to more quickly purge the interior air that is likely hotter than the "fresh" incoming air. The cabin airflow exhauster is fairly restrictive so lower one of the rear windows slightly.
If you happen to drive away immediately then the vehicle's aerodynamic nature will prevent most exhauster airflow so as Lexus states, lower the rear windows until most of the trapped hotter air is purged.
Once the cabin interior temperature has reached a temperature at or below the outside world then manually switch it to recirc, close the windows and now as soon as you deem it viable (a learned thing) put the system in fully automatic. It may not seem so but the Lexus climate control achieves its highest cooling efficency with the blower running at its very lowest speed, the longer it takes the airflow to move through the evaporator core the colder it will get.
And, in automatic mode while the system will continue to indicator "fresh" mode it will actually be mostly recirculating already cooled and conditioned cabin air.
On my 92 LS400 I once disconnected the cable that meters the engine water jacket to the heater core and tired the valve off so absolutely no hot water could flow throught the heater core. Very hot day in north central MT that was.
I don't know where, exactly, that water valve is in your RX but you might consider tying it shut for the duration if nothing else works.
I find that the system works best for cooling on HOT days (it works fine in automatic mode if not capacity challenged) if I turn the setpoint to "max cold", set the airflow routing to bi-level, footwell and dash, and then manually monitor/control the blower speed to control the cabin's comfort level.
In "max cold" position the water jacket flow valve should be fully closed if it was correctly set at the factory.
You're now in an area that is famous for being both HOT and HUMID, so you might be amazed to learn that most of your system's cooling capacity is flowing out the condensate drain. "Squeezing" gaseous water into liquid form boils off a lot of refrigerant.
And now, if you bought a dark interior just forget everything above, you're just simply out of luck!
Typically after the first 5 years, you have no more monthly payments to make on the car. So other than regular maintenance of the car, you don't have any other overhead for another 5 years if you keep the car for 10 years. This outweighs any Residual value calculations on your vehicle.
Think about this and you will realize the folly in your argument.
Even my old Fords, 68 & 75, went 250K miles without undue maintenance costs. My 92 LS400 has about 80k miles, has NEVER been back to the shop, I replaced ONE oxygen sensor in all that time.
Today's cars are an automotive mechanic's nightmare!!!
We have a 2001 RX, black over black and reside in one of the hottest areas within So.CA, semi-desert. Not unusual to see 110-115 F. but humidity is, of course, pretty low vs. Chicago.
Car cools down great if the A/C is operating properly, and yours might not be. So, as Zizzy suggested, have it checked - still under warranty at this point unless you racked-up 50k miles rather fast!
As for other suggestions, I can second that one about tin foil being a major advantage, layered with shiny side up on top of the moonroof slider.
Along with McGyver, the poster that suggested the tin foil trick, I've been able to pick-up radio transmissions from Mars, Venus, and Pluto - and the Moon telecommunications comes in so clear you'd swear it was next door!
Let us know the outcome.
Didn't you just state, basically, that the automatic mode of the Lexus A/C doesn't work in hot and humid climates?
Zizzy's "simple" thermometer test will be meaningless to an A/C shop. What they WILL want to know is the evaporator's inlet air temperature versus the "downstream" temperature. Like zizzy says you can obtain the outlet temperature by using "max cool" (NONE of the system airflow should/will be routed through the heater core) and putting the system manually in "fresh". The indicated outside air temperature will then be approximately the same as the evaporator's inlet air temperature. I would also suggest making the measurement on a fairly low blower motor speed.
Could work.
I made no reference to automatic mode. Please do not paraphrase me or twist my statements to suit your agenda. Wow, not just denigrating to Lexus automobiles, Lexus owners are now included.
And as I've said, get a grip.
Read again; Once the cabin has cooled down, I generally run it at Max Cold/Fan at 2 bars with the recirculator on.
I cool down the cabin by hitting the Auto button.
The automatic mode is the best! At Auto/Max Cool setting, the fan is wide open and I don't need that much air movement after the cabin has cooled down.
So again; Once the cabin has cooled down, I generally run it at Max Cold/Fan at 2 bars with the recirculator on.
Try copy and paste. It's easier than paraphrasing and saves me time.
ham1005, if you measure the A/C at the vent and it's 40F or higher, it's not meaningless. Tell an A/C shop that the air coming out of the vent is this temp and they'll tell you to bring it in.
My A/C @Max Cool/Recirculate measures 34F.
I've had similar A/C cooling problems twice. Each time, the technician started by sticking a thermometer in the vent. Simple.
In order to know if the system is operating correctly and efficiently one would need to know, at least approximately, the air temperature drop "across" the evaporator.
As it happens you operate your A/C the same way I operate my 01 RX300 A/C in hot weather. IMMHO if I rely on the automatic mode to keep the interior cooled to my passenger's comfort zone, 72F, using a setpoint of 72F, then the Lexus system eitehr neevr gets there or takes way to long to get there and then even when it finally does it's automatic modulation moving from sun to shade can be very discomforting and annoying.
Setting the temperature setpoint to max cool eliminates the system's control loop for adjusting the mixing/blend door (and thereby the cabin temperature comfort level) and always provides outlet airflow with the MAXIMUM cooling applied. When you modulate the blower speed (to two bars) to control cabin temperature your are simply replacing that system control loop with your own "senses".
So as I have said, you proved my point, whether you like it or not.
The Lexus RX300 climate control does not have adequate capacity for HOT climates, and especially so for HOT & Humid climates.
Actually it appears that at the base, or fundamental level, the Lexus RX300 likely DOES have enough cooling capacity provided the control system never routes a portion of the system airflow through the heater core (reheat cycle). Lexus probably decided that the resulting airflow (with no reheat) would be so cold as to be discomforting.
Max cool/recirculate/34F...
Damn that's COLD, gives me chills, shivers, just setting here thinking about it.
I've proven nothing. There's nothing to prove. His A/C is not performing as well as he likes. Your points remain unclear and irrelevant. Again, please do not twist my statements to suit your agenda.
My auto mode works perfectly well. When I hit auto, it's doing exactly what it's set to do. It's set at Max Cool, and that's what it pumps and attains, Maximum Cool (which is why I turn it down). I want it to automatically turn my cabin into an icebox. It does just that.
I fully expect it to automatically result in a colder, less humid cabin than I prefer, because, outside, it's hotter and more humid than I prefer. This enables me to automatically cool off as quickly as possible.
I suppose I could select a specific temperature, like 72 degrees, and then hit the auto button. The fan would automatically adjust its speed to attain and then maintain that temperature. Whee!
I personally have 60k on a 99 rx. I bought it with 50 last fall. Still running smooth. Any one else?
Has anyone had a similar situation and has it turned out to be related to emission filter, etc?
I will agree that if you have the discipline to "continue to make payments" to your own savings account you would be money ahead hanging onto a vehicle BUT the reality is 99% of vehicle owners will need a replacement when their present vehicle is sold/disposed of and too few come with any significant cash. As such, they are making a highly leveraged purchase, hardly an investment so a "return" (ROI) can't really be calculated. I suppose you could calculate the total expenditures and figure this against against "opportunity cost" but you'd soon have a spreadsheet that looks like something from WorldCom or Enron ;^). The efforts of Edmunds to show TCO are valid, and if people use 'em they'll be wiser for it.
I will stand by my arguement that you often do better using the 'retained value' of one vehicle to lower the TCO of its replacement rather than squeezing the last bit of value out of vehicle and starting over. This is especially true if you own a chain of vehicles with DECREASING TCO, something that is easier to do as several manufacturers are reducing maintence needs in newer vehicles. {I suspect that some makers will find they need to move back towards 'planned obsolence' as the 'lonely mechanic' will eventaully hurt overall profitablity for dealers/manufacturers if people can own trouble free vehicles indefinately.}
I too have seen the "8 to 10 year" maximum value calculations, and they don't hold up for many, many vehicles. The frequency with which models change, the additional optional equipment and the competitive offerings all conspire to make many vehicles worth a fraction of what they were worth new. That is why I emphasized that each vehicle owner should chart out the gap between what their current vehicle is worth and what a replacement would cost.
I also clearly stated that some cars deprecaite along a steeper line than others. Fortunately the Lexus LS sedans are holding value tremendously well, right up there with the best ever. I do not think that the RX300 is doing nearly that well in retained value and length of time on used car lots/supply of new vehicles (sludge factor?, Highlander, competition?). This situation may only worsen when the redesign/replacement bows in a year or so as a 2004 with many changes expected to combat the MDX, streched X5, Cayenne, XC90 etc...
I will concede that I was painting with too broad a brush when I used the 5yr/60K mile number for all vehicles. There are a ton of vehicles that you'd really take a bath doing that. There may even be some situations where driving a vehicle until it has only 'scap value' makes sense, but this is, afterall, a Lexus RX300 forum, and the image factor is a strong influence.
I have experienced none of the A/C problems that have been interminably ranted about and beaten to death in this forum (and unfortunately, others).
I feel these are discussion threads. I don't see participation in this forum as an opportunity to set up one's soapbox and bash the RX 300.
Sadly, there are socially retarded indiduals who troll these forums and post flamebait believing that others will buy into their flaccid rhetoric.
1. Go to max cool & FRESH
2. change the system airflow exit routing to footwell & windshield (Minimum outlet airflow restriction with no 34F airflow to your face)
3. drop each of the rear windows 2" (the existing exhauster/path is too retrictive)
4. Run the blower full blast for 3 to 5 minutes (purge the HOT interior atmosphere first)
5. Drop the blower speed to a comfortable level, close the windows, convert to recirc, and exiting airflow routing to bi-level.
6. Convert to normal automatic mode, 72F(?) after ECU deterministic routine computes that the interior materials and surfaces have reached an optimum temperature level.
Perhaps I'm dreaming.
But all these capabilities already exist, both of you clearly use some of them. Give me access to the ECU code and a good programmer...
Instead Lexus uses the system in a counter-productive way, cooling 122F air to XX rather than bringing in 102F air (to cool to XX) to purge the 122F air.
I find it amusing that anyone's decision on whether to purchase an RX300 would come down to the 20 seconds or so of thermal discomfort common to all vehicles.
Surely a Lexus has some redeeming qualities! :-)
tidester
SUVs; Aftermarket & Accessories
1. Go to another car dealer.
2. Trade their Lexus RX 300.
3. Drop their membership in any Lexus forum.
4. Run their mouths somewhere else.(purge the HOT air inside them)
5. Drop the subject.
6. Convert to normal.
Give me access to a cattle prod with 50,000 volts for 10 milliseconds...
Purchase decision:
Hmmmm...
I'm not discussing anything regarding purchase decision, I guess what I'm really trying to do is to get Lexus to abide by their motto:
"The Relentless Pursuit of Perfection"
Or:
"The Passionate Pursuit of Perfection".
I would think Lexus would find it extremely embarrassing that the lowly Ford Escape SUV has a better and more reliable AWD/4WD system than the RX. At this point in time the only thing that will keep me from trading up to the next RX model, mostly to rid myself of the Nav display (I can tolerate the Nav being useless but the loss of the LCD readout is another matter), will be if they don't fix the rear wheel clearance problem.
It seems to me the only possible harm in pointing out any Lexus vehicle's relatively few flaws is if Lexus itself doesn't pay attention and therefore they simply propagate the few flaws they have into the next model/version.
And...
This isn't HOT air.
Nor is it ink.
Mostly it's a relatively few, universally, damn few, electrons.
No, but I'd bet the hot Tucson sun would give Texas a run for its money! :-)
Mostly it's a relatively few electrons.
You got that right! Thermal and electrical conductivity are very closely related.
Happy 4th!
tidester
Until they introduced the Focus.
The same Escape with the steering wheel lock nut coming off, right?
The same Escape with the overwhelming and dangerous fuel leaks from the filler pipe, right?
The same Escape with the interior trim pieces coming off or breaking off, right?
The same Escape with...what...6 formal recalls and a few dozen TSBs?
Right. That Escape.
Why doesn't Lexus EVER LEARN?
The Relentless Pursuit of an Escape.
Makes me tingle all over.
now
These slogans are so unimportant that Lexus just changed theirs to take advantage of the catchy alliteration (head rhyme) of the 3 P's.
Even the name Lexus is an advertising exec's creation.
Where does one see these phrases? Paper/magazine ads, TV commercials, Posters/brochures at the Lexus dealers.
Look in any Lexus owner's manual. Find these slogans there? Not likely.
Electrons? More like dogma.
Hot and DRY, Austin, HOT and HUMID.
Drier air allows the human metabolism, sweat glans, to work.
Ford Escape: Nobody said anything being reliable about the Escape except the AWD/4WD system. Granted it isn't worth considering if the rest isn't reliable but my point was that Lexus should use the Escape's (or the Sequoia's, absent the low range) AWD system (and wheelwell clearance)as a "model" for the RX.
Relentless to Passionate..
No, someone FINALLY realized that "Relentless" really implies an acknowledgement of NEVER getting there.
And are you saying we shouldn't expect Lexus to "Passionately Pursue Perfection" because it's simply an advertising slogan?
Damn, and I always thought that was the reason the entire Lexus product line is the absolute best in the world marketplace.
Advertising, nothing more...Hmmmm....
Relentless: Showing or promising no abatement of severity, intensity, strength, or pace.
See Unrelenting: Not softening or yielding in determination.
Again, please do not twist my words in support of your agenda.
All I said is, "These are advertising slogans. Brief attention-getting phrases used in advertising or promotion. Nothing more."
To quote E.A. Poe, "Only this, and nothing more."
Again, another flaccid argument presented, based upon twisting my (and now other's)words.
You state: I always thought that was the reason the entire Lexus product line is the absolute best in the world marketplace.
You really believe that? Because of a slogan?
LMAO. I repeat, Madison Avenue strikes again.
Can you hear it?
David Hannum laughing in his grave?
David Hannum, b.1832 Look him up, too. LOL
Steve
Regardless of the humidity, I perspire as do most people in the heat of summertime.
Now, some would actually make the bold assertion that "drier air allows the human metabolism, sweat glans, to work."
Well, that's plain wrong and rather misleading. Sweat glands work regardless of humidity.
Perspiration evaporates faster and cools one more efficiently in drier climates, but people can sweat when they exit their Lexus whether in a tropical rainforest or an arid desert, or even in Arizona or Texas.
Anyway, it's always great to hop back in the Lex and feel that fine, way more than adequate A/C.
tidester
According to Lexus:
FWD 0 to 60 in 8.5 seconds
4WD 0 to 60 in 8.8 seconds
But, these performance capacity figures are for comparison only, and were obtained with production or prototype vehicles by professional drivers using special safety equipment and procedures in high humidity situations in Austin TX while during the relentless pursuit of perfection, I mean the passionate pursuit of perfection. These should not be attempted on public streets or highways except with the Ford Escape AWD/4WD system installed or with snow chains only on the front wheels. If you bought a dark interior just forget everything above, you're just simply out of luck!
Mooving along.
Isn't that a Swedish acronym for "heating, ventilation air neurotic"?
Perhaps it's just a pen name.
Impala?
Isn't that Swedish for Chrysler Town & Country AWD?
So many questions, so little time!
tidester
Ahem, that's my story and I'm sticking to it.
As always, negotiations are based upon commitment and research. Any other tactics/strategy approaches will be appreciated.
Dan
Regardless, are you really certain a used 99 RX has enough "value" over a brand new HL to justify the RX?
Looks like to me that maybe you could get a new HL for that 15-20% less than the used RX. The only thing I can think of offhand that you would be losing.......is the RX badge.
A new HL AWD will have the VSC/Trac and that's a BIG advantage over the 99 RX even if it does have LSD.
And IMMHO the HL has a neater, cleaner, "look" about it, less "minivanish" than the RX.
You can search for my past posts on that subject if you like. If you were purchasing new I would recommend a hard look at the ML (Past MLs have had reliability issues), but since you're looking at used you might even consider the Chrysler T&C AWD minivan.
I own a Lexus RX 300. I love it and recommend it, but please build the Highlander you'd like @ www.toyota.com, check out all the options and packages and then do the math.
Used RX 29,500
-15% 4,425
= 25,075
A new Highlander AWD for $25,075? Not likely.
Or 20% off for $23,600? Dream on.
wwest-There are rules in this forum regarding misleading posts. I challenge you to post any link with these prices for a new AWD Highlander.
You lose more than the badge. HID? Please re-read your past posts. Have they mini-vanished from memory?
And you are right of course zizzy, the best price I see on a new HL is about 26K.
But.
I would still dicker with the Toy salesman first, and then I would advise the Lexus salesman of my "options". In the end the Toy salesman may be able to beat the Lexus' salesman's best CPO deal, it is July, nearing the end of model year.
And by the way, you should expect that the Lexus "certified" sticker adds about $1900 to the sales price.
In effect, the very same HVAC system one poster on this board has denigrated so strongly on RX and now he's suggesting that others purchase it?
Oh well; as the host would say, that's a Dead Cat Bounce so let's move on...
Dannysf, there's no reason to pick-up a dealer certified RX if they charge more than $500 beyond private party market value for that extended warranty. Piece of mind for the 100k extension (less the mileage on date you purchased it) or 3 years from date of sale to you is a good thing but not if it costs anywhere near a $1900 premium over an RX from a private party.
I've been pleased in the past to purchase a private party used Lexus, a new Lexus, and a Certified Previously Owned (CPO) Lexus. The CPO procedure, which the dealer pays a couple hundred bucks for, in my case was a joke. One example - no spare tire - how's THAT for a 128-point inspection?! Hey, it ain't easy to remember all 128 inspection points, right?
CPOs, IMO, are just a marketing gimmick; notice that the "best" CPO plans are on the vehicles least likely to break down.
If I was currently in the market for a used RX, I'd pick a private party used one with at least 6-12 months left on the warranty and a decent amount of mileage left (original warranty, bumper-to-bumper, is 4-yrs/50k miles, whichever comes first - vs. the Highlander which is 3/36).
In 6-12 months, any serious problems will be apparent and Lexus will take care of them. After that, reasonable maintenance is all you need and perhaps one major dealer service (or good independent mechanic) for maintenance every other year. CPOs don't pay at all for maintenance services.
A lot of RXs are procured via 36-39 month leases and there's a TON of these 1999-2000s coming back to Lexus Financial Corp this year.
Also, most of these leased vehicles have a monthly cap of 1,000 miles so if the owner brings it back with excess mileage, they're responsible at (usually) 15 cents per mile over their end-of-lease 36k. However, if they buy the vehicle at end-of-lease and resell it, they get out of paying any excess mileage charge.
Why not put a classified ad in the largest metropolitan paper near you and offer to buy their RX coming off-lease?
Contract residual value on a 36-month lease for a 1999 RX was probably 60% of MSRP ($32k) or $19.2k. Let's say the original owner has 10k excess miles on it so he's looking at a $1,500 cost just to give it back to the dealer...
If he buys the vehicle for the $19.2k and sells it to you for $20k, he makes a few bucks for his trouble and avoids paying Lexus $1,500. You get a RX still in warranty for $20k but of course you have to add TTL fees - as you would on any used vehicle.
Of course, it's more work than checking out a few dealers but the 4-yr/50k warranty on all Lexus models makes this a viable acquisition method.
I'm dazzled by your display of cunning, keen
insight and dexterousness in this post.
An RX 300 still under warranty for $20k? Gimme!
And all this with a Dead Cat Bounce to boot?
Too much. Next!
A/C: I can't say for sure but I would suspect that the HL has the same basic A/C components, heating/cooling capability, as the RX. It's just that the HL is always a manual system and the RX is automatic but must always be over-ridden manually, if one wants satisfactory operation, that is.
